Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: Meat_And_Beer on June 12, 2013, 05:08:58 pm
Hi There! First post, lots of lurking.
There are some amazing people on here, and I’m hoping someone can help me out on a build I’ve been working on for over a year now. It’s my first, and quite an undertaking for someone with no previous knowledge of any of this stuff!
I feel like I should give all the details I can, so I apologize for the massive length of this thing in advance!
I met a super talented, smart and awesome man through my girlfriends place of work who’s been building tube amps since he was a teen, now in his mid 50’s. This started as just a preamp.. Now it’s this massive two channel, mixable 50 watt monster with an fx loop. He took my under his wing, and taught me everything I know right now about this art form.
I was strictly told not to publish any of the schematics, or even photo’s of gut shots online or anywhere. I’m at an impass, and I now live about 5 hours from my extended parents. (He and his wife) Even an emergency visit when the problem occurred, couldn’t produce results that got to the bottom of it. So, desperate times, desperate measures…
The amp has two main channels, 5 gain stages each. Channel one, as we’ll call it, is the top row of knobs on the chassis. Channel two, also has 2 buffer/followers (on 2nd & 3rd stages). A switch sends the signal from after the 2nd stage buffer to the PI, effectively giving a Marshall Plexi mode. Neat trick! Each channel has two defeatable tone networks. Channel one has a defeatable additional gain stage, Channel two can select its output from stages 1&2, or 1,2,&3 with a defeatable feature called “Contort”. (A glorified Contour)
Channel one (Stage 5) was crafted from part of an Engl E530 schematic, and heavily modified/developed. (For months I slaved over this channel, and the resulting circuit floored me when I got it right to my ears!!) Channel two (Stages 4&5) is a BK Butler Real Tube RT-902, again, HEAVILY tinkered with. These channels are now very much deviated from the original, but that’s where they started out.
The two channels can be played independently, or summed through the mixer tube at the end. This mixer has a resistor ladder that yields a Hi-Z output, the FX send, and of course to the PI.
I had cross talk issues (Electrostatic coupling) between the channels that I got rid of with the brass shielding that you see, and also by changing almost every signal carrying wire to shielded wire. Another amp builder told me how to completely silence the channel not in use through the rotary selector knob, sending ground to shunt its output. Fantastic! But if I knew that before the build, the rotary would have been at the other end of the chassis, of course…
This was before I had the final values for the FX loop installed. It was working splendidly! Every single aspect and component was in great functionality. (Sans some tweaking that’s always inevitable at the end of a build) I even put it in its case and played it for a few days while I was waiting for my amp tech guy to get back to me on final values for the loop. The day came, and I took it back out of its case, and put it back onto the working jig, and installed the FX loop properly.
I tested it at low volumes, and it seemed super. Then the next day, and I got on the volume a little bit, and something sounded wrong… As I pondered and stared at the guts, a spark, POP! Shot out of the power supply. Weather this was of real consequence, I’m not sure anymore. I never found the crime scene, no arc marks to be found. The inside of the chassis had never really been cleaned/blown out, it very well may have been a foreign object landing somewhere undesirable with the flipping around from jig to case back to jig. Pretty squeaky in there now though.
The thing that sounded “wrong” was that channel 1 is somehow getting another signal riding on top of it, sounding much like the electrostatic coupling I had gotten rid of. That channel sounds nothing like it’s supposed to now, but I can hear the original signal back there, it’s just getting squashed by this parasite!
Channel two as well, but not nearly as noticeable. Also, its second tone network’s treble is problematic. At zero, there is full volume. As you bring it up, treble increases, but volume decreases.
So I took the emergency trip down so see him for the weekend and figure this out. We suspected something in the power supply, where the spark originated from. (There is now also a nasty ground issue, that hadn’t yet really developed)
We checked and swapped out for known good;
- All filter caps
- All decoupling caps
- Choke
- Jumping over the FX loop/completely bypassing
- PI cap
- Power/connections to color organ (Yup, there’s one of those in there too)
- Tube swaps
- Bypassing “Plexi Mode”
- Guitars/Cables
- Many other assorted jumping/removal/otherwise disabling things
Through our experimentation, a swirling sounding ground issue had developed. I attached a sound clip of it here. At the visit, (Providence, RI) it was more like RF, radio, and static. At home (Much more rural, not as much city) it’s more just like swirling ugly ground noise. The sound clip is at home, I did not adjust any knobs during the recording, it’s just a swirling pool of madness all on its own.
Originally, I had bent lug 3 of the pots that ground to the bus bar that runs along both rows of pots. This broke/made them iffy, so I replaced every single one with brand new. This ground issue sounds just like it did when a pot or two was acting up. Can’t be one of those now, though, right?
We put a couple 22pf across the grid and plate of some first stage areas, rolling off the top end starting around 15kHz. It helped a bit with the RF.
Here’s how it’s set up mechanically;
- 1st bank of filter caps ground at the center taps with the PT
- 2nd bank grounds on bus strip
- Decoupling caps ground at or near where the stages they feed also do on buss strip
- Buss strip grounds at PT point
- OT common is at the speaker outs only
- Input jacks ground to 1st stage of channel two
PT: Hammond 374BX
OT: Merc Magnetics JCM 900-50-0
Choke: Merc Magnetics MAR100-C
The PT and other gnd’s are to one of its mounting bolts. I know this is not in good practice now, I plan on changing that. I tightened it, poked at it, with no effect. I’ve spent countless hours poking around with a stick, I can NOT find where this crap sound is coming from.
Do I have too much shielded cable in here?
I also attached a picture to see if some eagle eyes can pick up on something. (It was much prettier before all the mod’s, relocating, adding the color organ, and taking everything in and out a bunch of times and putting burn marks all over) I’m already going against his wishes, and would really prefer not to post any schems. I may decide to PM something to someone, but let’s see where we can get with this first.
Pictured parts labled:
1 – 12AX7 - Stages one and two channel 2
2 – 6AV6 – Stage three channel 2
3 – 12AU7 – Buffer for stages 2&3 channel 2
4 – 12AX7 – Stages 1&2 Channel 1
5 – 6AV6 – Stage 3 channel 1
6 – 12AX7 – Stages 4&5 Channel 2
7 – 12AU7 – Stages 4&5 Channel 2
8 – 12AU7 – Mixer
9 – 12AU7 – Phase Inverter
10 – 6AU6 – FX Loop (very fast tube, could use some taming in the upper freq’s somewhere I’m sure)
11 – 5U4 – Rectifier
12&13 – 6L6GC
Caps A-F are 22uf 450V Decouplers (Between 290v-310v supplies)
A - Mixer
B – V5, V7a
C - V4 a&b
D – V10 FX Loop
E – V3b V2
F – V3 a, V1 a&b
G - ~100v supply for V6 a&b
H - ~100v supply for V7 a&b
Any voltage readings or other information, I’ll be happy to give a list. But they’re all pretty much where they should be as far as how it was designed. (And as far as I can tell)
Remember, this amp did work, and quite well. Something has slowly failed/moved out of spec, or has mechanically failed. I’d like to believe it’s one thing that gave out… But obviously I don’t know for certain.
You are a trooper if you read this whole story, and I commend you. Thanks for such a great place guys, any and all suggestions on further troubleshooting this beast is so much appreciated!
-Chris
More pics, trying to figure out how to post a sound clip too...
This should do the trick:
https://soundcloud.com/agormortisrr1/horrible-noises/s-oI33f
very complex; perhaps overly so. schematic as built would be of most help as would anode, cathode and screen (where applicable) voltages for each element annotated.
Voltage readings as requested. I knew I should have just posted em…
Again, I really would rather not post the working schem, I gave my word. Besides, the final (Minus power stage) is about a 3x1.5 foot piece of paper. Cripes!
V1a
Plate: 169v
Grid: 4mv
Cathode: 1v
V1b
Plate: 1601v
Grid: between -1 and 15mv…
Cathode: 1v
V2
Plate: 94v
Grid: -10mv
Cathode: 608mv
V3a (1st buffer)
Plate: 268v
Grid: 160v
Cathode: 164v
V3b (2nd buffer)
Plate: 294v
Grid: 93v
Cathode: 104v
V4a
Plate: 171v
Grid: 1mv
Cathode: 1v
V4b
Plate: 175v
Grid: 5mv (fluctuates up and down quite a bit)
Cathode: 1v
V5
Plate: 105v
Grid: -36mv
Cathode: 604mv
V6a
Plate: 62v
Grid: -284mv
Cathode: 3mv
V6b
Plate: 56v
Grid: -169mv
Cathode: 3mv
V7a
Plate: 30v
Grid: 2mv (up and down)
Cathode: .8v
V7b
Plate: 33v
Grid: .4mv
Cathode: .9v
V8a (mixer)
Plate: 189v
Grid: 79v
Cathode: 93v
V8b (mixer)
Plate: 188v
Grid: 79v
Cathode: 93v
V9a (Phase Inverter)
Plate: 150v
Grid: 39v
Cathode: 50v
V9b (Phase Inverter)
Plate: 150v
Grid: 39v
Cathode: 50v
V10 (FX Loop)
Plate: 100v
Control Grid: .6mv
Cathode: 1.8v
V11 (Rect)
Plate (Pin 4): -81mv
Plate (Pin 6): -80mv
Filament (Pin 8): 422v
Filament (Pin 2): 422v
V12 (6L6#1)
Plate (Pin3): 421v
Screen (Pin4): 419v
Control (Pin5): -44v
Cathode (Pin8): .5mv
V13 (6L6#2)
Plate (Pin3): 420v
Screen (Pin4): 418v
Cathode (Pin8): .6mv
That's too bad.
Sluckey, I know. Thing is, it worked, and now this issue. (I've tried changing it back to when the FX loop wasn't working, same deal. Meaning something bit the dust and I have to find it) I want to see if anyone has any leads on it before I go and divulge it all.
I know this place is very respectful, and an incredible wealth of honest knowledge. To most of you veteran builders, I'm sure nothing in my schematic will make you jump out of your chair. You've most likely seen much more sensitive material than my schem could even hold a flame against. I do realize this.
Do we have any suggestions? I've seen many issues resolved in these threads with less information than I've given here. I'm going to do what it takes, and this thing will make it across the finish line. That is a fact. :)
:anyone:
That's too bad.
+1
I can appreciate a man keeping his word. That counts in my book. And if you have given your word, I think you should keep it.
However, it's truly a shame that you're confined to asking for help within that frame work on a forum that shares schematics so liberally and graciously with others. But again, I can appreciate keeping your word.
Seeing the schematic may have been useful in us helping you.
Respectfully, Tubenit
Part of that noise sounds like parasitic oscillation, as you have observed, which causes all sorts of weird things to happen. like pots working the wrong way around.
Do you have an oscilloscope or someway of signal tracing. Even then, hyper sonic oscillations is like radio, it transmits out and gets into everything. The fact that it was picking up radio transmissions in urban areas suggests this also. Check each stage and make sure that their response is rolled off beyond audible frequency range( I think that is putting a few pF between anode and grid for valves but DO NOT TAKE MY WORD FOR THAT) .
Supersonic oscillation can also overload power supplies and blow transformers/speakers.
V4b
Plate: 175v
Cathode: 1v
Grid: between -1 and 15mv… ?????
Grid: 2mv (up and down)... ???????
Those Grid voltages needs super sleuthing. It appears to be talking to itself i.e. hypersonically oscillating. Can you supply Grid CURRENT values, maybe problems with grids latching and drawing current.
Have you tried shutting down logical blocks and then re animating in logical block - like computer programming.
Example/Explanation;
1.Remove tubes and B+ - maybe even coupling caps between stages from everything except PI and Power Amp Stage -TEST,IF faulty FIX (is it PI or PA???), IF ok NEXT
2.Connect first input stage (V1a, V1b) - TEST, if faulty FIX, ELSE NEXT
(OR work backwards from PI/PA, one stage at a time getting it going and stable.)
etc etc
Have you had a drumstick in there tapping around for microphonics and testing lead dress for changes in the symptoms.
I'm new here and not very familiar with valve electronics, but that amp looks like a radio transmission waiting to go on air. You may need to do a lot more shielding with copper plates to get it stable. (I was a marine radio technician at the end of the tube era, early seventies)
Sparks shooting out is really as bad as it gets, at least it didn't blow your house fuses/breakers.
If that sort of advice is not going to help then the good folks here will need a schematic, if it's a trade secret - well - you're on your own really. I mean that in a down to earth factual kind of way - no hurt intended. Maybe convince your tech buddy to let us have the schematics.
Best of Luck.
29 knobs, years in the making, multiple fathers, secret schematics, mystery sparks.....
I dunno what to say. Not even where to start.
My personal opinion is that it is "over built", in the sense of "10 pounds of sausage in a 5 pound bag". Actually most of the chassis is quite clear and neat, but that front panel... :huh: :huh: :huh:
Stare at it. Imagine you are the signal. Where do you go? Where can you go that ISN'T good?
I would get lost with all the knobs or controls. At one time i was into building amps with all kinds of bells and whistles.
At the present time for me a simple schematic and layout with little insertion loss is what i like best.
That's too bad.
+1
Tubenit,
Thank you so much for seeing it as I have to also. Believe me, I want to lay the whole thing out for everyone, as I know that will get it down to the delicious meat and potatoes. I mean no disrespect to anyone here by withholding info. But without this guy that has taught me, spent countless hours calculating and drawing up schematics for me, teaching and showing me why the hell this does that or how it affects the other, I’d just be buying amps and wishing I could get my tone.
My tone is right here, inside of this misbehaving contraption. I just need some outside help.
GlennJeff,
Your advice sounds like an excellent idea! “Logical blocks”... I would’ve never thought of that. I have a little pot/resistor network I use to clip onto a stage in my amp, and it’s fed it to a known good amp on clean to listen to what’s going on from the test amps input to that mentioned point. Bad news is that it starts from stage 1 on both channels.
BUT, if I check each individual stage, or “block”, that will tell me something else altogether. Thanks, I’ll try that!
I do have a scope. My generous amp father leant it to me before I left the last time I was down there. I need to fashion a grid for it, the “divisions” that is. But it’s still very useful for checking for ghosts and other junk on a signal.
I checked the squirrely grids for current, zero.
I’ve tapped and poked and pried at every conceivable connection and component. Just a little action at the first stages, which should be expected anyway, no?
I have fully ruled out that it is the power amp, or the FX loop. If I plug my guitar into the FX return, it’s a beautiful sparkly awesome clean signal that I could listen to for days. The return pot has tons of headroom to boot!
FX send sounds like the sound file attached, as does the Hi-Z out.
I’ll close with this,
Nothing anyone says about my wire dressing, overall build quality, or anything else is going to hurt my feelings. Please, be frank with me. I know there are a million ways of doing everything concerning these builds. Mine does look a bit ugly. (See all the LED’s behind each tube, and their corresponding wires. Those, are the ugliest. Ignore them if you can, I plan on addressing that.)
This is my first actual build. Each channel was built independently in a prototype chassis and developed. They looked MEGA ugly. The power amp also had its own proto chassis. Again, not at all pretty. (I have pics, if you guys want a laugh!) But when I plugged them all together, not only did they work like the dickens, holy mother of god was it splendid…
I’m getting better. I’m not going to drop this craft, I am VERY ambitious, determined, and a bit sharp. This is not to be confused with stubborn, fat headed or conceded. All criticisms are welcome. Thank you so much for the responses so far, looking forward to delivering good news in the near future!!!!
PS, I see a couple of new posts that I’m eager to converse about. Give me just a few minutes, gentlemen. :icon_biggrin:
Thank you for recognizing all this can in fact fit in here. It is, after all, the biggest chassis that Dirty Dawg Amps makes. Being that it's all clear and concise, but just the front panel is confusing, well, I'll just thank you at the moment. I'll explain below!
Boy and how. I agree! I mentioned in the beginning that this started out as a simple one channel PREAMP. How did it end up to be this thing?? Well, months and months of education, trial and error, and he thought I was ready for such a challenge. Sir, I promise you, this thing is a go. Have you any direction as to what is failing in my amp?
Now, I will address the pile of chickenheads on the face.
Has anyone had to work front of house at just about any kind of event? You have a mic, a board, some outboard gear, a power amp and speakers. (The typical scenario anyway)
You have to set the mic gain on the mixer just so, so that you're under clipping, usually, so you can set the mixers fader at unity without having to memorize about 10 tracks of where everything wants to be. Then there are aux sends, don't over-feed them either!
Weather your outboards are getting fed with the aux's or the main outs, no difference for this, it would get too technical with all of the sub out possibilities and everything. Just picture it a linear venture from mic to speaker.
If you have a return signal, or if your outboard effects have a send, you have to watch those also, again, to avoid clipping, or any other kind of undesirables. Within just this small set of equipments, you can greatly affect the tonal quality of what gets delivered to the power amp. Don't forget, you cant have THAT set too high or you'll overpower the speakers, or if they're set too low you'll be trying to pound your signal into them from the board and that wont sound too pretty either.
Here it is;
Gain staging. It's all about how you set the gain from one stage to another. If I want to hear the first tube pound the proverbial snot out of the preceding stages, I'll dime that pot. But I don't, so I don't do that. Next in line is how much do I want out of that first tone net? Do I even want the first tone net? I usually do, but there's a simple switch for yes or no, and accompanying pots because of load differences.
The more I increase the first input pot, directly influences how much of the tone net I will hear in the end. (If it's engaged, or it's just straight gain/volume) next is how I want that 2 stage pile to affect the rest of the mess. Next up, depending on which channel, is an optional thing. (Either the "more" on channel 1 which is just more gain, or the "Contort" on channel 2 which is a stage w/ contour really) You can include it, play with its tonalities, or ignore it.
THEN, there is the, "how much do you want to let that thing in..." Pot. It's the end, you can EQ that too, or not. Up to you. In the end, the switches you flip, determine the number of pots you have to play with.
This amp is an almost limitless tone machine. It's actually very simple. BUT, remember, I just asked for a preamp.
The more you play with this amp, the more and more easy it is to understand. It's really not as crazy as it looks. A lot of the pots are there for when you want them. Or, they can be all there at the same time. Up to you. :laugh:
I take it you mean that noise, which is in it's own way beautiful, starts from stage 1 on both channels. Signal tracing is probably not going to be helpful then, it's likely parasitic oscillation.
The initial outbreak of this oscillation could have taken out lots of things. Have you checked all resistors for appropriate values, caps for short. Check valves individually in a working amp)
Logical Blocks, this approach might save a little time;
Completely disable power to all channels and disconnect signal feeds except Channel 1. (How many channels are there ?)
Also disable any "side add-ons" that can be switched in, switch them out. Adjust gain structure for clean sound.
Good or Bad? Fiddle with knobs. What happens?
Disable/unpower Channel 1 and disconnect signal feeds.
Reconnect signal and power channel 2
etc etc
Basically, You had it working but it was faulty in the sense that it was unstable. You not only have to repair it, you also have to find underlying problems in it's engineering, which appear to be related to unwanted feedback paths which, as PRR pointed out, most likely come from the front panel wiring and pots.
Another BLOCK you could tackle;
Get as many of those front panel pots that are not necessary for "bare bones", "most basic" operation disconnected at the feed point on the PTP circuit board and unselect them with their switches, unwire their subsection on the PTP board. They, and their feed wires/shields, are antennas.
Otherwise, get it going one valve at a time. As your PI/PA is ok you should be able to use it as signal tracer once you've got rid of that "ethereal angelic music" that we call noise (by disabling sections). Using the internal PI/PA might detect anomalies that an external "signal tracer" amp would not.
This project was never really finished and it is going to be a big job to get it finished.
That is what makes projects fun though, in a masochistic sort of way.
I'm not the best person to ask, but, once you get it stripped down and working in "bare bones" mode I will be happy to TRY and tackle the radio engineering problem that the front panel poses.
All the best.
Eesh, I really hope I don't have to individually test each component. To answer, no I have not tested all of the resistors. Do you have a logical guess as to where to start?
Check valves in a working amp? Do you mean some of my tubes might be bad? If so, I've tried a myriad of tubes in different locations, I have a good collection of 12A_7's. (And the others) Also a tester, but they don't really matter in these occasions. I'm sure it's not a tube.
There are two main channels, one has a little trick that sends what is essentially a Marshall Plexi circuit to the speakers. Other than that, its just two, with a lot of yes or no switches and knobs along the way.
Thank you for your many ideas to narrow this down, I have a lot of work to do, and you to thank if anything comes of it. I'll keep everyone posted!
Something happened in between these two that you will have to figure out? You're stating it worked splendidly and then it didn't. I'd go back and undo everything added beyond working splendidly. And I'd probably replace everything around the area where the spark was in the power supply.
Components probably ok if PI/PA survived. What I was trying to convey is "develop some sort of strategy that is systematic and thorough" I guess. Doubt you'll get a "wave the magic wand" solution on this one.
Blue flames and Mushroom clouds (Mystery Sparks) are really a sign that something has been badly compromised so do what tubenit suggested first even though the power supply appears to be OK. Put the oscilloscope on the high tension B+ and make sure it is fairly ripple free and that the "hum/oscillation" is not getting onto the supply (or measure for AC on the DC supply with a DMM). Check around the terminals and plastic seals of the filter caps in the power supply for any sign, leaking goo, slightly buckled cap bases etc.
Also, as tubenit suggested, remove the prior modification that you did just before the problem developed. If that doesn't resolve the problem then its probably the long hard road.
Spend some time on it, implement tubenits suggestions and then get back to us. One step at a time.
By the way, I really like the front panel artwork, how was that done.
All the best.
374BX 200VA, 375-0-375 @ DC ma 175, 5VCT @ 3A, 6.3VCT @ 6A.
You have 10 preampish tubes .......... so I'm thinking maybe around 30 ma total or more presuming a LTPI?
The 6L6's will be drawing maybe 140ma?
Your PT is 175ma.
I am wondering if your current draw is at the max or exceeding the specs? That's probably not it but without a schematic, we're really grasping at straws trying to help you. It's kind of like diagnosing a car problem without knowing what kind of car it is other than having a V6 engine.
:dontknow:
Thanks guys,
I have swapped/subbed the entire area the spark occurred with known good parts.
I have already tried to undo what I did in the FX loop to where it was beforehand, that didn't work.
When I plug into the return of the fx loop, its a beautiful clean signal. (Telling me that everything from that point to the back end is good) If I send it to another device from the FX send, I get the noisiness.
tubenit, I asked my amp tech about this very thing, "Are we pushing this PT too much with all these tubes?" He said I was just about maxed out. Do tubes draw a specific amount of current depending on their type, or does it depend on things like what voltage you're running them at etc?? I'd like to actually know what I'm expecting from the PT also, and if this expectation is out of line.
I'm sorry, LTPI? I did a quick search and still didn't really get the gist of it. It's very easy to stump me on random things still.
I like Glennjeff's suggestion of breaking down all the blocks and searching that way. I'll start implementing that strategy next.
And thanks, the front panel was a lot of work! I found a font I liked, and plotted out the face of the amp on a program called Flexi 7. It's kind of like a CAD drawing program for sign shops that do decal and lettering work. Tried to match the yellow to the knobs with a shops in stock stuff, and had them run me off a few. I stuck them onto the chassis that was wet sanded and ready for clear. Had it cleared over the decals with automotive.
I know this power amp is essentially a Marshall with very little done to it, if at any. There are some parts of the schem that wont bother me to share, and this is one of them. As far as I know, all is good in the world of the power amp. This thing is a tank, it worked perfect with no issues both times that I built it.
Do I have an LTPI?...
Long Tail Phase Inverter, V8 and it's bias components.
Read about it here http://www.valvewizard.co.uk/acltp.html. (http://www.valvewizard.co.uk/acltp.html.) I found it a bit of a brain tease.
Maybe Sluckey or HotBluePlates or PRR or Dummyload or someone who actually knows can verify this ............ Do 12AU7's draw more current than 12AX7's? I am thinking they can handle more current?
I do think that the PT current capability could be an issue? Can you pull around 3 or 4 12A_7 tubes and still play thru it? IF so, try that and report back.
Do you know how to safely jumper over sections? IF so, try running V1a directly into the return of the FX. Does that work? Then add V1a & V1b into FX return. Does that work? and so on
Your goal by jumpering and bypassing sections is to locate which section creates the problem? And again, it may be there is too much current draw on the PT? I don't know.
BE SAFE!!
What tubenit said. Eliminate parts of the circuit (one part at a time) with a high voltage .1uF capacitor to ground to try and see where the problem is occurring.
Other than that suggestion, I really aren't prepared to guess whats going on without being able to see the (entire) schematic.
Both tubes draw the same filament current, but the tube current depends on the load. 12AX7s have more plate resistance and work better with larger plate resistors, and should not be used with less than about Ra = 47k, because the maximum plate dissipation rating is lower than a 12AU7. 12AU7s have lower plate resistance, and a higher plate dissipation rating, and therefore are capable of conducting more tube current. But if you use Ra = 100k with a 12AU7 triode, it won't conduct much tube current at all.
about the PI posted - in this case, Ib is around 7.6mA & the balance is wonky - about 28% out. R anode of inverting amp should be around 68K to maintain reasonable balance - IF this is truly a 12AU7 driven LTPI.
with 450V B+ one would expect Vbias to be in -53 to -55V range.
interesting NFB insertion point. usually it's inserted under the tail R.
have you tried disconnecting NFB loop? made sure secondary of OT is grounded properly?
He's probably not overloading the PT. PT current-ratings are not drop-dead blow-up points. 200mA in a 175mA PT will sag and run hot. Life may drop a bit. It's not today's problem.
*milli*Volts on tube grids which "should be zero" are un-important. There's always some grid current, in or out. Tenth-volts are not uncommon. Worry when stray grid voltage becomes a noticable part of grid-cathode bias voltage. For typical g-amp circuits with 1V-3V across a cathode resistor, a tenth-volt is "huh?" but probably not a problem. A hundredth-Volt (10mV) stray grid voltage is beneath notice.
He states "ruled out that it is the power amp, or the FX loop. If I plug my guitar into the FX return, it’s a beautiful sparkly awesome clean signal". Therefore speculations on 28% unbalance in the phase splitter are "probably" off the mark. (However I have seen old filter caps +plus+ a 50% unbalance excite motorboating due to large unbalance in output stage sneaking back into input stages.)
I was going to work backwards from the mixer tube to see which stages I could reconnect before I got to the undesirable sound. The sound is there with channel 1 disconnected, as well as channel 2 disconnected. I did not pull tubes or B+ for this...
Dummyload;
It's been determined that the power amp, PI, and FX loop are known good. That is different about the NFB location, I agree. I'm not the actual creator, to I don't have an explanation for you. OT common is to the speaker jacks only.
I've also determined that this disgusting sound is inherent throughout the preamp, both channels.
Why is my standby switch loudly thumping when turning it into the OFF position occasionally?
New tonight, the color organ now hums like hell when turned on. It was always VERY quiet while in operation....
I was going to go through and make sure nothing above a nice ~15k rolloff was getting into the tubes. Only problem is I packed up my sig gen already. Somewhere. I'm moving at the end of the month, so this is going to have to take a back burner pretty soon.
I'll be up to some amp shenanigans this weekend, hopefully I at least get some sort of solid clue soon...
Thanks everyone, I appreciate all the help you've been giving me, even though I'm an outcast that isn't allowed to share much.
Who knows, I might break. But it'll be a while.
i made no statement that was the culprit, and for the record, it IS very unbalanced; i was simply pointing that out.
my thoughts are that this amp has RF/ultrasonic instability in the output stage. since reading the last post, he seems to have made some headway by isolation of the pre-amp ckt.
i should have know better than to chime in... :dontknow:
DummyLoad;
Never feel that way. I have actually noted your observation and it now exists on a list of tweaks and things I plan on doing/modifying/addressing after the amp gets restored to its former functionality. I appreciate it, thank you!
DuumyLoad - It's probably got some really nice even harmonic distortion :icon_biggrin:
Meat_And_Beer - Disconnect the colour organ (whatever that may be). Forget about it, very secondary to the immediate situation.
Pull all the non PI/PA tubes except the one immediately before the last known working OK tube. Is that FX send, FX return or PI at this stage?
Standby switch may need a little thump filter on it. Not knowing how or where it is wired is a bit of a problem, but I'll get you some diagrams in a few minutes.
One simple step at a time.
There is actually a harmonic distortion characteristic at about 9k that's undesirable to me, think the two may be cause/result somehow?
I had the color organ (Blinking LED light ckt) disconnected for a long time while working on this problem, I cut its power and signal feed. It didn't make a difference, but I also don't know its there (Aurally) when its connected and in the "off" position.
I was wondering, how many tubes is OK to pull at once? Isn't that not a good idea to have all the pre's out at the same time for supply/load reasons? I could very well be worrying about a non-issue, also.
If I pull the mixer tube, V8 (PI is V9, FX is V10) everything goes dead silent. Flatline. Any other tube I pull one at a time (Aside from PI/PA) will usually drop its volume, but otherwise no effect.
FX Loop is the return, Send comes from a resistor ladder after the mixer.
Here's the supply. I thought the .1 across the switch was supposed to do that? Or would that be more like a 4M7 to gnd?
Dear Swirling in Providence,
Your problem is not with the amp. Your problem is with the Guru! I'll let you in on my experiences and offer a solution to your enigma.
Having never spent much time in the learned halls of academia and like you pursued the dross-less path to Jedi-Tube-Sorcerer, primarily by way of self study, I would at times find myself enamored in the presence of that mystically speaking, (on purpose to enhance mystism), curmudgeon of knowledge that frequently is fall out of the corporate world due to the fact that: They don’t get along very well with others. The all knowing "Guru of Tube Nirvana"
Smart as H*ll they are very appreciative of your presence for reasons including, someone recognizes them for their brilliance-
My personal experiences with Gurus are basically positive but they definitely have their quirks and eccentricities. After a time you wake up one day and realize two things: The bizarre aspects of their behavior tends to drive you away- (The use of profanity is a common trait with them when they begin to diatribe their favorite injustices upon, presentation of a simple query). The falling out begins as your knowledge advances to the point of asking questions that result in long-winded answers ending with- I don’t know; either said or left to the interpretation of the hearer. Your experience may be different.
In reading your post you state the design is a secret and the Guru can’t fix it, paraphrased. In passing I wonder first if G. intends to build and market it or does he just want to keep it a secret? Big difference.
By the way- unless a product is doublesealed in epoxy and encased in a welded self destructing chassis the design will be fathomed in a matter of days upon release or by a technician that loses his authorization because he can’t pay the $10,000 service department license fee. There are no more secrets- Just ask the NSA.
Here’s what I think has happened and how to attempt to resolve it or ethically break free from your commitment to keep it a secret should resolution fail.
G. Doesn’t know how to fix it. Something has crossed the boundary of logical flow in the circuit. If G. won’t commit to fixing the design he got you to spend all the time and money on and G. won’t let someone else try to fix it and G. doesn’t intend to profit from the design of it- He should let someone else fix it. Has G. ever mentioned profit sharing if it became a smashing hit?
G. has an ethical problem.
I’m very busy cause we may have a nuclear war any minute so I’ll cut to the chase:
Go to your Guru and have a serious talk. Tell him diplomatically you have an expensive broken amp that he goaded you into building. In the process your going to find out what kind of integrity this person has; and the vibrations here will tell me some things too.
If, as you imply he is a close friend of yours he should either offer to fix it some way or let you divulge the schematic so that others may attempt to do so. What does it say if he won’t do either and your stuck with a white noise generator instead of an amp.
The amp concept you have placed before us is not unique and even an amateur as myself has already figured out what the gist is. A couple of posts ago someone else created a similar- Space Age: Tube Amp Design Laboratory. You’d have to be from the 60’s or so to get that one.
If the Guru won’t do any of the above, I think in the process you will learn something about his character and with a clear conscience you could probably send a copy of the schematic to one of our "Trusted Gurus" here for further analysis- In strict confidence of course.
Then, at least if they can't help you, at the end of it all, they'll tell you to bring it to a local service technician, i.e. Amp Guru.
Crazy as a Silverfox.
Usually there is a resistor in parallel with the capacitor on the switch, typically 220k on the ones I've seen.
In most circuits pulling the tubes shouldn't be a problem. The voltage to the output tubes might increase a bit but no dramas USUALLY. I would not have expected this to be a whole new way of hooking up tubes. WAIT for one of the more experienced folks here to confirm but I think you have to do it.
OK, here is a step you should be comfortable with.
Remove the final tubes before the mixer in each channel, That is only removing two tubes, the last tube in channel 1 before the mixer and the last tube in channel 2 before the mixer. If you pull these two tubes and the noise is gone, you have eliminated the mixer stage as a problem, one step in the right direction.
Everything going silent when you pull the mixer tube (I assume it mixes channel 1 and channel 2 together) is perfectly expected if the amp is ok when you bypass the pre-amp via the FX loop, because pulling the mixing tube does exactly that, bypasses the preamp.
I do hope you are turning the amp off, removing the power cord from amp and discharging the caps with a 2k resistor on insulated clip cables with each step. Never be complacent when it comes to safety procedure. I got bitten by a charged cap a few weeks ago whilst doing some paid work for a studio. Left hand also. Not nice, not safe, I was concentrating on one section of the board and touched a power transistor that was waving it's little metal tag in the air where I was not looking.
Hope you enjoyed the lively rant from Silverfox as much as I did.
Silverfox,
You touched on some very valid points.
I've PM'd a couple people on here asking if they'd like to go over the schematic with respect to privacy. One very respectfully declined, another very nicely stated that I should go to hell because I wont post it publicly to the world. I can live with that, I have no hard feelings.
I've also contacted someone semi-local to me pertaining to this repair, awaiting his response.
We don't swear unless it's called for, but I know exactly the type you speak of.
The tech in question gets along great with others, is a super humble, honest man, has amazing academic credentials, not to mention a few amps in particular that would make some of you "Jimi Hendrix" fans wet yourselves and melt immediately afterwards. But I digress, and don't mean to overly defend him. But the dude is a total sweetheart.
It's not that he can't fix it, we just didn't have enough time for the problem at hand. We crossed many, MANY things off the list. Again, the amp WORKED, and something has given out or weakened. It's a search party for the faulty component(s), not an erroneous design.
Yes this is actually a simple build, thank you for realizing that. A lot of people get confused easily when there are too many colorful and shiny parts close together. Hell, I would too not knowing any better. This is my first build, you could say this is what I was brought up on so I'm none the wiser.
We have discussed producing these as one off's for those so inclined. Myself, personally, doubt that will ever happen, however.
Thank you for clearing the air on some of those things, I like your eloquence! :thumbsup:
Glennjeff,
Yes, the mixer does just that. Mixes the two, or when they're in single mode, they signal passes through just one half of the tube.
I just tried pulling both last stage channels tubes. It's still there, so shall we suspect Mr. Mixer??? I saw a ckt VERY similar to the mixer in my amp in the RCA receiving tube manual. My book is in a box somewhere, so I can't double check it, but I'll throw the schematic for the mixer in my amp up here tonight when I get home from work in about 9 hours from now.
Thanks again folks!
Unfortunately, this is not sufficient evidence to press charges against Mr Mixer. Had the noise gone with that test it would mean Mr Mixer was definitely innocent. Now he is just a more likely suspect.
Are you in a position to measure all valve 8 resistors, measure/ replace capacitors, examine the socket and solder joints there.
If I were in that position I would then turn the amp upside down, ensuring that it was stable and could not topple and then, with those two valves still out, I would switch the amp ON and tap Valve 8 socket, pin/wire side, with a drumstick, sockets do go faulty.
I'm not suggesting that you should do this of course.
I still think you should pull all the valves prior to the mixer and see if Mr Mixer is culpable. V1 - V7 - GONE. Better make sure you know which ones go where, I can only count to five before the intense desire to start juggling them kicks in.
All the best.
I guess the one that respectfully declined is Tubenit. That's just the way he is. He would never tell you to go to hell, or even express that about you when talking to someone else.
So that leaves me as the accused one that stated you should go to hell??? Well, I'm surprised you got that from my short, direct response to your PM request. Maybe you're just lying about that part. In my defense I'll just quote our entire PM conversation...
Hi Sluckey,
I sent Tubenit a pm asking if he'd be willing to look over my schematic if he thought he might be able to shed some light for me. He recommended I ask you.
My amp tech has been less and less apt to get back to me in the last few months. He has cancer, doesn't eat or sleep much. (He also smokes a lot ) I worry about him all the time. I thought it might be time to get a fresh outlook on this, so I came here.
I don't want to give you a sob story, I just would like to ask you if you'd be interested in seeing what's actually under the hood of this thing. Questions like, am I asking too much from my PT?, and, is the 6AU6 introducing oscillation because of its design characteristics? are some of my main concerns.
Of course, as I've mentioned, I'm still very green. About 1 and a half years experience is nothing, in the grand scheme. I try my best, I have good fabrication skills and hands, I am a quick learner and all, but I have a looong way to go.
I mean no disrespect at all withholding information that would surely expedite this resolution that will surely come eventually. These are his wishes, and I owe it all to him, I'm just being honest and trying my best to keep my word. On that note, if you agree to look over the schematic, all I ask is that you please just keep it to yourself.
I know there are a lot of very trustworthy and super knowledgeable people on here, and I'm ready to expand my horizons. I'm in this for the long haul, I just starting out is all.
Thank you in advance, I look forward to hearing from you. All the best!
Chris
And I quickly replied...
I do this stuff as a hobby. But I only do it in the open forum.
You have asked this public forum to help you, but you can't provide the single most important piece of info that might fix this Rube. Without a schematic, everyone would only be making wild ass guesses and blindly shooting in the dark. When PRR says "I dunno what to say. Not even where to start.", that pretty much sums it up.
I think you may have to fix it yourself. I suggest you put on a blindfold and start probing.
Chris,
Sluckey has been one of the most generous and gracious individuals on the forum in helping others. He is superb! I consider him a friend and he has extended a remarkable kindness to me personally for yrs over this forum (and in person when I met him once)
He easily holds the record for helping me with both real (within normal limits) challenges in amp building and finding my total goof ball mistakes. Sluckey has always been forebearing and patient with me.
Conveying that he politely told you to "go to hell" just doesn't fit who Sluckey is or the generousity of his time, help and information.
A number of us have commented on the extreme and even severe difficulty in helping you without a schematic. And we've supported you keeping your word to not share the schematic.
The norm is people post schematics and as a community we try to help the poster. You've asked something extraordinary in wanting help within the confines of no schematic.
You've excercised limits in what you can bring to the table so how about honoring the limits that others bring in what they will or will not bring to the table?
I suggested you contact Sluckey because he is waaaaayyyyyyyyy smarter than I am and I wasn't sure I could help even with a schematic.
It is perfectly reasonable and appropriate if Sluckey sets limits for private help & is willing to only help thru a community effort. That's his choice and I don't think he should be portrayed as being unkind for a very reasonable and legitimate choice.
That's not telling you "go to hell". :laugh:
All of what Tubenit said in his last post IMO is right on the money. Sluckey just want's everyone here to benefit as a group and that's more than fair.
You have 29 knobs and 15 switches on that amp and you say;
So the guys are confused because they need a road map for the 4 miles of wire and component connections in your build? :w2:
Sorry but you painted yourself into a corner with your guru. I don't see how it's fair to ask help with fixing a top secret design that has 29 knobs, 15 switches with out a schematic.
And they still tried to help you.
Brad :l2:
Hi MAB, "PLEASE HELP ME WITH MY CREATION" is your REQUEST of this FORUM and HELP is here to be given.
I will not RANT at you as I am not I a position to do so, I am a carpenter with NO electronic training at all but I have a passion for music and old electronic stuff and this is my driving force behind my "cupboard of it almost worked" builds.
There is a lot of stuff in there because the builds I have been doing are usually bits and pieces of other amps that are CUT and PASTED to make a SCHEMATIC and me thinking that this will work :dontknow:
I was pointed in the direction of this forum by the guy's at TUBEDEPOT and I have never look back.
After being on this forum for a some years now some of my creations are still not flying but the one thing that stands out is that with EVERY build that I do I am getting closer to the "ONE" the "ONE" being the amp that will make my CRAPPY guitar playing sound as good as my FAV player, Mr. Gary Moore.
When you talk you leave me :w2: because you sound like you have a good grasp on this electronic stuff, far more than i'll ever have.
You are lucky the have this guy to bounce stuff off and to have a PLAN for the "ONE" and I assume that this is the "ONE".
DO you PLAY guitar??????
You are the one that is outlaying the money and time to this amp and if you play guitar you really should be building or learning to build the amp that will serve you and perform to YOUR needs!!!
I have built some of the creations born on this FORUM and once built they sounded great BUT they were not to MY liking or style of playing. I was not bummed by this as these builds are a platform for other builds not only when it comes to the actual circuit but EVERYTHING that goes into building VALVE AMPS and there is a lot.
AS for your SCHEMATIC, I too believe that it should be kept under wraps as requested by your friend. You just might hold the secret that puts the amp building world on its ASS (Please don't that that comment as being derogatory)
AS I said I pick parts from other amp builders (mainstream builders Marshall, fender etc.....) because they work but by plugging each bit together doesn't mean it will work without some considerations and what they are depends on everything :think1:
I even looked at some local builders as their builds relied on what parts were on hand and some ideas they had were really OUT OF THE BOX or were they :dontknow:
What I am getting at is that i'm sorry if I say the wrong thing but I don't think that what you have on paper is in any way NEW, VALVES have been around for a very long time and it think that they have been USED AND ABSUED in every way possible.
This is what you should DO,strip it back to a basic amp with preamp(one channel that you are most likely to like and delete any bells and whistles) PI and power amp. This is the basis of all amps and tweak it and play it to see if you like it and if there is no problem then build onto it in stages.
I would think that the base amp is nothing new so posting a schem should be ok if there is a problem.
I wish you luck on this build and I hope YOU get what you want out of it, because this is what we are all here for. :icon_biggrin:
I was looking at your photos and with the amount of shielded wire you are using you could have easily melted the insulation for the inside conductor and it's shorting out to the shield. It has happened before to the best of them.
Does the shield have clear insulation on it or is it bare? If it's bare it could have shorted out something.
Brad :think1:
... We crossed many, MANY things off the list. Again, the amp WORKED, and something has given out or weakened. It's a search party for the faulty component(s), not an erroneous design.
It's very rare for a new build to have any part that "gives out".
I agree at this point with Glennjeff that the problem is probably between the mixer input(s) and the grid of the output tubes. I looked at the "Two-Channel Audio Mixer" in the RCA Tube Manual and note that there is a chance that the way it's connected to the new FX loop may be an issue. Really, the mixer is a little over-built for what you're doing.
As for the spark/pop, you have to assume a stray piece of wire got in somewhere, or there's unintended contact from a high voltage point to a "groundish" voltage.
In a future build you may want to stay away from the Gibson-style shielded wire, as the bare shield offers an excellent opportunity for unintentional short-circuits.
I think you'll also agree that it's easier to visually troubleshoot an amp for a wrong connection (the cause of maybe 90% of new build problems), and make good connections in the first place, if the layout is not so dense in areas.
But before you think I'm jumping on you, I must congratulate you on the fact the amp worked at one time! My first electronics build was an over-complicated distortion pedal that never did make a sound other than motorboating. :l2:
The first words out of my mouth is an apology. Sluckey, I didn't mean to pose you as a bad person at all. I surely wasn't about to call you out as such openly, either. What I got from your "That's too bad" regarding my not having permission to post the schematic as, Ohp, well tough $#*&, kid. Your quick, short response to my email also felt very sour. This is how I came up with what I said, judging by my intuition, and reading between the lines as they say.
Suggesting I put on a blindfold and start probing is pretty mean, just for the record.
I don't know you, and I may have taken these statements the wrong way, and even way out of context. If I have, I do sincerely apologize. I have certainly made bigger mistakes in my life and unfortunately it wont be the last.
Chris
Brad :l2:
When I said, yes, this is actually simple, I picture it all out in my head easily. I've been dripping sweat and solder over this amp for a while now. I mean no degradation to anyone by saying that! I knew it was going to be taken wrong, and it's completely my fault for wording it that way. Imagine a single channel 50w amp with 5 gain stages. Not too bad, right? Well this one has another preamp shoehorned in there, and you can switch em. A mixer gets them both going simultaneously if you want, and there's an FX loop... And some other crap..
Okay. Its complicated. :lipsrsealed:
I certainly hope I haven't painted myself into a corner, I'm trying to do the exact opposite, break out and get feedback. The little info I've given so far has already gave way to possible anomalies that could be upgraded. ie, the PI being 28% out of whack as previously mentioned.
Timbo, the only reason I have anywhere near the grasp I have on this stuff (And please believe me when I say it is VERY limited) it's because of the man I started interacting with regarding this build. I am beyond grateful, and hope to attain much more knowledge in the very near future. I will not stop working on these things, "hooked" isn't even the term for it anymore!
I have been playing the guitar for JUST shy of 20 years, I'm 32. Going into this project, each preamp channel, and the power amp were prototyped. The pre's were developed, mulled over, messed with, they shocked the shit out of me numerous times because I'm a newb, and I almost killed an ocilloscope with the headstock of my guitar when I let go. They've been played into with a million guitars, out to other power amps and speaker cabs.. That's it, I'm going to post pics.
I finally got my million dollar sound. MY sound, to MY ears. It's in the top row of this amp, and I cant wait to show it to everyone. The bottom row, is amazing also. Voicing is different, spectrum & versatility is in a totally different direction than the other. This is what MY ears told me, this is when I said, "OK, we have a final schematic for this bad boy."
And I never would have gotten to where this thing is, without help, and extreme determination.
So Meat_And_Beer
Have you pulled tubes 1 to 7 and tested the sound yet.
Given that you have most inadvisably had the shit shocked out of you on a number of occasions I take you have learned safe operating procedure. Oh, by the way, you have to be careful with older tech oscilloscopes, they have a floating ground so if you have the test lead ground at a point on the amp that is high tension, you can get shocked by touching the oscilloscope.
NEVER work on the amp with a guitar strapped on - NOT EVER.
Hi Glennjeff!
I just pulled all tubes before the phase inverter. Leaving in the PI, FX loop, 5U4 and 2x 6L6. The unstable ground swirl is still there. Engaging the FX loop actually gets rid of it to a degree, but it still exists, but in a much more minor degree.
With FX tube pulled and FX loop switched off, it's still there in the "minor degree" present. With it switched to "on", there is nothing. Though, I could only assume that to happen anyway.
:icon_biggrin: Yes, I have learned and re-learned the safe practices in these big voltage meanies. Thing is, when you learn something, it really takes it coming into actual reality why you should remember it in the first place! Or conversely, (Hopefully) just a reminder. The headstock almost into the scope incident was a first time learning for me... I didn't factor in that my hand on the strings connected me to ground. The "One hand rule" was out the window, little did my other hand know....
I like your last line!
So Meat_And_Beer
In other business, I mentioned earlier, accusing the mixer. At work, of course, I was thinking about it all night. As well the post from SilverFox because that was excellent, and makes me chuckle just thinking about it..
A previous test previously mentioned, If I feed stage ONE to a known good amp. I hear the unhappiness of something somewhere. Now that is without disconnecting coupling caps or supply's. If I get unhappiness from stage one, and also so from the mixer, then I suspect anything from either channel, stage 1 and beyond to the PI. But c'mon!
WHAT could be cross-talking/leaking signal/causing ground insanity. :BangHead:
Great, we've made some progress. This is a pretty sure sign that there is something wrong in either FX, PI, PA or PS.
Leave all preamp tubes out and fix the problem as it now exists and you may be in luck.
Remove the cables that "sent to" and "receive from" the FX loop from the main circuit board, remove the FX tube and make a jumper from the board between "send to" and receive from", in other words temporarily get the FX circuitry out of the way, as if it was never there. Then retest.
I am assuming that the signal goes to FX before it goes to PI. It would be really weird to have the FX send after the PI. If the FX is after the PI, which your description kind of implies, then get back to us before you try that.
As promised, here is the mixer CKT. I'm tired. But, tomorrow is amp day for me.
Not mean. Just plain stupid. How in the world could you possibly work on a complicated piece of gear that you cannot see?
Oh wait a minute. That's what you asked the forum to do!
Chris,
Sluckey is a very good hearted guy and you significantly misunderstood him. He is not unkind, just straightforward.
Regarding your mixer ........................
I've never seen anything like that before. IF you had given me the entire schematic, I think I would be at a loss to know whether something was designed correctly or not.
Try this ................... use two 470k mixing resistors as a way to mix those two channels and bypass the "mixing tube".
See if that resolves the problem. IF it does, then the issue is the mixing tube.
I hadn't either, and had to look twice at it because I expected something different. What I think I see is a fixed-bias unity-gain mixer, using the grids of a dual-triode to isolate the two input circuits while mixing their outputs at the shared plate load.
But... if that is correct, then there should be no bypass cap across the 47kΩ cathode resistor; that's because the only valid reason to make that resistor so large is to insure the mixer provides a gain of just less than 1, or said another way a stage that only mixes.
What I thought you referred to was the below circuit from the RCA tube manual. It is cathode-biased and uses the grids of a dual-triode to keep the two input channels from interacting. However it uses resistive mixing at the output. Like Tubenit showed, you could skip all that and just use the resistive mixing, which is the approach used in the overwhelming majority of guitar amps.
In the end, at least this mixer may be "too clever," as a lot of unnecessary parts are present providing many extra opportunities for something to go wrong.
I didn't have any mixing resistors, so I just tried the regular kind... :m4
It didn't help us, but I thought that was an excellent idea, thanks for the suggestion!
That figures, about the mixer ckt being alien to you guys. This was one of those things where you have an idea, ponder it, and when you wake up the next day the answer pops up. (Origin of this ckt)
I believe that is what I saw in the tube manual, I was just flipping through the different schems one day and remembered seeing it. And it would also figure it's nothing like this one, what do I know?
I keep trying to remember why exactly we tacked that bypass cap and additional r on the cathode resistor... But I can not, and it was a while ago.
I have tried jumping straight from the mixer to the PI and pulling the FX tube, no change. We also have solidified the PA and PI as known good. I swapped every single filter and decoupling cap on the supply with known good ones, one at a time. Nothing changed there either. Good thought though, for sure. It took me a LONG time to convince myself that the FX loop wasn't the issue. I've proved it's kosher time and time again, but I still glare at it suspiciously on occasion. Well, I do that to a lot of things in there now...
I'm going to try to pull power supplies to all stages of channel 2 and see where that leaves channel 1. If that doesn't help, I'll try the other.
Brad :think1:
I thought this was right up my alley. I poked around for continuity to the chassis where there really should be none... and I think you're on to something.
The shield is bare, and where it gets close to things I don't want it to touch I shrink tube it, or solder it somewhere for stability. I also tried to supply all of them, as one, to ONE main entry to the buss bar.
Is anyone thinking ground loop problems with this?
Brad :think1:
Possibly, although the amp has worked before. That is an awful lot of bare shielding which means a lot of opportunity for something to go wrong/start touching. I'm 100% positive your amp friend has forgotten more than I'll ever know, but I'm surprised he let you use bare shielded wire. I know just enough to know I could never get away with it. ;) Those are also an awful lot of pots and switches to go dodgy or pick up stray noise.
Oh, and dude... your avatar is freaking me out. *shudder*
Better? I guess sheetrock screw skull head guy is pretty aggressive looking. He was smiling though. :icon_biggrin:
My amp guy was the one who suggested this wire. I don't think he quite anticipated me using this much of it though...
The amp DID work before. Since then, my hands have been slapping the inside of this thing silly, anything could have happened by now.
Hey, guess what I have... A stupid question. I try to limit these, and find out the answer myself elsewhere, but I cant seem to get a solid yes or no.
Should my OT primaries have continuity to chassis? Of course the common should, but if so, I completely don't get how that would even work..
Not quitting the day job any time soon.
No.
The OT primary winding has a center-tap that should go to a high-voltage point in your B+ rail. The ends of the primary winding go to either side of the push-pull output stage.
If there was continuity to the chassis, then you'd either be shorting the B+ rail to ground (if the chassis is firmly bonded to ground), or placing high voltage on the metal chassis (if the chassis is not firmly bonded to ground). Either one is bad, for different reasons.
Thank you John.
Better?
Yes.
Brad :laugh:
No.
Good, it does all that. I'm stupid and asked the wrong question then. :rolleyes:
It's the multi-taps out to speakers. 4 ohm, 8 ohm, etc. Why would there be the common for the - signal, and the same common be riding on the + signal to the speakers??
Your OT primary may be 100-200Ω typically from center-tap to either end. The OT secondary from common to 16Ω tap might only be a few ohms. Therefore, you will get continuity from the highest impedance tap to the chassis, where the common is grounded.
"Continuity" for most meters does not mean "0Ω" but maybe something more like "less than 100Ω". Or whatever resistance the manufacturer decided represented "substantially connected."
Interesting creation meat and beer. I can appreciate that you are chasing the tone you ultimately want. And that you started out with circuits building blocks that others designed (i.e. Engl and BK Butler). And can appreciate you have given your word on the schematic thing. However...(FWIW), unless a 'guru' goes by the initials HAD or is or planning to market this secret sauce circuit to the world for livelihood, it doesn't make a lot of sense to horde good knowledge--eventually it will get out and the guru will likely be forever known as selfish/self-serving. Honorable grandmasters of tube amplification shared their 'secrets' with the those worthy of the knowledge (though I could be wrong and often am) and I know of no members of this forum that have built empires from any secret sauces shared freely here. But everyone has their reasons...so I will not judge but only offer a thought.
I have read and reread this thread several times and offer another thought--since your amp worked up to the time of the final FX modification, logically it makes sense to retrace everything subsequent to that mod. BUT since you have been in and out of the chassis as many times as you indicate, and no progress is being made yet, I humbly suggest that you take an afternoon or evening and thoroughly visually check EVERY SINGLE solder joint and reflow ANY that even look remotely suspicious--you will probably have to cut most of your cable ties to get down a level or two. I have had at least two builds in recent memory that cursory inspection looked good and the amp worked but 'not quite right' and there was a fluctuating measurement and sound. The culprit was only as simple as a solder joint. Again, even if you are experienced wielding a solder iron, there are a lot of connections here in your build so the potential is there.
Again, for a relatively new amp builder, nice effort! Regards
dennis
Thanks Dennis!
Of course, I have found one cold solder joint about 2 weeks ago. Was that the only one? Ppphhhsssssshhhhh.. Probably not!
The things that are iffy to me, is when I rotate the 1st stage tube in its socket for either channel, a LOT of fluctuation/noise comes about. Sometimes it'll sit there sounding cruddy, and I'll poke it so it sits in a microscopically different position, and the cruddy-ness disappears. I have re-flowed these solder joints, and I have cleaned all pin holders with deoxit. I cant get in there to tension them though... They were new when I purchased them at the beginning of the build. Make no difference their age? Thoughts on that?
I tried Willabe's idea concerning all the shielded madness. I found no continuities to ground on the center wire. Excellent idea, I was hopeful on that one!
I removed power supplies for each channel and their tubes. No effect removing channel 2 and listening to channel 1... The other way around seems to make a big improvement, but it was still there. And the issue of it's (Channel 2) second tone networks treble was still acting up. (At zero, its fine, as you bring it up, treble increases, but volume decreases.)
hhoooooo boy.
So I'm finishing up the updates & cleaning up on a very large schematic in photoshop. I'll plunk her up here after dinner tonight.
It is very unfortunate I have left a sour taste to many people by not releasing it. I was trying to first see if anything could come from my very lengthy information intro, and subsequent tests. I'm hoping after it's up later, all the animosity will disappear. Just trying to be a man of my word, I know most of you can respect that. And I do trust you guys, I've been following for a while, I see your tight knit community! It's just that when you put something on the internet, even momentarily, it is forever on the internet.
Chris
actually, the Sound City L/B100 mixes the two 1st stage preamps in a VERY similar fashion
You mean the input jack going to both pre's at once? I tried a pickup selector at first to switch one, the other, or both. But there was too much capacitive coupling in the switch because of sheer proximity so they were both always getting signal for the most part. Shunting the signal at the end works fabulously.
Wish I never got rid of my Sound City. I was a kid, and I thought it was just too loud! Silly kids. Practically gave it away too...
So, a pretty interesting thing just unfolded here at the broken amp camp.
I was plucking the twanger (On gear that works..) and a chord was ringing out into silence. In the very lowness of it, before my noise gate stood in the way and put up its wall, my head snapped toward the speaker cabinet...
...The "ground swirl"...
It's my friggen guitar! I only have 5 of them, could I possibly be bothered to pick up a different one once in a while??? Not when it's always been sitting right next to me at the table, I guess.
I recently told the story of about 6 months or so ago I got whacked and let loose of my guitar almost spearing an o-scope screen. It really hurt, but it also fried my bridge pickup. I installed a new one probably a few months after. Must be I have some work to do in there, because its the cause of (most of) the ground swirl I hear.
This does not by any means fix my amp, but it certainly chilled it out a bit. I can still hear cruddiness there, but it sounds more to me like RF, and a tad of motorboat action.
Time to break out the scope and kill all unwanted upper kHz once and for all. I think that control on the cathode of V6 is contributing to some, if not all of the boating. Anyone seen anything like that little circuit jem? It's original to the BK Butler that the stage was adapted from. Any foreseeable improvements that won't overly affect its desired effect?
It's a bit hard to read the schematic, but better than nothing... V6 seems to have
positive feedback phase cancellation, was that the intention? Or may be I got my eyes crossed trying to follow the wiring :icon_biggrin: Also, could you please summarize in one sentence what is the current status with the amp, this thread is a bit hard to follow with so many changes and suggestions made...
I also have each individual stage/ckt as its own sheet of paper that is much easier to read, this is the whole layout as is. If anyone want's a section up that's much clearer, just give me a shout.
The schematic does not reflect 22pf caps that now exist between the grid and plates of V1a, and V4a.
Problem summary;
Both channels have what seems to be rf/slight motorboating.
Channel 1 has a signal riding/coupling on it that makes the desired signal sound terrible. The 250k pot (p13) at the input of stage 3 / V6a can be turned all the way down, and you can hear just this unwanted hitchhiker. As you bring it up, the good signal comes in, but cluttered with the undesired one. (This issue exists from beginning to end of the preamp, it's just most obvious here.)
Channel 2 has its problem with the "bias" control at the cathode of V6. (Lin taper) It's boating a bit. Its 2nd tone net off the plate of V6 has the treble control issue. It's the 500k with a 220k resistor across it, P15. All the way down, volume is good. Turn it up, treble increases, but volume decreases.
Sorry, a bit more than one sentence was needed... But that's about it in a nutshell. Other than that, its just happy tweaking!
Happy Fathers Day, gentlemen!
Sorry I just can't make out the parts that you mentioned, but it seems that the descriptions of Channel 1 & 2 were flipped in your latest post - just to confirm Channel 1 is the top row and Channel 2 the bottom row, right? May be you can highlight the section that you are having problem with, on the large schematic above. We'll help you get to the bottom of this eventually, but I suspect there are feedback loops from either mis-wiring or parasitic coupling given such complex build.
Hi Jazbo8,
I made a mistake, it's V6 that has the "bias control" on it's cathode with the motorboating problems. I said V5, sorry my mistake! Ever since I had to divide one 12ax7 into two 6av6's, the V's have thrown me off. (Cross-talk elimination) Everything's correct on the 'matics that I've provided here, I just slip up every once in a while.
Yes, Channel 1 is on top, channel 2 is on bottom.
I really don't think it's a wiring error, this amp was working. (I could, and always can be, wrong though) It indeed is a coupling that is happening somewhere. I suspected the fx loop switch, because it has some lengthy cabling attached to it, and large signals like to couple at those points. Also a concern for probability to me, was the "plexi mode" switch, for the same reasons. I've tried bypassing these with no luck so far...
I'll remind you I went through great lengths to electrostatically shield all cross-talking components. I had them playing together very nicely. Switches are my next suspicions.
I'll highlight and re-upload a new schematic and replace the above one. Attached here is JUST last stage of channel 2. Motorboating bias control, misbehaving treble control. (There were not an issue before, they're known good, but the bias ckt is known to be fussy with placement.)
Would you be able to post a link to some recordings of what the amp sounded like prior to developing the problem? The circuit looks fascinating and I'd like to hear what came of the development effort.
I've considered using a tube mixer on, I believe it was a Plexi with two input tubes ultimately driving the power amp.
Glad to hear you have a decent Mentor. They're very hard to find nowadays... Fortunately the Internet just about makes them obsolete and where it doesn't, you have so many smart people it's possible to burn through them faster than they can indigestate, (coined phrase), on you. The collective knowledge of the machine is superior to machinations and you don't get the personality disorders associated with inflated egos. Doesn't sound like you've ever had to deal with that yet. But I digress; really interested in hearing the original amp as it may provide a clue.
I'd also be interested in hearing you play if. Your earlier post regarding signal processing for live performance says a lot. Here's a link to something I threw together for the guys here kinda quick so excuse the any rasp in the tune; clik the X to get rid of the kitty ad and you'll see the player. http://mergatroid.minus.com/ldR28YJcsY3Z0 (http://mergatroid.minus.com/ldR28YJcsY3Z0)
Fox.
Thanks for uploading the Channel 2 V6 picture, so what I thought was phase cancellation turned out to be just crossed wires when viewed on the large schematic... So this is a pretty standard gain stage - just curious why do you load both stages so heavily? 10k is a tough load, and the small slope resistor on the tonestack is better handled by the cathode follower IMO. The bias adjustment creates a pretty good size peak at LF when dialed down, perhaps that contributes to the motor-boating or instability on the low end? 2) did you check the treble pot to see if it is functional, it should not interact much with the volume control. And did you try bypass the whole fx section?
Jaz
Silverfox;
Right now my studio computer is 100% disassembled, we're moving at the end of the month. (I use ProTools for some asinine reason, it's an involved setup.) I only have two recordings of the amp when it was functional to speak of, really. The 1st one is when it was in the proto chassis, and I was using a parametric EQ to find exactly where a certain harmonic distortion/clipping was so I could smooth it out in the future.
The second is when I got the thing at it's best it's been in the real build. For some reason, I didn't save the session (All individual clips in a multitrack), I just saved the entire mixed down clip. It has about 3 or 4 harmonies and drums. This disappoints me because I was later trying to listen to JUST one track without all the others. I don't think I saved any of it, it was a quick demo for a friend down in RI, kind of just a "Check this out!" clip.
Both are of Channel 1, my favorite. I haven't had time to go through the entire amp as a play-through/demo yet, I planned on it after it's totally happy with itself.
I also have the feeling that the music I mostly play and listen to isn't very popular around here. (Tends to be hard, fast, and melodic)
You can check out a cover I did of Elton's Crocodile Rock here if you'd like:
Elton John Crocodile Rock cover... Metal punk style! (http://www.youtube.com/watch?v=BwsB0fSIEu4#)
YouTube does a good job of swashing the life out of audio unfortunately.
I can provide a link to the project I had while living in RI with just a bassist. Some track titles aren't the cutest... I recorded, mixed, edited, all that stuff, all these songs. (There are no vocals, it's just music)
When my amp tech/teacher and I were first getting acquainted, he was also curious as to the music I played. I gave him a CD. And I quote, "Woah, way to knock us back into our wheelchairs!" That's the best indication I can supply. ;)
http://www.reverbnation.com/retox666/song/11698858-bar-fight-of-the-gods-pt-i (http://www.reverbnation.com/retox666/song/11698858-bar-fight-of-the-gods-pt-i)
I really like the character of the rhythm guitar in that track you posted! The lead tone sounds very relaxing also. Nice work!
I can't wait to demo this amp, there is truly something for everyone in it.
No problem! Say the word, and I'll post a closeup of whatever is in question.
In regards to the slope resistor, The value choice was a mix between the original schematic and my tech's math. Should I try something more in the realm of 56k? It does have massive bass... pretty much everywhere. (It can always be toned down with the knob, of course) Reason being is this amp could double as a bass amp. It does go VERY low if you want it... I can even get my 2x12 with V30's to "woof". Normally this is a very mid/bright sounding cab with my other gear.
As to the heavy loading 10k's, this is getting into where I'm limited in my knowledge. I don't know. :dontknow:
I re-situated the wiring pertaining to the bias control, it got me no joy. Should I adjust the 10k across the 22uf cap? I tried all sorts of different values for the cap, this is my favorite one, I'd rather not change that value if at all possible. But I'm up for anything that might sink this motoring boat.
Yes, the treble still squashes the output volume. I did try bypassing the FX loop, I jumped straight from the mixer tube out to the phase inverter and pulled the FX tube. No change. I still feel like there might be something I'm missing on that topic though. Something is evading me...
Little amp gremlin rascals... I'll get you!
Yes, I hate it when the amp worked before then just quits, then it is always something simple that botch things up, but finding it is usually not... Anyway, I don't think you should be changing any parts just yet, you got to find the root cause first. Your amp looks very well build with neat wiring and shielding, but it still does not hurt to chopstick around all the solder joints and move the wires around a bit to see if you can get the RF/motorboating to change pitch or amplitude, so at least you can isolate the trouble spots. Sorry couldn't be more help now...
What is this? It strongly resembles circuits which are notoriously unstable.
Since the amp worked before, it may not be an issue. OTOH it may be a lurking snake. And always possible it *wasn't* wired this way, one of your fixes "fixed" it, and it bit you.
PRR,
This is actually note for note the BK butler preamp, looks like we didn't actually change one component in there. Except, the bias cap, and additional 100pf across the plates. I actually own the actual unit as well. It's plates are getting something insane, like 13 or so volts. Mine gets +/- 60v at the socket.
This schem I'm providing is from Genz Benz, the now owner of Tube Works/BK Butler stuff. (It was emailed directly to me from them, not sourced from the net.) I had a different schem that was VERY similar, and the value of the cap on the similar one was the 22uf value that I preferred much more than the 4.7, and everything in between that I tried.
Notoriously unstable? Please, sir, do go on!
Jaz,
I've poked around with a skewer so much in this thing, it finally broke the other day! The motorboat got substantially more stable when I re-situated it's pot ground to the buss bar. Is there a possibility that when this gets really "fixed", that the treble pot will stop acting up? This has never been an issue for me, super strange. The treble, that is. I'm not really sure how I can go about addressing that. Parasitic oscillation...
What are some things that could be causing this?
-Lead dress/length
-solder joints
-what else?
So can it be said that we don't suspect any components have gone bad? Caps are 600v or more, and 1/2 watt resistors. Should be MORE than hearty enough I would think!
I got tired of thinking about it, and I pulled the BK out of the rack and started probing around in it.
Plates (In the actual, purchasable unit) are 11v.
(I've been very curious about this part) When "bias" is at zero, plate volts are 11. Turn bias all the way up, plate volts turn to about 2.5. This really freaked me out when I couldn't figure out why the supply in my amp was all over the place. Stupid knob! Glad to know its inherent in the circuit at least.
The components in the cathode bias network are indeed what is indicated on the actual BK schematic. Why then, when I auditioned caps for this, was I getting nowhere near the effect like it has in the actual pre? They (Bias knob) now behave identical... (Real BK Vs. mine, when my amp is having a good day.)
I'll set it aside while it's opened up for now. Any other things anyone would like to know about it? I'm not a whiz at PCB tracing, and it's dual layered too.
Now that we know where the inspiration for the circuit came from, some comments on its design - the Butler was designed as a stompbox (although a rack version is available), it is a starved-plate design and runs off +-12V, so when you use the same values as the original, it would not work the same way. Anyway I think the schematic contains an error, the 10k resistors should form a simple voltage divider. The way is drawn on your schematics now, there is no attenuation - not that it matters much since it should not be the cause of the RF and motor-boating. To make sure, you can always bypass the stage. BTW, have you pulled the tubes back from the power amp and find out where the RF/motor-boating starts?
The unit in discussion is indeed the rack version, the RT-902. The (Partial) schematic I supplied is for the rack version.
The motorboating is on the bias control, I'm sure of it. Been there with the prototype. Channel 1 has no motorboating anywhere, but it has the same RF characteristics as does channel 1. I've pulled lots of tubes, searching...
Would it be helpful if I made a video for first hand action and explanation of exactly whats going on? Sort of like a hearing the words, and also being able to watch the lips move type of thing? I have just enough gear NOT yet packed up to be able to do that. I think I'm going to. I'll try to get to it very soon, within the next day or two.
I am sure we can get rid of the motor-boat problem by adjusting some of the parts in V6, so look on the bright side, now it is just a matter of tracking down the RF problem (very likely some HF oscillation), then you are set.
Do you have a recommendation as to where to start adjusting?
Would there be any adverse effects if I were to put a 22pf across the plate and grid of each preamp triode in there? Or do they need to be strategic? I haven't checked, but my instinct tells me that even if there is the 22pf in a stage, thereby not able to feed HF the next, it doesn't mean the next stage can't "hear" as high/fast just because the signal is being fed to it by something that is no longer able to.
Is that acceptable logic? I would think I want to 'limit' at least the first two or three stages in there.
First can you please verify if what I said was correct, can you control the amount of motor-boating when you turn the bias control? I only did a quick simulation, but it may not be what's causing the problem... Hate to harp on this issue, but if you pull out all the preamp tubes from both channels, leaving in just the mixer, PI and the power tubes, do you still hear the RF? If not, then you can put in one tube/stage at a time until the RF appears, then you know for sure where it started...
Jaz,
Yes, the bias knob was in control of the boating. However, since as previously mentioned, when I re-situated the pots ground, it helped immensely. Before, it would boat, after, I'd hear a "wubb" as I passed about 2 on the pot, if it were labeled 1-10 concentrically. Just now, I don't get the "wubb".
It is acting strange still. At zero and bringing it up, I can hear it increasing the hiss of the amp sharply, then quickly diminishing it before I even get to 12 o'clock.
I did reverse tube plucking as you asked, and it yielded the results I had assumed. V1, and V3 (first two stages of both channels) are the culprits for the dirty noise floor and RF. V1a, V3a, and V3b all have the 22pf grid to plate, and V3 is the worst. Even with having 1st and 2nd stages with this mod as opposed to just the 1st stage of the other.
V3 is channel 1
V1 is channel 2
In conclusion, the amp sounds pretty darn quiet given the settings I have it set at for this test, and with those two tubes pulled.
What is a better way to eliminate RF other than the grid to plate cap I'm doing? It's not all high freq stuff, there's a lot of low garble in there too. I think it's post three I made here in the beginning, the sound clip I attached a link to. It still sounds like that, but not as bad.
It goes to show I've been working on this amp a lot more than I should be paying attention to actually playing the guitar.
When we first determined the value of and implemented this 22pf grid/plate cap, we watched it on the scope. Adjusting the signal generator, at about 15k it would start to roll off, at about 20k the signal had shrank by at least 50%, and continued decreasing on the same curve as K further increased.
Thank you so much for continuing this battle with me, Jaz.
I'm adding a clear shot of stage(s) 1. Both are essentially the same, with some minor variants.
This is channel 2, as is. (Ignore the dotted capacitor on the 1 meg output pot)
For channel 1, subtract the 100pf across the plate resistor. Subtract the 22uf across the cathode resistor. The dotted cap on the 1 meg output pot is a 270pf.
Remember that the input jack goes to one single shared 68K, and then goes to both channel 1 and channel 2 grids of each "stage 1".
You are welcome, I see (sorry if I make you repeat yourself), so it appears that you may have too much gain and/or picking up interference at the first stage for both channels. Some quick things you can try, in no particular order:
- move the 1M grid leak resistor to before the 68k, i.e., it goes between the input pin and ground;
- remove the 22uF cathode bypass capacitors or substitute a smaller one say 1uF, that will knock the gain down for both stages;
- add a capacitor from the input grids to ground, say 100-270pF, this will roll off the HF.
Jaz,
I tacked in an additional 1m to ground, where the 68k, and two inputs for each channel merge. This didn't help with what we're looking for, but man, did it kill some hum! I notice no sonic difference with or without the resistor when playing a chord. (Just a quick test, but I like it! I think it'll stay there.)
I tried a 100pf across the 1m (effectively grid to gnd), no difference. I tried it on the socket to its circuits ground, nope.
Channel 2 still sounds better than 1 with respect to the RF/noise floor. Channel 1 doesn't even have a cathode bypass cap on stage 1, and it's the worst of the two channels.
I made up a little brass shield to go around the input jack and its resistors, giving it its own little grounded hut to live in. But that didn't help either.
Your suggestions were awesome, thanks!
Sorry to hear that you did not get very far, one more thing to check - if the amp is quiet without the guitar plugged in, i.e., both inputs are grounded, and the RF/noise only appears with the guitar plugged in, then I think you simply have too much gain, to verify this, you can bypass some of the stages before the signal hits the mixer to see if the amp quiets down beyond that I am kinda out of ideas...
Reply 86
I think bypassing stages is a really good idea. :think1:
Reply 21 was
Do you know how to safely jumper over sections? IF so, try running V1a directly into the return of the FX. Does that work? Then add V1a & V1b into FX return. Does that work? and so on Your goal by jumpering and bypassing sections is to locate which section creates the problem
This is a bit odd, since Channel 2 has more gain stages than Channel 1 - need to find out why. Also, with the mixer and/or channel volume control you should be able to mute one channel. Doing this should reduce the noise as well. so far, you failed to isolate the source of the noise, until you do that, you are still shooting in the dark... I know how irritating this could be, been there myself a few times, it sure takes all the joy out of amp building :cussing:
Jaz,
The amp sounds the same with or without a guitar plugged in.
They both have 5 gain stages, does a follower/buffer count as a gain stage? I wouldn't have thought that not knowing... But, not only that, stage 2 has cathode bypass caps throughout, channel 1 does not have a single one. A real nice comparison can be done on this amp in that both of their 1st stages are the same, (MOSTLY) aside from that cap. What I noted, is that a stage with a cathode cap has about 8 divisions higher gain than one without, seen with a scope. What is HEARD, is super different, also. And I, personally, am in love with that sound.
I am not opposed to lessening the gain on stage two, as it is a ravenous monster. But it's pretty cool. :m11 Stage one on the other hand, has just enough gain to my ears. I would weep if I had to tone that one down!
Tubenit,
I will definitely try the jumping. Why didn't I already?!?! I remember now, and it's just a bunch of excuses. I'm gonna dig into it. It may be a bit before I can give a solid progress report on this one... Empty boxes awaiting filling are my eminent destiny... :sad2:
Gentlemen, I thank you very much for your support and efforts.
Chris,
Just some thoughts for you.
I've done over 20 different builds that weren't clones and were somewhat quasi/pseudo kinda sorta "original" designs. What that translates to actually is that I've simply repackaged ideas and innovation of other people meaning nothing I have done has been truly original. Even when I "came up with an original idea", ........ I learned later that someone else had done it.
I've tried ALOT of different stuff and spent 100's of hours experimenting.
There have been a couple of builds that I gave up on and cut my losses cause " I couldn't get there from here". I scrapped those builds and used the trannies, pots and chassis to start over. I think Geezer (who is better at this then I'll ever be & is perhaps the king of innovation here) has gone thru that a couple of times. I view failure as part of the process to success.
Based on what I've been thru, I'll offer four thoughts:
1) I don't think you need 5 gain stages and I don't think a 5th gain stage is going to offer anything special. In fact, I think you will find
it to have diminishing returns & create unwanted noise/hiss that is not useable.
2) High gain amps need to have a very careful layout. Without a good layout and grounding, you're going to have oscillation problems.
You have a quasi point to point & layout board hybrid.
3) You have stated repeatedly that the amp worked and sounded incredibly great prior to modding it some more. IF that is truly the case,
why in the world wouldn't you go back to that? It is bewildering to me that you won't return to something that you viewed as true
success?
4) IF you have created something that leaves these forum guys stumped in trying to help you, then I will argue it is too complicated to be
truly be useful to you. My guess is that you have a design flaw in the approach that you will not resolve without retracing your steps
back to what previously worked.
My two cents. With respect, Tubenit
It may be useful to you to look at this high gain amp thread to see what has been done on successful builds:
http://www.el34world.com/Forum/index.php?topic=15622.0 (http://www.el34world.com/Forum/index.php?topic=15622.0)
So both channels has 5-stages, I need to go back and look at the schematic more closely, perhaps I was thrown off by the long wire after the first stage in the top row, I thought you had skip a stage there, anyway, got to head out now, check in with you tomorrow.
I thought that might have been it. Originally there was a weird tone switching circuit that my tech had devised for me. I didn't like it, so it went away leaving a big blank hole in the schematic.
Call me crazy, or thick headed, but I'm still determined. I'll totally admit to being a bit stubborn at times, too. But there is no way I'm turning my back on this build. It will get there, I just still have a lot to learn, and I'm cutting my teeth on an inadvisable first build.
I've got RF/ground issues with the fist stages, two post that are oscillating is some manner, and a coupled signal.
That's a short sentence. I'll get there! :icon_biggrin:
I jumped stage one from channel 2 straight to the PI. It's very clean, other than a slight overdriven/buzzy sound at all volumes on the pot.
(Link to sound clip provided below)
What is it? I'll tell you, and I'm very happy to have found this out. If I turn the volume down on the guitar a bit, it goes away. I use active pickups for the most part. When we drafted this, I guess that 1st 68k resistor it hits isn't enough.
I brought the volume on the guitar down to where the buzz went away and it was fully clean. I pulled the cavity cover off my guitar and read the pot. With respect to ground on the wiper, its 4.8k. Wiper to lug 1 is 17k (Which is the number I want, I think...) It's a 25k pot.
What does my 1st resistor now want to be? Is it additive? Whatever the common resistor is around the 85k area?
I could add an active/passive switch... Yay more switches!!! :) (Kidding)
So that rules out stage 1 channel 2. (Right?) I'll later check out its stage 2. I have a suspicion of a certain switch that's coming up real soon in the circuit...
Thanks, Tubenit, for really driving that suggestion home to me, and thanks for being part of my amp diary, fellas. :)
https://soundcloud.com/agormortisrr1/channel-2-stage-1-to-pi
Chris,
Watching this happening. Keep going. Tubenit (Jeff) has some great information and it looks like you are beginning to narrow it down some.
If this is truly your first build, man it sure is industrious. I too have built what I thought was a brand new idea only to find out that it was not new, but you will never get a new design without trying something new.
Get her running and let us hear it scream. :bravo1:
Ed,
Right on man!!!!! Thanks! :)
So a good update, I think I've localized it, For channel two at least. Weather or not channel 1 follows suit in response to the repair, will be seen. (Or, heard?)
From the guitar into stage two of channel two, and out of that stage two to the PI, sounded great. Then I fiddled a bit with what few knobs I had. I'm glad I still have commendable hearing, because what my ears picked up was a very high frequency. But that's all I noticed, none of the garbley mess that's associated with when I plug a guitar into the thing.
This stage does not yet have the 22pf plate to grid HF roll off cap.. So I looked more. There are probably 4 wires in this amp that carry signal that are not shielded at this point. Two of them were right there at this juncture... I combined stages 1 and 2 and sent them to the PI. The garble appeared, but distantly.
So I shielded the two wires, one about 1" long, and another about 1 3/4" long. (First two stages in an amp on steroids, not taking a chance any more.) and installed the HF cap.
Sounds better! But, it was still there. Remember me saying...
The switch I was talking about was the "Plexi mode" switch. You can see it on the big schematic I provided, it sends stage two directly to the PI. With the Plexi switch off, I hear it, plexi on, it's gone! When switched on, the 1st stage volume can be about 11 or 12 o'clock and I wont hear it. As it's brought past that, it comes on like the dickens.
Which brings me to a question I've been wondering for a while, why hasn't anyone busted me on my switches not going to ground when not in use/bypassed? Bust my chops, people! I really am still a newbie!
It's either the plexi switch, or the fx loop switch that's coupling. Gotta be, right??? I have seriously tried SO MUCH stuff way before even posting here that I was beginning to rule out the switches/fx loop by default. Nope, I was right in accusing them. The whole loop of stuff got connected when the FX loop was finally incorporated. Bam, instant issue.
I'll get those to shunt what I don't want when de-selected, and see what's what.
success?
Tubenit, I'd love to answer you on this. I mentioned somewhere in this thread that I have in fact, tried to reverse the FX loop finalization mod. I didn't have success, but I at the same time didn't want to go too nuts looking to do so anyway. (I must've been one try away or something, because I literally feel like I tried everything!) All of these effects/bonuses/tricks are in there to stay, and I knew there was a way to make them all work and be friends. In the back of my mind, I knew it was going to be this.
I needed a systematic way of smoking it out. And as simple as it sounds to most on here, the "Logical Blocks" that Glenjeff brought up long ago, then Tubenit and Jazbo8 reinforcing the zeroing in by way of stage by stage, finally clicked for me to not be so dumb.
This forum post has been my "diary", a much better one than I've been actually notating previously. Thanks for your patience folks, I did have a motive in my head.
I have a couple other ideas, but I don't want to diminish the gain that channel 2 stages 1&2 have because that will adversely affect the "plexi mode". Aside from that, it's past my bedtime! I had to get all of this out and onto the table.
Thanks everyone, good night.
The switch I was talking about was the "Plexi mode" switch. You can see it on the big schematic I provided, it sends stage two directly to ANOTHER switch (FX loop on/off) and then to the PI. With the Plexi switch off, I hear it, plexi on, it's gone! When switched on, the 1st stage volume can be about 11 or 12 o'clock and I wont hear it. As it's brought past that, it comes on like the dickens.
It seems like you are finally getting somewhere... from the big schematic I can make out a DPDT switch, that bypasses everything, and sends the output from the second gain stage of Channel 2 directly to the PI, so is this what you mean by Plexi OFF? If so, the problem is kinda odd, since you have a lot less gain stages adding noise in this mode.
As for grounding the switches, I see with the Plexi switch OFF (if I read it correctly), the input of stage 3 in Channel 2 isn't grounded, but since the switch bypasses everything after that, it should not matter, of course, it would not hurt to ground it.
Also you are saying, with the Plexi switch ON and turning Channel 1's volume pass 11 O'clock, the noise appears, what about Channel 2, does turning it up to 11 O'clock, does the same thing?
Plexi mode switched on sends the end of stage 2 straight to the PI. Switched off, it goes through the rest of the circuit normally.
Okay, so now I'm doubting my previous post. Dodgy amp gremlin crap!
Channel 2, stage 1 only, straight to the PI. I'm listening to it now, it's faint, but the instability is there, and intermittent. When I bring it's only volume pot up, hiss it gets louder, then softer at the very tail. When it gests softer, is where the gross unstable fluctuating sound chimes in. This first stage must've been having a good night last night or something, because I didn't hear it then. :BangHead:
Channel 2, stage 2 only, I just recorded and scrutinized. I killed 60 Hz, and sloped some low end so I could discriminately listen to whats going on in the rest. I really can't hear in there what I can in stage 1. It seems to be ok...
I thought it was the switch, maybe because I wanted to, but stage 1 is the real BS'er here.
I have not checked out channel 1 yet, I was hoping to wrap my head around this channel first, then apply what I've found to the other.
...Also, with the mixer and/or channel volume control you should be able to mute one channel.
Yup, and double yup. I can silence either channel with its final volume, or I can shunt it all together with the channel select rotary knob.
Crunch time for moving... Can't.... put the soldering iron... dddooowwwnwnnnnnnnnnn
Meat_and_Beer you can take your first bypass cap down to 2.2uf instead of 22uf it will help with some of your ocsillation problems it also will tighten it up for any palm muting stuff you might do.
You have a 1k there, At 820 R and 2.2uf your right at 80hrtz which is the bottem E string in standard tuning with 1k and 2.2uf you should be down around a drop D tuning, I could do the math and figure out exsactly were,but thats close enough .
I know engle and a few others use 22uf but they keep a balance in othere area,s . At 22uf you are taking it into the 1 to 2 hrtz range which is lower that your transformer can play . It cause.s instability issues in high gain amps where in lo gain amp's like a classic fender it just makes it sound fuller, even then i never go above 4.7 uf, except when building classic circuits. Im talking strickly the first stage you hit.
You could also go 2.2uf with a 4.7uf on a switch to add extra for bright sounding guitars.
You are wrong about thinking some of these guys wouldnt understand your music I havnt been in a metal band since the early 90,s and yes that makes me old. But there are a few guys here who dable with a high gain build once in a while. We play mostly classic rock now because thats what all are friends play (LOL).
Bill
Bill,
Thanks so much for that informative response! Most of my guitars are in drop C (CGCFAD), one in standard 440, and another in B standard.
I was just hinting/warning that the stuff I play might not be a lot of peoples cup of tea. I was hoping that I was at least semi-wrong about that one. ;) I'll probably soften up as the years go by two, seems to be the trend!
I'll give it a shot today! Lots of stuff going on, but it'll be quick, and I'll report back. Thanks again!
Chris
The closest thing I had was a 4.7uf, so I tacked it in there. No change. (I listened to unmodified just prior)
No bypass cap, no change either...
Man, there is so much I have to learn! The ways to tailor your circuit to your playing/tuning. Even just to get something to end up at precisely the necessary voltage for things...
Jeepers tube amp books are pricey. I feel like I'm in college again!
What this sounds like can be heard here:
https://soundcloud.com/agormortisrr1/horrible-noises/s-oI33f
HOWEVER, it has gotten a bit better. (A bit!) This clip is from the entire channel (Either of the two channels, and it makes no difference weather a guitar is plugged in, or the jack self grounds with no input)
What I'm hearing at the output of just the first stage is nowhere near as nasty in compared to what it sounds like throughout the whole circuit, like the link above. This makes me think two things;
1) Stage 1 is where it is originating from. Given that both channels are ALMOST the same, possibly it's something inherent in design.
(But it never gave me this much crap before... Or much of any crap at all!)
2) It's mechanical. A cold solder/bad ground connection somewhere.
Thoughts? Pointing fingers?
There is definitely RF in there. (But does weak ground cause RF? Does a cold solder, depending on where it is, cause RF?)
With more and more of my test gear getting packed/relocated, I can't tell you exactly what's going on precisely in respect to what frequencies are being allowed in there, and where. I WILL be able to in about a week or two though! To the extent of my ability, that is. Which doesn't TOTALLY suck, at least.... Well, a little.
Thanks for the beautiful support, team!
:thumbsup:
