Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: kagliostro on July 22, 2014, 11:57:19 am
Title: Paralleled V1 question
Post by: kagliostro on July 22, 2014, 11:57:19 am
The simple way is to use a switch to connect the second triode grid to the input
but assuming to go a step further on, is possible to "control" the insertion of the second triode, I mean something like using a pot ?
if the tube wasn't V1 I'm sure this can be done, but as the signal present at the grid of V1 is the lowest signal in the amp
is possible to use a pot in the position of the switch ?
Do you see any other way to achieve the progressive insertion of the second triode ?
Title: Re: Paralleled V1 question
Post by: shooter on July 22, 2014, 12:38:52 pm
found this on the net, tried it, seemed way "overdriven" for my app, but it is sorta what you're askin....I think
Post by: tubenit on July 22, 2014, 12:48:51 pm
Check out the "FAT" control on the original Tweed Overdrive Special.
With respect,  Tubenit
Post by: sean_thornton on July 22, 2014, 01:48:03 pm
All those ideas are kinda cool. In my current build i have V1 paralleled with a relay switching in different cathode and plate resistor values along with the bypass capacitor. Originally i designed it so that V1b could be switched in and out via the plate and cathode, leaving the grid connected. I worked fine but i prefer the tone of a paralleled setup so i dumped the switching idea.
Post by: kagliostro on July 22, 2014, 02:00:28 pm
Thanks Shooter - Tubenit - Sean_Shornton
Jeff the idea starts exactly from your FAT control on the TOS  :icon_biggrin: :icon_biggrin:
only, here, I'm not sure about the use of a pot because here we talk about V1 and the input signal is very low
the only pot in front of V1 grid I see around are on HiFi circuits where the signal is supposed to be higher than the signal from a guitar
or isn't so ???
(http://www.angelfire.com/electronic/funwithtubes/images/Amp-Williamson-3.gif)
Post by: shooter on July 22, 2014, 08:53:56 pm
Not sure what a guitar norm is, I use .5vac from a tone generator, volume seems close when a guitar is plugged in.  I think hi-hi's uses a standard  like line in, line out, 1vac?
sean_thornton did you do your component switching on the fly, a foot switch?
Post by: sean_thornton on July 22, 2014, 09:18:16 pm
Yeah Shooter, double footswitch, one for reverb, one for "fat". I will post a schematic once I have the bugger finished, then it's on to the next build, LOL!
I was actually going to ask kagliostro the same thing about his idea, are you going to use a footswitch and a relay, or just a switch on the front panel?
Post by: kagliostro on July 23, 2014, 12:12:07 am
The idea was to use a switch on the front panel
of course, if a pot arrangement is possible, there may be a switch too
Post by: kagliostro on July 24, 2014, 10:02:48 am
I'm in doubt
I've think to the circuit and a second option come out
this second version provides for the use of a separated plate resistor for each triode and a second switch to connect or disconnect the second plate output
do you think this is necessary to avoid changes in tone of V1 when it is alone, I mean to have V1 that sounds as if in the circuit there isn't V2 when V2 is not paralleled (I hope I've explained this thing in a comprehensible way)
Post by: DummyLoad on July 26, 2014, 09:36:23 am
switching at the grid, the relay wiring will add *some* noise; the plate switching will POP and possibly exceed the relay DC volt rating but probably won't matter since it's "floating". bottom schematic is what i'd build. fewer switching elements.
have you considered switching the cathode of V1b off ground?
Post by: kagliostro on July 26, 2014, 10:03:15 am
Ciao Pete
Do you think that this arrangement will be of benefit trying to avoid pops ? (look to the attached schematic)
One other thing, the original schematic uses a V1a Plate resistor of 100k and 1.5k cathode resistor
the schematic that we are discussing is the Alembic F2b  to wich is added a CF on the output and having an odd triode this is used as to
have a paralleled input
(http://moosapotamus.net/images/AlembicF2B_SCH.gif)
Which do you think will be the best value for the Plate resistor using a single plate resistor for both V1a & V1b ?
Grazie
Post by: sean_thornton on July 26, 2014, 10:14:49 am
If you have the plate and cathode switched out there is no need to mess with the grid. My own experiments showed me that leaving both grids connected in a parallelled 12ax7 had no detrimental effect when switching the cathode and plate of one triode in and out. It also taught me that i prefer the tone of both triodes switched in so I dont even bother switching them anymore, I have come up with other ways to manipulate gain and tone. I also suggest using relays, this will also help to eliminate "pops" when switching.
Post by: kagliostro on July 26, 2014, 11:14:47 am
OK Pete & Sean_Thornton
Do you think this will be a better arrangement ?
Post by: DummyLoad on July 26, 2014, 07:26:16 pm
should work. however, it is likely sean is on track: you'll eventually stop using the switch.
Post by: sean_thornton on July 26, 2014, 08:08:17 pm
Well, it looks like you are trying to imbalance the 2 triodes. Not sure why. The Alembic preamp is a gorgeous sounding one, much loved by Gerry Garcia, and is hard to improve upon. What is it that you are actually trying to achieve? Have you checked out Matchless Amps? They have a parallelled V1, look at their arrangement.
Post by: DummyLoad on July 26, 2014, 11:28:45 pm
paralleling triodes will bump gain up roughly 15%.
Post by: kagliostro on July 27, 2014, 01:06:46 am
All starts from the fact that the F2B is a good preamp but is missing of the necessary impedance adapter at the output
if the buffer is add via a single triode (6av6 - 6at7) the counterpart is the availability of spare parts "on the road"
if the buffer is add via a double triode (12ax7) the counterpart is an unused triode
as to have easily spare part available is obviously welcome but what to do with the "odd" tube ?
To add a gain stage will upset the original F2B and looking to other options one is to use this triode for a CF
between V1a and TS, one other to use it paralleled to V1a, paralleling triodes, as Pete say, will add a 15/20% of gain
and increase the noise rejection, the increased noise rejection is the principal reason for which I chose to go parallel
the switch is think as to permit to use the preamp more like the original if desired
Post by: sean_thornton on July 27, 2014, 10:57:20 am
Ahhhhh! NOW i understand! Okay, so basically you wish to keep the Alembic as close to original as possible but have the option of switching the spare triode in and out.
Okay, kep the V1b grid connected, just switch the cathode and plate in and out. For simplicity i would suggest that the cathodes share a common resistor and the plates do the same. this can easily be achieved either with a switch or via a relay. You CAN incorporate separate resistors for cathodes and plates but I found that it isn't needed.
I hope this helps, let me know if you need any more info.
Post by: HotBluePlates on July 27, 2014, 11:37:45 am
If you still haven't tested to see whether you will like the parallel-triode option, I would wire up the volume control as you had in your very first post.
If you decide you want to incorporate switching that is guaranteed not to pop, you will want to look at solid-state switching, using series and shunt JFETs as the "switch elements" (that is, in place of switch/relay contacts) and solid-state control circuitry to activate the JFETs. I'm not a solid-state expert, but LooseChange (and probably others) has used this in at least a couple amps, and Kevin O'Connor covers it in some detail in his books.
Post by: kagliostro on July 27, 2014, 11:54:41 am
@ Sean_Thornton
Switching the plate is enough safe ? No pop or other contraindications ?
@ HotBluePlates
The pot option is on standby because I'm afraid that the pot will load to much the input that is very low level signal, do you think is possible to give it a try ?
SS switching intimidates me, I've no familiarity with SS circuits
Post by: PRR on July 27, 2014, 08:53:55 pm
EL84 is an excellent single triode with LOTS of possible output and readily available on-the-road.
Post by: kagliostro on July 28, 2014, 01:23:01 am
Ciao PRR
do you mean an EL84 connected as triode for a CF output ?
Something like this ??
(http://headwize.com/images5/ahammer4.gif)
Post by: HotBluePlates on July 28, 2014, 08:41:04 am
@ HotBluePlates
Use a 1MΩ pot, wired exactly as you first drew your schematic. The pot will appear to the input signal exactly the same as the typical 1MΩ grid reference resistor, and will be no extra load at all.
Post by: Platefire on July 28, 2014, 09:03:01 am
Yep, interested to hear your opinion/report of the results once installed. I've got a couple of amps with unused V1b gain stages I could possible apply this to. Platefire
Post by: DummyLoad on July 28, 2014, 09:43:16 am
@ HotBluePlates
how so? the 1M fixed R is in || with pot + grid leak. so less than 500K load. leave out the 1M fixed and it's identical to original ckt, no?
Post by: kagliostro on July 28, 2014, 05:20:04 pm
Thanks for the advice HotBluePlates
The 1M resistor connected into the switch of the input jack in reality isn't connected there in the original F2B circuit
it is connected between the 68k resistor and the grid of V1a
so I think HotBluePlate is right, to use a pot instead of a resistor in that position will change anything on the input circuit
now is to be considered if a switch that connects the grid of V2b to ground is to be preferred to the switch on the cathode
or if is better to have both
Post by: PRR on July 28, 2014, 11:56:36 pm
Switching the cathode will pop. {EDIT} *Violently*. 90V transient at the plate which has roughly 30V peak signal.
Switching grid to ground, but leaving the plate in the audio path, will load-down the one active tube and give much lower gain than the "original".
Post by: kagliostro on July 29, 2014, 12:24:26 am
So the option will be (as from Sean_Thornton) to switch plate and cathode ? See attached schematic.
Without the switch of the plate don't you think that the 100k resistor on cathode of V1b will be enoug as to maintain the cathode cap charged in order to prevent pop ?
Of course if there is a swith at the plate the 100k resistor can't do the job for which it was intended
Post by: PRR on July 29, 2014, 12:44:26 am
IMHO....
The only happy way to do this is:
Drive both grids
Connect each cathode to its own R-C network
Connect each plate to its own resistor
Take output from ONE plate for "original"
Short the plates together for "double".
If the two triodes are Matched and there is no load, there is no pop and no change of gain.
If the two triodes are Matched and there is a load, there is slight pop and slight change of gain.
If the two triodes are not Matched and there is a load, there is slightly more pop and slight change of gain.
The simulation below shows this. For "switch" I used time-switches. One closes at 4mSec and the other opens at 6mSec, marked on the waveform by arrows.
To approximate the effect of mis-match I edited one fake triode for mu of 90 instead of 100.
I know I have seen one of Doug's 12AX7s show 213V and 214V on plates, fantastically good matching. But reading voltage charts of other amps I have seen much worse matching in a single 12AX7.
So the scheme could be very critical about the 12AX7 you use in it. If the two sides are not well matched, you might not dare to switch unless you mute the amp (volume down, or standby). Maybe fine for headbanger party but not when playing the waltz while bride dances with father.
Post by: PRR on July 29, 2014, 01:04:55 am
Your V2B stage is all wrong.
No plate resistor needed or wanted.
Grid resistor is needed.
A typical grid resistor won't need 0.1uFd to drive it.
The 2.2K cathode resistor will clip for signals above a Volt or two.
10uFd is not needed for 10K output pot and likely loads. A non-electrolytic will give less trouble.
If you must use 12AX7 for an output device, it is hard to beat the Fender 5F6a's tone-driver amplifier. Steal both the voltage amp and the cathode follower. Note the unusual value of the volt-amp cathode resistor (820 Ohms); this is needed to get the plate down low so the cathode follower has some voltage to work in. You may bypass this if you wish, to get closer to the Alembic/Blackface 2nd stage gain.
The 12AX7 in this circuit (any practical circuit) only flows about 1.8mA, and can not put all of that to a load. A high guess would be 1.5mA. If you load with a 10K pot and a 10K mixer, 5K total load, that is 5K*1.5mA= 7 Volts peak or 5 Volts RMS. This "should" be ample; however distortion may be significant.
Whereas a EL84 can loaf at 10mA and easily put 15V into 5K, 5V into 1K, drive any "line input" you run into.
Post by: kagliostro on July 29, 2014, 04:52:59 am
One of the first option to which I've think trying to plan this thing, is in the attached schematic
I was thinking to disconnect the input of V1b from input and short it to ground, at the same time the plate of V2b will be disconnected from V1a plate
one option to which I was thinking at that time was to short to ground (via a decoupling cap) the plate of V1b when V1b plate wasn't connected to V1a plate
About the V2b circuit, I'm a plagiarizer and that circuit is the send circuit of the Engl Fireball (as draw by Mr. Merlin)
(http://i.imgur.com/FE0cGff.jpg)
such FXLoop was added with success to a 5e3 circuit (see schematic on this post http://el34world.com/Forum/index.php?topic=17360.0 (http://el34world.com/Forum/index.php?topic=17360.0))
and I was thinking it will be OK also for the F2B output
Do you think that a circuit like this will be more suitable ? (see attached schematic)
I'm interested on the use of an el84 as output CF can you give some values for components ?
One other idea will be to use a paralleled double triode as CF (so no mod to the circuit as tu use an odd triode), what do you think about ?
Post by: HotBluePlates on July 31, 2014, 04:32:37 am
Sorry, I saw what I wanted to see...  :laugh:
I ignored the fixed resistor from input jack to ground, because it's not needed; the 1MΩ pot would already be an adequate grid-reference. So what I really meant was delete the fixed resistor, and use only the pot.
At that point, the first triode sees only a non-changing 1MΩ to ground, as does the input jack. The second triode gets a varying percentage of the input jack voltage, according the the setting of the pot. And the resistance from wiper-to-ground is irrelevant to the 2nd triode operation, apart from varying the signal input level.
Post by: kagliostro on July 31, 2014, 05:10:35 am
Any thoughts about this version ?
Post by: DummyLoad on July 31, 2014, 04:57:22 pm
you don't need the plate switch relay - switch from cathode to cathode
Post by: PRR on July 31, 2014, 07:12:04 pm
I say use the plate switch, not the cathode switch.
Switching the idle plate to a large cap kills the audio there, but that audio does no harm. OTOH when you switch *to* the large cap thing get out of whack for some seconds.
Build it. Wire-in (well-insulated) switches. Try it.
Post by: tubeswell on July 31, 2014, 09:11:06 pm
Just to add more confusion
(https://farm6.staticflickr.com/5451/8843550022_f9125ed75d_z.jpg) (https://flic.kr/p/ettvjo)Switchable cascade:parallel V1 (https://flic.kr/p/ettvjo) by tubeswell (https://www.flickr.com/people//), on Flickr
Post by: kagliostro on August 01, 2014, 07:45:51 am
OK I think that this thing must be wired and tried
But at the moment I'm in Toscana for some days ( just the time for a small taste of wine   :wink: )
So a little standby is on at the moment
Thanks my friends
Post by: DummyLoad on August 01, 2014, 11:16:46 pm
i have the standel spin on the breadboard, (see thread "good clean fun") that had an unused 1st stage triode. i did not wire in a pot - too many parts to move to insert one.
the perceived increase in volume is somewhat noticeable. IMO, forget the whistles and bells, don't switch anything. just build the F2B as is, unless you can stand the popping an clicking.
if you must that triode, then switching the triode in/out as a paralleled gain stage may be of greater gain benefit, but that changes the preamp topology significantly that requires a mixing circuit that is no longer the alembic design. your decision.
see schematic attached for results.
