Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: Leevi on March 06, 2014, 01:05:41 pm
Title: Is that normal?
Post by: Leevi on March 06, 2014, 01:05:41 pm
I'm working with an amp where is not a grid resistor (normally 68K) on the first amplification stage.
I changed the plastic input jack to Switchcraft metal jack and wired it like always i.e. the signal tip is connected to ground when the guitar is unplugged. It works fine if the guitar is plugged but if I unplug the guitar I get relative big hum.
If I separate the signal tip from ground the hum disappears.
Then I changed the jack to non-switched jack and that works fine.
Any good clarification?
/Leevi
Title: Re: Is that normal?
Post by: HotBluePlates on March 06, 2014, 02:25:33 pm
What is the amp?
Where are there possible ground loops?
Post by: stratele52 on March 06, 2014, 05:52:48 pm
What is the amp?
Yes, first thing ; what is the amp ????
Post by: Leevi on March 06, 2014, 11:20:02 pm
I don't know the brand, I only have chassis of it, can also be a DIY amp.
It's a push pull amp with 2x6V6 and cathode bias. I have added PPIMV to it but
don't know if the problem was there before that.
The structure of PI is like in Marshall and Vox.
The preamp consists of one 12AX7 where the triodes are parallel connected.
The preamp circuit is very common with Volume and tone.
/Leevi
Post by: stratele52 on March 07, 2014, 04:14:30 am
I
/Leevi
Most of the time it is easy to see if it is a DIY , post some pictures.
Ground loop ? connect the switchcraft jack but do not scew it in the chassis . If it is a ground loop it wil work with no hum .
Post by: Merlin on March 07, 2014, 04:38:23 am
Why not just put the plastic jack back on...
Post by: stratele52 on March 07, 2014, 05:03:54 am
+1 ;   easy and will work
-1   ; Plastic is not as tough as Switcraft jack
Post by: Leevi on March 07, 2014, 08:53:22 am
One solution is to use a non-switching jack which works fine
but I would like to know the root cause for the problem.
/Leevi
Post by: John on March 07, 2014, 09:48:32 am
Did you say it does not have the 68k grid resistor to the first stage? Maybe it's not so much "hum" as just air noise. :dontknow:
Post by: stratele52 on March 07, 2014, 11:47:27 am
/Leevi
Non- switching jack = hum too
Post by: Leevi on March 07, 2014, 12:11:26 pm
Not in this case. The hum disappears which is weird.
This the reason why I started this topic.
/Leevi
Post by: HotBluePlates on March 07, 2014, 12:15:55 pm
The hum disappears which is weird. This the reason why I started this topic.
My crystal ball is cloudy...
Being a DIY amp (or at least an unknown amp), the only one who knows what is in the amp and what is going on is you. Also, being a DIY amp, all bets are off about whether the thing was even assembled correctly in the first place.
Post by: Leevi on March 07, 2014, 03:29:36 pm
Yes and my interest is to find the root cause for the problem.
I'm now pretty sure that it is a DIY amp.
/Leevi
Post by: sluckey on March 07, 2014, 03:32:12 pm
Can we see a hi rez pic or two?
Post by: Leevi on March 07, 2014, 03:59:17 pm
Couple of pics:
I have changed the preamp triodes to serial connection but the problem was there before the change.
/Leevi
Post by: Willabe on March 07, 2014, 05:01:25 pm
The power tube K R should not be on the big filter cap next to it. It will heat up that cap and will shorten it's life.
               Brad    :w2:
Post by: Leevi on March 08, 2014, 12:34:43 am
Good point!
/Leevi
Post by: Leevi on March 08, 2014, 02:17:56 am
I found the root cause.
I changed the input jack to a shorting jack.
I didn't connect the shunt to the closest ground point
but a point where the hum was not any more caused.
The clarification for the problem is IMO ground loop.
/Leevi
