Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: frank57 on August 23, 2015, 05:42:13 pm
Title: Did I wire this efx loop right?
Post by: frank57 on August 23, 2015, 05:42:13 pm
I wired it like this but I can't remember if the two jacks had to be connected somehow.
Title: Re: Did I wire this efx loop right?
Post by: sluckey on August 23, 2015, 06:30:19 pm
Add the violet wire if you want signal to pass thru if nothing is plugged into the jacks.
Post by: frank57 on August 24, 2015, 07:13:13 am
Does the purple wire make the preamp signal pass through without activating the jacks?
Post by: sluckey on August 24, 2015, 09:48:23 am
I would probably use a yellow wire.
Post by: frank57 on August 27, 2015, 12:17:03 pm
What about this idea? Is this better or worse?
Post by: sluckey on August 27, 2015, 12:58:36 pm
Or maybe this?
