Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: kagliostro on August 24, 2014, 04:06:33 am
A friend has build by himself a 620VA PT that is used in an amp who absorbs 460W, the TA after ~20 minutes is at a temperature of 55-60° (Celsius) 131-140° (Fahrenheit)
I consider that as an acceptable functioning temperature, what do you think ?
As to have a fresh during functioning transformer with a load of 460W which will be the right VA of the PT ?
What is a TA?
Sorry Steve
TA = Trasformatore Alimentazione = Power Transformer = PT
TU = Trasformatore Uscita = Output Transformer = OT
You can hold it for many seconds. It is fine.
Thanks PRR
also I'm thinking it is fine, thanks for the confirm
the 620VA are enough to have a big transformer to transport, so I think it is an acceptable compromise
but I was curious about how big must be the transformer as to be near fresh during functioning
A friend has build by himself a 620VA PT ..........
The transformer is a DIY unit
The transformer is an E/I
here you can see it on the left
http://www.diyitalia.eu/forum/download/file.php?id=9933&mode=view (http://www.diyitalia.eu/forum/download/file.php?id=9933&mode=view)
as my friend build more than a PT (and OT) at the moment I'm not sure of which are the exact spec of that PT
as soon as I know it for sure I'll say which are
EDIT: Here are the spec of the transformer
PT (core 40mmx70mm):
primary 0-220-230V 2A = 0-245-253 spire of 1mm wire
secondary 0-275V / 0-53V / 0-53V / 0-45V 1A = 0-327 / 0-64 / 0-64 spire of 0.73mm and 0-50 spire of 0.8mm wire
secondary 0-50V 200mA = 0-62 spire of 0.40mm wire
secondary 0-12,6V 1.8A = 0-15 spire - 4 wire in parallel each 0.45mm this was on project but was take off from the real PT
secondario 3.3-0-3.3V 15A = 4+4 spire - 3 wire in parallel each 1.6mm
