Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: BigE on March 30, 2015, 08:25:07 am
I've got an Ampeg V-4bh that suffered a fall from the cab it was sitting on. Now there is hardly any output our of the mains. Swapped Tubes and no change. Chop-sticking doesn't reveal anything. Can't see anything broken or loose.
Here are my voltages:
V1
1 - 220 6 - 218
2 - 0 7 - 0
3 - 3.7 8 - 1.8
V2
1 - 346 6 - 220
2 - 71 7 - 2.5
3 - 113 8 - 4.5
page 2 schematic:
V1:
1 - 230 6 - 270
2 - 0 7 - 50
3 - 1.7 8 - 102
v2:
1 - 281 6 - 276
2 - 0 7 - 0
3 - 15 8 - 15
Power tube voltages:
3 - 485
5 - -47
8 - 0
voltage at "bias" point in schematic is -48
+- 10v are right on
High voltage drops look OK.
Not sure where to start since I can trace signal all the way through the thing. And you do get output but you have to Max the thing to get any signal out.
Thanks in advance.
usually mechanical hits cause mechanical breaks, I'd still look for that.
Listening or scoping? I'd think either would show where the signal gets anemic
With a listener box i traced the signal. I figured on the power tubes it would be non existant but it seemed pretty solid.
