Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: Toxophilite on January 16, 2014, 02:14:42 am
On my 5F11 Vibrolux build, (the messy point to point one in the small chassis)
I get some high B+ voltages
It's built to the schematic and it has the proper tube compliment for the build all plugged in
THe only changes are a baxandall tone stack and a classic fender 2 input rather than the 3 on the original
At pin 8 of the rectifier I have about 382
at the next cap(after the 470 ohm resistor) I have 380
and on the screens and the plates of the 6V6s 380
the next little node after the 220k resistor and cap I have 299
On my phase inverter I have 247 and 208
and on my preamp 1/2 12AX7 I have - 195
and the tremelo half has - a vacillating voltage around 170 to 235
THese are all around 30-50 over what they should be for the schematic
The amp works well, really quite loud
The tremelo dworks well too
I'm just curious if it could be a problem and what should I do to rectify it?
Just for fun I tried my SS rectifier in there and the B+ at the plates jumped to around 405-407..just like my AB763lite build
This unit has a Hammond transformer that I have the specs for
It's supposed to have 310 on the secondaries but actually reads about 335
This is because of the change in wall current right?
It might be the "wrong" Hammond transformer for this amp .
Or bias is too cold .
Wall outlet ? Just read it . you'll know.
Did you know , If, for same amp you buy 2 differents transformers . One with 310 volts at 70 ma and the other one 310 volts at 120 ma .
You'll have more B+ voltage with the last one.
Secondary voltage is accurate if you use the proper load ( ma )
You really mean 22K, right?
Those voltages look fine. Using a NOS 5Y3 will drop the B+ some, unless you are already using a NOS 5Y3.
Yes. Today's line voltage is about 10 to 12% higher than back in the 1950s. Your B+ is about 12% higher than the old schematic shows.
I understand a new built use a new Hammond PT , Today Hammond PT use today's line voltage . No need to ad 10-15%
Ooops
Yes , you're right
I mean 22K resistor and the Hammond transformers are probably about 60 years old
The PT is a Hammond 272Z60 rated 310-310 secondary volts 70ma
I'm using an old RCA 5Y3
Thanks! I won't worry about it then
All is well
Ooops
Yes , you're right
All is well
Old hammond are made for 110 Vac primary , today with 120 and sometimes more secondary are higher.
If you look again at that catalog download, you'll see the chart with the 272Z60 has a heading that says the primary is 115v.
335v-310v = 25v -> 25v/310v = ~8%
124v-115v = 9v -> 9v / 115v = ~7.8%
I'm guessing your wall voltage is between 124-125vac.
Bonus!
Too bad I don't pay for it here or I'd think I was getting a deal!
