Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: patty1969 on February 16, 2015, 04:34:18 pm
Title: Noise form newish 5f4 build
Post by: patty1969 on February 16, 2015, 04:34:18 pm
I have a strange problem occurring from a 5F4 I built some time ago.
I gave up on it a few years ago because it was making noises and I did not have the time to fix it.
So, having found some time, I set it up in my workshop and turned it on to warm up while I did some other electronics projects.
I remember that it would occasionally make noises when it was warm.
When it warmed up, I used a chopstick to probe around and found that the wires going from the input jacks to the first 12AX7 were microphonic. I probed the resistors and the wires between the input jack and the tube and they were all noisy when I tapped on them. ALSO, while the amp was plugged in and warming up, I had another amp plugged into the same extension cord. When I was fiddling around in the second amp, e.g., probing around, I was getting noises in the 5F4.
Are these two things related?
Any help would be appreciated.
Pat
Title: Re: Noise form newish 5f4 build
Post by: shooter on February 16, 2015, 08:15:56 pm
I would suspect a grounding issue, can you hear radio stations faint, they always seem to be Gospel stations when they show up!
Post by: patty1969 on February 19, 2015, 07:01:26 am
Thanks for your reply!
It seems like the shorting jacks on the bright channel were not contacting very well. I cleaned them and it seems quieter.
No radio stations. Either way, no gospel radio up here. More likely to hear a hockey game or angry talk radio (on AM I assume).
Still wondering about the noise transferring into the amp. Last night I noticed that if I turn the volume knob on the guitar, you can hear a static noise in the amp but if I touch the amp with one hand and turn the knob with the other, there is no noise. It is not a lot of noise but it is there. How normal is that?
Pat
Post by: shooter on February 19, 2015, 10:27:13 am
try a different guitar cord, sounds like loose/broken shield on the cord/guitar.  I made the mistake of doing what you did on a 2 prong amp....I won't do that again!
