Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: fdesalvo on August 14, 2015, 04:21:15 pm
Title: 5E9-A Trem Groudning Questions
Post by: fdesalvo on August 14, 2015, 04:21:15 pm
Ello, ello!It's been quite some time, gang. I hope you all are doing exceedingly well.I'm about finished amassing my components, but I have a question or two. I'm not using the brass grounding plate, but have a few grounding points for the preamp and power section a'la Hoffman. Where do I ground the trem speed pot and foot switch jack? Thanks!
Title: Re: 5E9-A Trem Groudning Questions
Post by: HotBluePlates on August 14, 2015, 07:26:47 pm
The parts your mentioned are connected to a specific tube in that amp (using the original Fender layout, it's the 12AX7 closest to the output tubes). Ground those parts to the same place that 12AX7 is grounded.
