Forum and Web site Stuff => Hoffman Amplifiers web sites => Topic started by: EL34 on June 22, 2015, 10:26:51 am
I added a new feature to my shopping cart.
You now earn discounts based on past purchases
You can read all the details on how this works on this page
http://hoffmanamps.com/Info/CustomerLoyaltyInfo.htm (http://hoffmanamps.com/Info/CustomerLoyaltyInfo.htm)
Enjoy your discounts :icon_biggrin:
Doug, That's VERY cool! THANK you!
Jeff
Same as above....Wes
Thanks guys
Thanks also, did I read correct, for past sales after 1/1/15, not sales prior to 1/1/15?
Thanks.
I shoveled-out my room, moved books from floor to walls, and *might* get a workbench again, do projects which need more than 2 parts.
But I haven't had a workbench since May of 2014!
Somebody call the Whaaambulance!!!
Excellent customer loyalty program Doug. Sorry I haven't bought anything for a long time.
Cheers,
Chip
Thanks.
hopefully you'll resurrect that heathkit AF oscillator. :icon_biggrin:
yes, I just started it yesterday but I am back dating your sales to 01/01/2015
I find it amazing that people are checking out with $500 orders and don't log in?
Or worse yet, don't elect to set up a user name when they check out :dontknow:
If you don't log in, the shopping cart does not know who you are and will not add your current order to your order history
This has happened a few times this week
A $500 order gets you 5% off on your next order
why would you not login or create a user name on a $500 order?
Or increase that 5% by not using it now on your current order
It may go up to 7% that can be used on the order after this order
You have to login to make that happen.
I noticed this bit for some people that are choosing to use the discount
They are applying a 5% discount to a $6 order
Would you rather use that 5% on a $6 order (.30 discount) or a $100 order ($5 discount)?
Not telling people how to use their discounts but I am not sure people are thinking it through on how to take advantage of this
I save more money if you use your discount on a small order rather than use it on a larger order
Just giving people a heads up on something that they maybe did not think about
Login or create a user name when you check out and take advantage of these discounts
It's free money
The men-in black can't find ;'em that way :icon_biggrin:
It's free money
:embarrassed: :sad: :cry:
It's free money
Did you do that?
I can find your sales history and update your login
I think I did, wasn't a real big order but every bit still helps. The sales receipt number is - 47940. Thank you as always Doug.
I don't see that you are set up in the shopping cart data base?
Next time you check out, pick the Create user name option and set yourself up
Add a note to your order and I will update your user name with your past history
I only see one order since 01/01/2015
I just had a customer check out with a $983 order and they did not set themselves up with a user name
There's 9.83% off towards the next order that is lost :dontknow:
