Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: Leevi on February 10, 2014, 11:45:30 pm
The sound is is very weak and it's crackling. I measured the voltages on PI pins 1 and 6.
1: 166v
6: 250v
I'm just wondering this big difference but have not found any good reason for it.
Heaters have been cheked and I have tried with another tube.
http://www.kolumbus.fi/~y635749/RikstoneAmps/PowerAmpC15b.pdf (http://www.kolumbus.fi/~y635749/RikstoneAmps/PowerAmpC15b.pdf)
The amp is very simple, one EF86 as a preamp.
Leevi
Check all Power Supply voltages
"Crackling" can sometimes be caused by plate resistors, especially when using carbon comp resistors.
Weak? This is just a power amp and requires about 1 Vrms to drive to full power. You're not trying to plug your guitar straight into point C1 are you?
I just added the schematic of the power amp. There is EF86 + 6 pos cap. switch + volume
before PI. I have checked the signal level after preamp and it's OK.
/Leevi
There was cap missing between volume and PI input.
Now at least the plate voltages are in balance but there are still some
oscillation problems I have to fix by changing the wiring.
/Leevi
