Amp Stuff => PC Express and JSchem - Schematics and Layout diagrams => Topic started by: kagliostro on April 18, 2014, 02:52:48 am
I was constricted to update my PC so now I run under Windows 7 64bit
I must say I'm satisfied of the new OS but I encounter a problem
I'm no more able to use Jschem, if I start the program I receive a warning
telling me that I've no Java installed on my PC on the contrary I've the last Java disposable installed
Please, can someone give me help ?
EDIT: I solved the problem, instead to download and use the Windows version of Jschem (.exe), I downloaded the Any other OS version (.jar), this last has no problem with my Windows 7 64bit + Java 7.55 64bit :thumbsup:
I don't install the 64 bit java on my 64 bit machines
I install the 32 bit versions
Which Java do you have installed?
Ciao Doug
I've the 64bit version of Java
You can install the 32 bit version instead
That's what I do on my 64 bit machines and jschem works
Try uninstalling the 64 bit version and get the 32 bit version here on this page and see if that works
This page has both versions
http://www.java.com/en/download/manual.jsp (http://www.java.com/en/download/manual.jsp)
Thanks, I'll give a try
Hi Doug
I was on the page you linked and I've read this
We have detected you may be viewing this page in a 32-bit browser. If you use 32-bit and 64-bit browsers interchangeably, you will need to install both 32-bit and 64-bit Java in order to have the Java plug-in for both browsers. »
As I use both browsers, I installed the 32bit version and didn't deleted the 64bit version that I had previously installed
Now with both versions installed all is fine and Jschem for windows opens regularly
Many Many Thanks
Cool
I don't use the 64 bit browser
I forgot that windows comes with both versions
I use both versions of Opera :icon_biggrin:
the old 32bit Opera 12.16 (that I prefer for the functions it has)
and
the new 64bit Opera 20.0 based on Chrome core (if I encounter particular difficulties)
I've also IE 11 that comes with windows, but I really don't know if it is 32 or 64 bit :laugh:
Grazie Ancora
ok, I was assuming you were using IE11
Windows 7 comes with 32 bit and 64 bit versions of IE11
probably windows 8 also
Thanks for the info :thumbsup:
