Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: G._Hoffman on October 06, 2014, 05:39:46 am
Title: I got so tired of looking for a decent and reasonably priced AC30 chassis....
Post by: G._Hoffman on October 06, 2014, 05:39:46 am
....I decided to make one for myself.
I still have a LOT to learn about using a bending break - even one as cheap and shoddy as mine.  Not sure if I'm going to use the aluminum preamp section shown here, or if I might decide to go with the steel one I also made.  I know they used aluminum in the old AC30's, but they had their transformers mounted in such a way as to support the preamp chassis.  On the other hand, if I stick with the aluminum, I'll only have to get the power amp chassis plated (the steel I'm using is mild steel, which is to say it will turn into rust in about a week - not what I want at ALL).  The steel one turned out a bit better, though, so there is that, too.  Of course, the aluminum came from a scrap dealer, and the (16 gauge) steel came new from the home center, so the aluminum is a bit rougher looking for that reason, too!
I forgot to make the holes for captive nuts before I started bending, which means they will suck to make.
Actually, the thing I most need is to figure out a good way to cut steel in a straight line.  I have a non-ferrous metals blade for my table saw (which isn't much fun, as it sends chips flying EVERYWHERE), so I'm pretty good on aluminum, but the similar blade I tried for steel shot off a crap load of glowing red chips right into the pile of sawdust under the table saw!  NOT a good idea, I don't think.  What I WANT is a sheer, but since I want to be able to use 16 gauge steel, and I can't spend $1,000+, that is not in the cards right now.
(https://farm3.staticflickr.com/2945/15270428467_8b01932509_z.jpg) (https://farm3.staticflickr.com/2945/15270428467_3b5a215c32_o.jpg)
(https://farm3.staticflickr.com/2949/15433913916_cbe46da98b_z.jpg) (https://farm3.staticflickr.com/2949/15433913916_ae09cac71e_o.jpg)
(by the way, if you want to see ridiculously large pictures, just click on them)
Gabriel
Title: Re: I got so tired of looking for a decent and reasonably priced AC30 chassis....
Post by: G._Hoffman on October 06, 2014, 05:46:38 am
Oh, and if you are thinking there are too many preamp tube sockets, you are wrong.  There is one more than you would expect, but it certainly isn't too many!
I got something clever in mind.  Well, not that clever, but cool!
Gabriel
Post by: kagliostro on October 06, 2014, 06:03:23 am
You are thinking to add an EF86 channel (like in AC15) or a one tube reverb, those two things are missing on the AC30  :icon_biggrin:
About cutting at home a steel sheet you must use a tool like this
(http://www.vibroget.com/wp/wp-content/uploads/201101.jpg?6020c0)
and an 1mm thin cutting disk for inox like this
(http://www.nauticailliano.it/P/D/%7BFCE69D19-4930-47CD-A8AC-756062F62BE1%7D/NAUTICA-ILLIANO-DISCO-TAGLIO-INOX-RHODIUS-MM115-SPESSORE-MM1.jpg)
you require also to be patient and to have a steady hand, draw a line with a marker and follow it
Post by: terminalgs on October 06, 2014, 10:00:26 am
Cutting with a cut-off wheel and a 10KRPM die-grinder cuts steel of nearly any thickness, but!!:  it isn't cutting as much as it is heating to the point of burning to get through the metal.  Similar to a plasma cutter, but a bit more crude and less precise.  You will be left with a piece of metal with a sharp edge that will need filing to make it more like a sheared edge and less like a jagged knife.  With some skill, smooth cuts can be done with a cut-off wheel, but the edges are still super heated..   die-grinders come with two handles... use both!  and know which way the wheel turns.,,   respect the die-grinder!
Your chassis looks great!
To drill holes in the lip for clip nuts,etc.:  cut a piece of wood into a block that'll fit snuggly  into the chassis so that it touches all four planes (top, sides, and bottom where the two lips are)., it should be perpendicular  to the long edge of the chassis... you can slide back and forth in the chassis you position the lip under the drill bit,  with the block directly under, or next to the hole.
as for metal gauge size:  16 gauge steel is pretty thick.  I use tin-snips on smaller gauge mild steel, and use reinforcement brackets to ensure transformer weight doesn't collapse, deform chassis.   I do this so (1) I can use snips, and (2) I can use a cheap bench mounted bending brake.
regarding rust:  imho,  rattle can metal-etch primer is all  the rust-prevention most amps will ever need, especially if its stored in climate controlled place.  lots of 40-50 year old rusty chassis amps probably spend 20 years or more in damp basements, humid garages, or incredibly hot attics.   plating or power-coating is overkill, but if you like the aesthetics,  thats a different story.
Post by: kagliostro on October 06, 2014, 10:49:22 am
To cut steel at home also an electric nibbler may be an option, but usually they are expensive
(http://www.boschhardware.com/wp-content/uploads/GNA20.jpg)
so you can think to an optional tool for your hand driller, like this
http://www.fervi.com/ita/utensileria/utensili-taglio/macchine-per-lamiera/roditrice-per-trapano-pr-7294.htm (http://www.fervi.com/ita/utensileria/utensili-taglio/macchine-per-lamiera/roditrice-per-trapano-pr-7294.htm)
but with nibbler the problem is that is difficult to follow a straight line being very prone to follow and execute curved lines
if you don't invent a way to do straight long
Post by: eleventeen on October 06, 2014, 11:04:02 am
The way I cut long straight lines on metal is to set up a fence on my drill press by clamping a nice piece of hardwood to the table and drill lots of little holes in a straight line, bend/break (or hacksaw) the cutoff section away, then use the 4" grinder, then file, then belt sander. Yeah, it's a pain in the rear end and kind of Fred Flintstone but really, any time you don't have the right tools it's a PITA.
Post by: heresrobert on October 06, 2014, 12:04:25 pm
Disclaimer. Do this at your own risk. Follow your tool's instructions and use safety precautions for sure!!!!!
Cutting sheet steel is difficult with hand tools.  I use a strong jig saw (Bosch for me) and some fine tooth metal cutting blades. Going slow helps save life on the blade. After carefully measuring and marking, I clamp the sheet metal down to a sheet of ply wood and saw horses. I use a straight piece of plywood under the clamps as my fence for long cuts. Support the sheet metal as much as you can on the plywood. It takes patience and practice. Cutting stainless sheet is a PITA, mild steel is easier, aluminum is easiest for me.
Robert
Post by: eleventeen on October 06, 2014, 12:35:55 pm
Stainless steel is incredibly difficult without top-notch tools. I wouldn't even try it.
Post by: tubeswell on October 06, 2014, 12:45:07 pm
For big bits of chassis sheet metal, I get the pieces cut on a guillotine in a metal shop.
I have a decent brake so I can bend it at home. For small bits up to about 1.2mm thick I use a pair of tinsnips
Post by: PRR on October 06, 2014, 02:33:40 pm
> bending break ... sheer
brake, shear
On your car/bike, brakes are good, breaks are bad.
Specifically... a brake lets you move to the right spot, then holds against movement. Work the handle/pedal, and the sheet stays there while you abuse it.
Shear: "From Middle English sheren, from Old English scieran, from Proto-Germanic *skerana;, from Proto-Indo-European *(s)ker- (“to cut”)." Sheer is how you want women's clothing.
(http://upload.wikimedia.org/wikipedia/commons/thumb/4/45/Godward-The_Mirror-1899.jpg/180px-Godward-The_Mirror-1899.jpg)
If you keep the table saw outside, the sawdust stays wet, won't burn. (True, this suits my $20 yard-sale saw better than your $2K Hoffritz saw.)
For ALL metal-work, find your local heating duct shop. I just had a huge duct bent-up perfect for about what I thought the steel alone would cost. While duct-work is mostly thinner gauge, there's some heavy bits and also duct-guys have GAS just as bad as we do, they have machines "too good" which they want to justify. And if not, he's sure to know who in town has the big shears and brakes, and won't over-charge for a small job.
Hand shears can cut 18 gauge (good ones) but it is work. My neighbor has 4-foot shears which attached to an anvil; he says if you heated the steel and had a heavy apprentice they would cut 1/4" plate. However I think they were intended for Wrought Iron, and they are in such bad shape that he welded them up as a bumper for his rat-rod.
Sawing (or abrasive disk) sheet metal is usually a bad idea. The edge comes out ROUGH.
If you must saw, clamp the metal between two hardwood boards. It cuts the vibration, may slow the sparks, and is less likely to get away from you than thin metal.
Stainless Steel is now banned here, after ruining many bits on some SS furnace and gas-line brackets. Who needs to live forever?? Even at your young age, a clean and a Krylon will stay rust-free until arthritis blunts your fingering. If you need "shine", go Aluminum and a clear-coat.
I do think that the $40 4-inch hand grinder is very-very useful for many things, and my neighbor did 99% of his rat-rod metal cutting (and metal roofing) with one before he got his cut-off saw (which is good for rod/tube, not really for wide sheets).
There is a 3-blade metal shear which is handy up to 18 gauge:
http://www.eastwood.com/eastwood-air-shears.html (http://www.eastwood.com/eastwood-air-shears.html)
(also comes in electric, and as an add-on to an electric drill.)
The Throatless Shear is even better, a very nifty device, but costs more; $170 for up to 14 gauge
http://www.eastwood.com/throatless-shear.html (http://www.eastwood.com/throatless-shear.html)
There used to be whole books about brake bending. I would say Lindey's Books but I see he has retired. Archive.org has random scans of old books. IMHO the old books are far better than the new ones which just prepare you to pass a test, not really to bend-up harvester brackets and furnace pots.
Post by: G._Hoffman on October 06, 2014, 04:16:48 pm
Robert
I used a jig saw (on this one, which was my second attempt of the weekend, because on the first one I put the choke in the wrong place and it was interfering with the preamp tubes), but when I used a fence with the jig saw the blade wandered too much, so it worked out much better to just draw a line and follow it freehand.  I'm pretty good at that, so its probably +- 1/32", but I wanted to be able to do better.
Just a 1970's Delta Contractor's Saw - nothing special at all, but very well set up!  And in the basement, so sparks in the sawdust are DEFINITELY a problem!!!!  I do have a roofing place near by, though, and I might give them a try next time I need something done - I've seen a rather big brake through their roll up as I walked past a few times!  I don't much like my brake (well, it only cost me $60, so go figure), and I would surely like to find a better way around this stuff.  The nice blank chassis on the internet that I have used in the past are all very nice, but very expensive for what you get, and drilling and cutting on bent chassis is just a pain, and it is too hard to do a good job.
Gabriel
Post by: G._Hoffman on October 06, 2014, 04:37:53 pm
An EF86 channel in place of the "Normal" channel - though I might have it be switchable with the 12AX7 normal channel, since the other half of that tube is the preamp for the Top-Boost channel.
Gabriel
Post by: kagliostro on October 07, 2014, 02:51:33 am
Some time ago I was thinking something similar
http://el34world.com/Forum/index.php?topic=16273.msg159252#msg159252 (http://el34world.com/Forum/index.php?topic=16273.msg159252#msg159252)
(http://el34world.com/Forum/index.php?action=dlattach;topic=16273.0;attach=39756)
Post by: terminalgs on October 07, 2014, 11:49:22 am
Franco,  On an AC30 designed like that, you might use the other grid input to the PI (like the first AC30s did), rather than ground it.  You don't have to mix channels one and two with those 220K resistors.   There would be a lot more gain available  from the sole 12AX7 triode channel.  or something like this:
(http://i.imgur.com/7L7s7hX.jpg)
Post by: kagliostro on October 07, 2014, 03:02:55 pm
I agree, but I was using that schematic because I've find it near what I was thinking
so it was simple to modify it as to give an idea about what I was wondering if feasible
My AC30 idea is a "bit" more complicated, I've near all what is necessary to build it
but I never finished an adequate layout, also I'm lost on building some equipment for my laboratory
also, last week arrived my CNC Milling machine and I'm studying CAD programs, Artcam & Mach3
I like your AC30 idea and I'll follow you with interest
Post by: Ritchie200 on October 10, 2014, 12:58:22 pm
PRR, I sure do like your show and tell posts! :grin:
Something else to consider guys.  Maybe its because I had been in manufacturing for many years that I notice them, but I'm sure its common everywhere.  I have several shops around me that do general fabrication.  Not necessarily the machine shops, but the welding shops.  The bigger ones around here buy sheets in large qty, have brakes and shears, and many times a complete job is cheaper than I can buy a tiny (relative to them) amount of raw material.  In some cases they have scraps large enough for a chassis so they are happy to use it up and material cost is minimal.  One place I use also has hole punch capability.  Another has an old Whitney that can to squares, rectangles and ovals, as well as holes.  General hands are cheaper than machinists so that's why I use the weld shops, I dont need them to hold +-.001".  I've got a Bridgeport, but if they can set it up and punch it for a couple of bucks, I'm good.
The place I use the most makes roll cages for pulling tractors, milling machine enclosures, coolant sump pit inserts, tanks, and any multitude of farming repairs and fabrication.  They even do powder coating.  Just make some phone calls, you might be surprised at the savings.
Post by: PRR on October 10, 2014, 10:00:24 pm
> bigger ones ...buy sheets in large qty, have brakes and shears, and many times a complete job is cheaper than I can buy a tiny (relative to them) amount of raw material.  In some cases they have scraps large enough...
+1
Post by: G._Hoffman on October 27, 2014, 03:45:21 am
...regarding rust:  imho,  rattle can metal-etch primer is all  the rust-prevention most amps will ever need...
Well, I went this route.  It looks alright, and it's not going to be visible, but I still kinda would have liked to get it nickel platted:
(https://farm6.staticflickr.com/5597/15454002597_97b984911e_z.jpg) (https://farm6.staticflickr.com/5597/15454002597_495928f914_o.jpg)
(https://farm6.staticflickr.com/5614/15640819572_f112a6ac49_z.jpg) (https://farm6.staticflickr.com/5614/15640819572_a198be52b6_o.jpg)
On the other hand, I really like the stiffness and solidity of the fairly heavy steel chassis.
Gabriel
Post by: kagliostro on October 27, 2014, 07:09:51 am
Very nice, I like it  :thumbsup:
Can you post some other photo with a perpendicular view of the turret boards ?
Post by: Willabe on October 27, 2014, 09:56:32 am
Looks great!
                           Brad      :bravo1:
Post by: terminalgs on October 27, 2014, 03:55:22 pm
Really outstanding!
Post by: G._Hoffman on October 27, 2014, 04:28:19 pm
I'll try to bring the good camera home and get some decent (i.e., non-camera-phone) photos.  it should be noted, this thing is far from being finished - I'm working on it as I have time, but am currently very busy finishing some guitars.
Gabriel
Post by: G._Hoffman on October 27, 2014, 04:29:32 pm
Kinda nice though, to not need an amp stand, nor to prop it up on blocks of any sort.
Gabriel
Post by: Willabe on October 27, 2014, 05:10:39 pm
 :laugh:
Post by: G._Hoffman on October 28, 2014, 04:29:30 am
(https://farm4.staticflickr.com/3951/15028914953_b28d2a051e_z.jpg) (https://farm4.staticflickr.com/3951/15028914953_53f23044f4_o.jpg)
(https://farm4.staticflickr.com/3955/15462920788_a9cafb3e29_z.jpg) (https://farm4.staticflickr.com/3955/15462920788_a6062ce627_o.jpg)
(Definitely NOT done.  And I have to rewire the preamp heaters.)
Gabriel
Post by: Ritchie200 on October 28, 2014, 08:28:41 pm
That is some beautiful work!
By the way, socks are not good insulation to bare concrete floor!
Jim :icon_biggrin:
Post by: eleventeen on October 28, 2014, 10:23:52 pm
Beautiful work! Heavy parts count in there.
Post by: G._Hoffman on October 29, 2014, 12:37:59 am
Well, it IS an AC30!  Lots of parts is the name of the game.
By the by, I started on the layout by copying the Weber layout, and then modifying it as needed to fit in the parts for the EF86 and to distribute the filter caps.
Gabriel
Post by: G._Hoffman on October 29, 2014, 12:38:53 am
Jim :icon_biggrin:
Well, first of all, I wasn't working on it, and second of all, it hasn't had power yet, so I'm not too worried about getting a shock!
Gabriel
Post by: kagliostro on October 29, 2014, 08:10:17 am
Just a curiosity, you have 7 inline preamp tubes, the chassis is longher than the original or is the standard lenght of the AC30 ?
Post by: G._Hoffman on October 29, 2014, 02:39:44 pm
Standard length.  There is a fair bit of extra room in an AC-30 chassis.  Plenty of extra current on a standard AC-30 heater winding, too!  I counted 5.1 amps of heater current for all the tubes, and the PT has 6 amps available.  That made life easier, for sure.
Gabriel
Post by: G._Hoffman on April 24, 2016, 05:22:39 pm
Just powered this thing up and played through it for the first time just through my test speaker, naked on the bench - no cabinet yet!), and the only problems I've run into were a bad tube (plate/grid short - it's definitely not good to only have 24V on a plate!  Even worse when the rest shows up on the grid!!!), and the speed control isn't working for some reason - not sure why yet.  Oh, and the Bass control is backwards. It's reasonably quiet, and the EF86 channel sounds fucking awesome!!!!!
 On the whole, I'm a bit baffled.  I mean, normally when I make an amp, there is some near disaster - a blown transformer, or at least I'll go through a few fuses.  This time ... nothing serious.  A couple minor things that shouldn't take too much to fix.  How the fuck does THAT work?  I was a bit worried by the 75V plate voltages at the mixer, but I looked at an old schematic, and it's correct.
(https://c2.staticflickr.com/2/1696/26624075315_92fdac3698_z.jpg) (https://c2.staticflickr.com/2/1696/26624075315_6103869a72_o.jpg)
(https://c2.staticflickr.com/2/1494/26597991836_ed8f9b3a45_z.jpg) (https://c2.staticflickr.com/2/1494/26597991836_4cf595e08c_o.jpg)
(https://c2.staticflickr.com/2/1680/26598000766_66945c391b_z.jpg) (https://c2.staticflickr.com/2/1680/26598000766_9d2733b13a_o.jpg)
(Click on the pictures if you want to see really big versions)
I'm gonna try to get the cabinet done this week, though work might get in the way.
Gabriel
Post by: G._Hoffman on April 24, 2016, 05:28:47 pm
It is amazing, though, that when you start to really follow all those basic concepts of layout, things really do work!
My next amp, however, will be a LOT simpler.  One channel, cathode biased EL34s, just as simple as I can make it!
Gabriel
Post by: sluckey on April 24, 2016, 06:50:28 pm
That looks really good!
If there is a plate/grid short then you should have the same voltage on each element.
Those AC30s are known to run really hot. With that style chassis some forced air would be beneficial.
Post by: G._Hoffman on April 24, 2016, 07:04:02 pm
Well, I measured 68kΩ between the plate and the grid (out of the amp), so I threw the tube and put in a new one, and all the voltages went up to the right range (all the other plate voltages were 10%-20% low, not surprisingly, until I replaced the tube).
As for the appearance - it looked so neat and tidy until I started running the shielded wire!!!!!!  But I'm much less concerned about that than the sound.  And it sounds GREAT!
And you're definitely right about it running hot.  Absolutely gonna need a fan when it goes in the box!
Gabriel
Post by: HotBluePlates on April 24, 2016, 09:36:33 pm
Very nice!!
It looks like you ventured into the "cross-the-socket" routing of the heater wiring, as I did in my Standel-type amp. So tell me... Did it turn out quieter than you thought it would?  :icon_biggrin:
Post by: G._Hoffman on April 24, 2016, 10:10:32 pm
Very nice!!
How else I could do it with that much circuitry?  It wasn't so much a choice as a requirement.  It's also how they made the old AC30's, so you know ... It works well, though.
The Vibe/Trem channel is dead quiet, the EF86 is pretty good, and the top boost channel is kinda hissy.  But no 60 cycle hum, so yeah, it's worked pretty well.
Gabriel
Post by: tubenit on April 25, 2016, 05:18:04 am
Just like all your stellar work, that looks great!  Very well done and thought out!
Thanks for sharing your pictures and success!
Post by: kagliostro on April 25, 2016, 11:50:56 am
Really an impressive job  :thumbsup: :thumbsup:
So, if I understand correctly you have an unused triode, those of the normal channel ?
and your configuration is
2 triodes (1 tube) for the LTPI
6 triodes (3 tube) for the vibrato/tremolo channel
3 triodes (2 tubes - one triode unused) for the Top Boost channel
1 pentode (1 tube) for the ef86 channel
do you used a tone control on the pentode channel ? a standard rotary switch with capacitors ? or what else ? on the faceplate I don't see controls for that pentode .....
Post by: EKDENTON on April 25, 2016, 11:54:17 am
Looks awesome. Very nice work! I haven't ever seen the inside of an AC30, it has a ton of caps on the one board.
And looking at all the empty tube boxes......looks expensive to build.
Post by: p2pAmps on April 25, 2016, 01:12:16 pm
Very impressive man...  Nice work.
So, I would love to hear about the technique you used on the twisted wire to connect turrets????  I might have to try that one out...
Post by: HotBluePlates on April 25, 2016, 02:25:01 pm
...  It's also how they made the old AC30's, so you know ... It works well, though. ...
No kidding!?
Huh, I must never have noticed. Or I subliminally-stole it from seeing old AC-30 pictures. I'd used it in the amp I referenced earlier (http://el34world.com/Forum/index.php?topic=14263.msg134513#msg134513), but didn't recall seeing/stealing it at the time.
Post by: Paul1453 on April 25, 2016, 02:46:52 pm
Your work looks outstanding.   :worthy1:
Note to self, scratch the AC30 off any list of amps I might want to try to build.
The parts count and layout look like more than I could handle.   :l2:
I hope yours sounds as good as it looks when you finish!  :icon_biggrin:
Post by: G._Hoffman on April 25, 2016, 05:56:57 pm
Yup, one unused triode.  The pentode was a kind of late addition to the design, or I would have used that triode as the standard Normal channel - one jack for each channel.  By the time I thought of it, though, I'd already finished the board layout, and didn't want to try to jam more crap in there.  There is a volume control for the EF86 channel, but the only tone controls on either the Vib/Trem channel or the Normal control is the Cut control, which feeds a bit of the inverted side of the phase inverter to the non-inverted side.  Fine by me - I tend to leave tone controls all the way up anyway.
Well, I tend to keep myself well stocked in most parts, and get them from mostly wholesale sources, so not TOO expensive.  Making my own chassis helped, and this is about the third amp I've used the transformers and choke on, but the others just didn't sound the way I wanted them to, so I decided to just build the real thing!  All the big Electrolytics are just power supply caps, but I like to distribute them through the amp so they are closer to their respective gain stages (helps with noise), with the caps on either side of the choke being paired in series, since radial caps are hard to find in 500V ratings.  Most of the rest of the caps are related to the Vibrator part of the Vib/Trem channel.  I've had it explained to me (I think further up in this thread), but it's all black magic to me!!!!
A couple of smooth jawed pliers, and a lot of patience.  Fortunately, you do it while the board is unpopulated, and there aren't all THAT many joints in most amps.   Not sure it was worth it, but I do like the way it looks.  One could buy a pair of safety wire pliers (used to hold bolts in place in jet engines and rockets, where Loc-tite is just an unwanted source of combustion - but I think it looks awesome, so I wanted to use that twist here), but the cheap ones have really rough jaws that ding up the buss wire, and the ones with smooth jaws are expensive.  It's a bit too precise to try with a cordless drill (which is how I do other twisted pairs of wire).
Gabriel
Post by: G._Hoffman on April 25, 2016, 06:14:21 pm
It was definitely the most complex amp I've ever built, BUT I've always been a fan of these things, and like most things, if you take each step in the process carefully, none of them are all that hard.  This amp just has a lot more steps than I'm used to!!!!!!
I think I might have all the parts I need for a 5E3 deluxe.  That should be a nice, simple job, right?
Gabriel
Post by: p2pAmps on April 25, 2016, 06:30:47 pm
Gabriel
That is exactly what I figured you used...  Safety wire pliers.  I have to try it out.  thx
Post by: G._Hoffman on April 25, 2016, 08:00:36 pm
Well, I didn't, because the ones I used to have are cheap and damage the wire, but you COULD.  I just used a couple of smooth jawed pliers.  (Buss wire is a lot softer than safety wire.)
Gabriel
Post by: SoundmasterG on April 25, 2016, 10:18:49 pm
How did you do the front panel for the amp? It looks really good....very nice work!
Greg
Post by: G._Hoffman on April 26, 2016, 01:25:06 am
Greg
I've got a CNC machine I made a while back (well, really, I'm in the middle of making it, but it is running).  The front plate is red laminated on white, so I just engraved it with a V-bit (30 degree bit, with a .015" tip, made by company called Precise Bits - who make really nice small bits, though nothing with a 1/4" or larger shaft).
Gabriel
Post by: tubeswell on April 26, 2016, 04:10:39 am
Top notch job. The metalwork looks dandy too.
Post by: Ed_Chambley on April 27, 2016, 03:36:04 pm
Very nice, and I know you are loving the EF86.  Playing 12Ax7 get old at times and those pentode preamp tubes are a nice change.
Great Job.
Post by: G._Hoffman on April 28, 2016, 04:13:03 am
Great Job.
It's got a very punk rock attack to it.  It makes me think of that really aggressive, not too dirty sound Elvis Costello used to get.  I've got to try to get that electric 12-string sound he has on Veronica - I think it should work out great!
Gabriel
Post by: Ed_Chambley on April 28, 2016, 01:21:16 pm
Great Job.
Gabriel
Yea Buddy.  I have actually taken to making the values switchable between Vox and Matchless.  The Matchless setup sounds very similar but has a more open feel.  I would thing with a 12 stringer it would be very nice.
A lot of folks have complained about microphonics and a very experienced builder, Jeff Bakos here in Atlanta told me to keep my voltage under 100 on the plates and I would not have that problem.  I do and have never had one go microphonic.
One of the guys at Triode Electronics told me to try a NOS tesla as I have normally used the ones with the screen in them like a mullard.  I have to tell you is is a fantastic tone.  I even converted my main Super Reverb channel 1 to a ef86.  Some say they are not great driving a tonestack, but I disagree.  Great tone and with a AB switcher on the Super Reverb I can get the great blues sound and then get that raspy tone.  Elvis Costello's tone is a great example.
Post by: Greenmachine on May 05, 2016, 06:00:40 pm
Amazing!  Good for you!
Post by: kagliostro on May 05, 2016, 06:23:52 pm
Ed_Chambley have I understand wrongly
or are you saying that you use the resistor (and capacitors) values of the Vox (and Matchless) on the ef86
(http://music-electronics-forum.com/attachments/1846d1203271300-ef-86_values.gif)
keeping the voltage that supplies the tube under 100V and also you follow the tube with a ToneStack having good results ?
Post by: G._Hoffman on May 06, 2016, 03:20:24 am
Got the baffle finished!  I'm planning to get the main part of the case covered tomorrow, but right now I'm really happy with how both the logo came out (click to look at the close up of the logo - I tried to find a font which was close to the Vox font, and put in all the lines similar to the Vox logo), and how the grill cloth came out.  I was really worried about the grill cloth because of the pattern, but other than the corners on the right (which are just a bit wonky), I think it turned out really freaking well.
(https://c2.staticflickr.com/8/7757/26573822810_de7dcc9a1c_c.jpg) (https://c2.staticflickr.com/8/7757/26573822810_038d5432fe_o.jpg)
(https://c2.staticflickr.com/8/7247/26242191993_96c199b082_c.jpg) (https://c2.staticflickr.com/8/7247/26242191993_15348e486c_o.jpg)
Oh, and the purple logo is not intended as a Prince tribute - I just have a boat load of these T1 sized "Super Bright Pink" LED's, and wanted to use them up!
Gabriel
Post by: kagliostro on May 06, 2016, 09:22:24 am
Very Accurate Job :thumbsup:
Post by: HotBluePlates on May 06, 2016, 11:58:06 am
... I'm really happy with how both the logo came out ... have a boat load of these T1 sized "Super Bright Pink" LED's ...
Is that a side-lit engraved Acrylic/Plexi panel?
Looks pretty awesome! And like my Standel-type amp, while the lettering lights brightly, the whole panel will faintly glow.
Post by: p2pAmps on May 06, 2016, 11:59:10 am
 :occasion14:
Excellent
Post by: G._Hoffman on May 06, 2016, 08:09:19 pm
Yeah, it is.  The glow is actually just reflecting off the Tolex behind it.  Last time I did this, (on a Dumble-esque amp fit for a Super Hero!), I left a window behind the panel as well, so you could see the tubes glow a bit (just a bit - no extra lighting in there!).
If your acrylic glows, you need to buy better acrylic.  I get it from McMaster-Carr, and it is SOOOOOOOO much better than hardware store acrylic.  It is completely clear, and there is no glow - just the engraving lights up.  (Well, any accidental scratches also light up, sadly.)  It also machines about 1000% better - no melting, no running over the design 5 times to clear out the dross - once, and done.  I usually have to go through and scratch out a few little burrs, but it is a night and day difference.
Gabriel
Post by: G._Hoffman on May 06, 2016, 08:52:44 pm
I always hated the way the grooves where you run the skinny piping turn out at the edges, so I decided to come up with a better way to do it.  While I'll admit this cutter looks a bit scary, it is taking such a light cut that it is pretty comfortable to use.  (This is also one of the reasons I love having a really great woodworking shop available - I had to buy the slot cutter; but the big bearing, the various bushings to make it work, the collar to hold it all on, and the bit extender were all on hand (mostly in the shaper room).  It does have a lot of mass, which helps with the cut, but also means that it took almost a minute to spin down!!!!  Definitely one only to use in a router table!!!!!
(https://c2.staticflickr.com/8/7024/26254697674_2f1042f3f2_z.jpg) (https://c2.staticflickr.com/8/7024/26254697674_b477d11380_o.jpg)
It sure does leave a nice corner, though!!!!!  It's a bit hard to see, but the corner has a perfect radius - no square corner!  I just tested the fit, and it is PERFECT!!!!
(https://c2.staticflickr.com/8/7029/26792589001_ce6bc6f65f_z.jpg) (https://c2.staticflickr.com/8/7029/26792589001_48351c054f_o.jpg)
Gabriel
Post by: G._Hoffman on May 30, 2016, 09:57:58 pm
(https://c2.staticflickr.com/8/7284/27294352221_127b6bc333_z.jpg) (https://c2.staticflickr.com/8/7284/27294352221_ae7d0fafe3_o.jpg)
The box is done.  Just some electronic odds and ends to tie up now (like power for the LEDs).
Please don't ask for close ups of the box.  They will not be forth coming.  I REALLY hate inside corners.
Gabriel
Post by: Ed_Chambley on May 31, 2016, 03:27:22 pm
I cannot say about the tube following the tonestack as I have not built that amp yet.  I plan to.
I have only used them in circuits similar to the Vox AC15, Like the Route 66 by Dr Z and of course a Matchless DC30.  And yes, I have made it switchable between the 2.  It began with playing the Matchless which seemed to have a better clean tone and I wondered why.
The voltage thing is something that Jeff Bakos told me to try on small signal pentodes to keep them from being Microphonic.  Actually it was a 6sj7 I was having microphonic issues with when I changed the 5c1 Champ from grid bias to cathode bias.  He told me to lower the voltage and it worked.  He also said he tries to keep all small signal pentodes at low voltages.
I can say on the EF86 and the 6sj7 lowering the voltage did help with microphonics, but I have been working with a 5879 a lot lately and this tube doesn't seem to have microphonic issues.
Post by: mresistor on June 01, 2016, 03:56:08 pm
That cabinet is beautiful !   You do nice work sir.
Post by: G._Hoffman on June 01, 2016, 07:02:04 pm
Just don't look at the vents, please!
Gabriel
