Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: kagliostro on May 02, 2015, 08:44:50 am
This FXLoop is a kit that you can find in the web, it is a serial FXLoop, but a friend would like to add a parallel switchable option
the problem (to me) to have things clear in mind, is the 2.2M resistor (I think it acts as a virtual earth)
so I'm not able to decide exactly how to arrange the added part to obtain parallel function
(http://i.imgur.com/BMuK4k2.jpg)
I was thinking to connect the junction of the 22n cap / 500p cap (send side)
with the junction of the 47k resistor / 22n cap (return side)
all with an in series switch to insert or disinsert the parallel and an in-series resistor (lot of doubt about proper value)
But, as told, the virtual earth presence confuses me a lot
Which will be your idea about ?
Many Thanks
p.s.: I hope the circuit was correctly reverse engeenered
Aiken has article that shows the summing feature for this type of feedback-amplifier:
http://aikenamps.com/index.php/designing-single-stage-inverting-feedback-amplifiers (http://aikenamps.com/index.php/designing-single-stage-inverting-feedback-amplifiers)
Many Thanks for the link VMS
I hope I'll be able to understand all that math :huh:
If you compare your loop to this loop, then for unity gain you would use 2,2M resistor, I think.
(http://i26.photobucket.com/albums/c149/VacuumVoodoo/Miscelanea/FX_Loop4.gif)
Yes, may be correct
I think I'll try with a trimmer as to establish a right value for the in-series (on parallel signal) resistor
As injection poit I think (as told) to the junction of the 47k resistor / 22n cap, but not sure of that at all
EDIT: I modified "my" schem and seems more readable, I added the mod for parallel/serial action
do you think it is correct ?
(http://i.imgur.com/lxyovS1.jpg)
what about to connect the 2.2M resistor to ground via the switch when in serial mode ?
in the schem you posted there is a ground connection on the switch, but to me didn't seem indispensable
Yes, may be correct
I'm not really an expert on these but to me it looks similar to the picture I posted.
You have to try it, probably you wont here any difference. :dontknow:
Thanks Again VMS
