Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: rhodco on September 14, 2015, 08:12:13 pm
Title: Another Princeton Reverb Build w/ mods
Post by: rhodco on September 14, 2015, 08:12:13 pm
Here is the beginning of my Princeton Reverb build using the Hoffman parts (mostly). Some lessons I've learned so far are as follows:
#1). You can see from the photos that I opted to not use a permanently attached power cord. Instead, I used a hacksaw and file to enlarge the round hole on the far back corner for the A/C cord into a rectangular opening for my detachable A/C cord socket. The only problem with that idea is I failed to consider the back cabinet panel will cover that corner and block access to the socket.
Solution: On this build I will have to mount the back cabinet panel about an inch or so lower than normal. In future builds, I will either need to plug that hole and cut a new rectangular opening as close as possible to the back plate, or try to find a chassis already cut for this.
Title: Re: Another Princeton Reverb Build w/ mods
Post by: rhodco on September 14, 2015, 08:24:35 pm
#2). Use only Alpha potentiometers, or the high quality CTS with brass stems. Shortly after I installed the front panel pots, I started noticing a huge difference in feel between the lone Alpha 250Kl on the far right for Tremelo Intensity, and all the others. The Alpha had the same smooth feel as my original Fender Princeton Reverb pots. But the others were CTS plastic stem pots that not only wobbled when they were turned, but were sticking and gritty-feeling as if something rough was rubbing on the inside.
Solution: After cleaning them with DeOxit D5 and working them back and forth a little, I concluded that these were just not going to be acceptable so I removed them and ordered replacements of a higher quality. Only the Alpha on the far right remains installed at this point.
Post by: rhodco on September 14, 2015, 08:44:31 pm
I also installed a hinged dust cover on the ext. speaker jack. It's easy to flip open when I want to plug in, and it covers the only rear jack that won't be used much.
#3). The BOM shows I need 14 "#4 Keps Nuts" and 14 "#4 X 1/4 inch" screws for mounting "Tube sockets, Cap bracket". The parts list shows I got exactly 14 each of the #4/40 Keps Nut and #4/40 screws. The only problem is there are 7 (count 'em) tube sockets. 2 screws and nuts each, plus another 2 screws and nuts for the cap clamp = 16 (Sorry Doug) not 14.
Solution: I was able to scrounge up another couple of screws and nuts to finish the job, but the lesson is to order 16 next time instead of 14.
Post by: sluckey on September 14, 2015, 08:44:39 pm
It's funny how the expensive CTS pots have a cheap feel and the cheap Alpha pots have a good feel. I prefer Alphas but you can't always get what you want, especially for a tremolo circuit.
Post by: rhodco on September 15, 2015, 11:01:33 pm
More progress today, though it was two steps forward and one step backward all day. Lessons from today:
#4). Mounted my Allen TO-20 Heavy Duty output transformer and threaded the wires through the grommets. Mounting screws fit the chassis holes, but just barely. They could be drilled just a little farther apart next time. As soon as I began to work it into place I realized the cap clamp was in the way. First photo shows where I had to unscrew the clamp, turn it 180 degrees, and mount it again. Next photo shows where I realized the clamp screw was facing an awkward direction making it very hard to get to so I removed the screw and nut, then installed them in reverse.
Solution: Next time, pay more attention to the photos provided by others. I could have saved a lot of time by just looking at how Hoffman and Scaggs had mounted thiers. Duh.
Post by: rhodco on September 15, 2015, 11:11:44 pm
#5). For some reason, I thought the turret boards and chassis came with mounting holes already drilled. Just more work for me to do I guess, but I didn't think it would be THIS much trouble. My idea for how to do this was to estimate where I wanted my holes in the board by looking at photos from the other builds. Drilled holes and mounted hardware, no problem. Now the tricky part... how to drill chassis holes that line up exactly.
My solution was to paint the bottom of each screw with fingernail polish, press the board down into place, remove the board from the chassis, and just drill holes where the red dots were. Seems to make sense until you actually try it.
Post by: rhodco on September 15, 2015, 11:17:11 pm
Only problem is that the holes ended up being off, way off, like about an 8th of an inch in some spots..... Hence the round file and ugly holes afterwards to get them all to fit in at the same time. I would like to know of a better way to do this if anyone has a suggestion. This took way too much time to do it the same way again on the next build.
Post by: PRR on September 15, 2015, 11:56:24 pm
The board bottom is near-flat?
The dummy way is to lay it in the chassis and mark the holes with a pencil. Pencil must be perpendicular!
To be more accurate, drill one hole, run a bolt through (still flat to the chassis) and check the opposite corner hole. If OK, drill that and screw it. Now you can drill the other holes through the holes in the board, using it as a guide-plate. (If very fussy, drill 1/32" smaller to avoid wearing the board-holes, then enlarge after you remove the board.)
Painting the screw-tip "should" work, except they probably aren't quite square or centered. If long, they come down well off the proper place. Also the blob of paint is likely to hit more on one side or the other, making an off-center blot. This can work but may need several tries and corrections.
Do not feel bad. I ordered two bolt-on resistors, then two more. I measured one resistor carefully, marked for all 8 holes, drilled pretty close. The first resistor, I knew I'd slipped and I had to rat-tail file a bit. The next one would not fit, though the hole was dang near perfect. Finally slapping myself into sense, I measured all four resistors. The second batch were a good millimeter off from the first! Between my slips and my idiocy (not checking b4 drilling) it was a long session with the file.
Post by: p2pAmps on September 16, 2015, 05:34:46 am
I did the drill method PRR talked about myself and it lined up perfect.  of course I drilled out the turret board first :)   Your amp looks good so far and these PR are great.  I have built two and couldn't be happier...
Cheers
Scaggs
Nashville
Post by: EL34 on September 16, 2015, 11:12:55 am
Good job so far.
My board install instructions tells you how to do the board mounting holes  :icon_biggrin:
That's just one of the documents under each board on the library page
Here's the direct link
http://el34world.com/Hoffman/instructions.htm (http://el34world.com/Hoffman/instructions.htm)
There's no one place that is idea for every chassis and so you have to plan where those board mounting holes should be placed
Transformers and other objects can be on the backside of the chassis and you may have to shift those holes arouind to clear those objects
It pays to look at all the build info first before starting
I have most of the Alpha values in stock for Fender type amps
3mra is not available in alphas
The plastic shaft CTS post work fine, but I like the Alpha pots better
Post by: rhodco on September 21, 2015, 09:37:05 pm
More progress, and more lessons learned. Received my Alpha pots, and the CTS brass shaft 3Meg pot. They all have a much better feel to them. Taking Doug's advice, I have installed some old Groove Tubes in the sockets before soldering up the pins so they will align easier. My cheap soldering iron was too hot and started melting the PVC insulation at a few points so I broke down and bought a Weller soldering station with variable temp like the one I used to have at work years ago. Quality tools are well worth the investment.
Trying to keep my wires running along the same lines as the example photos. Clear heat shrink tubing on the coax cable allows visual confirmation that my center conductor is not touching the shield.
Post by: rhodco on September 21, 2015, 09:43:31 pm
Laced up the board with solid copper wire, but realized that copper is a soft metal so pulling it tight only stretches it. That's why I also soldered some spots in the middle of long runs to hold the wire pairs together.
Post by: p2pAmps on September 21, 2015, 09:59:22 pm
Looks pretty darn good to me...  Keep the pics coming...
Post by: rhodco on September 21, 2015, 10:00:46 pm
Planning to finish wiring up the tube sockets and potentiomters, and double check all the wiring BEFORE I install the board and begin adding components to it. Lots of the wires shown are only connected on one end so far. I had to use a little yellow electrical tape to hold one of the coax leads in place. It probably wont be needed by the time I am ready to install the turret board. I guess it wouldn't hurt to leave it, but trying to be aware of the fact that it will get pretty hot in this enclosed space when it is closed up and rockin hard. Don't want to leave anything that could burn.
Just one note of interest here concerning heat - on my other Fender '65 Princeton Reverb RI: I did some testing after I upgraded the OT and re-tubed it last year. I placed a magnetic base thermometer on the faceplate while it was tilted back 45 degrees to see how hot it would get during typical band practice sessions. Air conditioned environment (about 75 degrees air temp), and run at about middle volume (4 to 5) for a few hours. Over several weeks it averaged out at about 135F degrees after warm up, with some peak times at a little over 140F. I don't know how that will compare to this one, but it gave me some baseline data for what a normal amp should run at with bias set to 23mv.
I love to experiment.
Post by: p2pAmps on September 21, 2015, 10:03:35 pm
I found that doing all the wiring first before any component install was the best for me.  Mount that turret board and get all your wiring nice and clean then the fun stuff will be easier IMHO.  No one right way just saying what I did...
Which trannies are you using?
Post by: rhodco on September 21, 2015, 10:22:14 pm
I'm using the power trans and reverb trans that Doug shipped to me (not sure of the brand he stocks), but I'm using the TO20 that BillM and David Allen developed as my OT. I tried it in my other Princeton Reverb and became a believer right away!
http://billmaudio.com/wp/?page_id=545 (http://billmaudio.com/wp/?page_id=545)
It gives a more rich sounding bass and makes the mids seem more 3 dimensional. Hard to describe but I definitely noticed the difference when I put it in. When I took it out to use for this build and put the original stock Fender transformer back in, I could tell the difference again. It sounds kind of flat now. Not as much life to it.
I know now what I'm going to have to do after this build is finished.... I'm getting another T020, another turret board and components, and I'm going to gut that Chinese PC board Reissue Fender. It's going to get a Hoffman Heart transplant!
Post by: Willabe on September 21, 2015, 10:46:05 pm
......  I'm going to gut that Chinese PC board Reissue Fender. It's going to get a Hoffman Heart transplant!
Now your talkin'!    :laugh:
Post by: Willabe on September 21, 2015, 10:49:56 pm
Probably has more current available in the B+ wind? But there could be a trade off for leads, less sag/compression.
Post by: EL34 on September 22, 2015, 06:20:16 am
The build is looking good
Post by: sluckey on September 22, 2015, 10:54:46 am
I noticed in another thread that you asked mscaggs about the blue and brown wire connections on his OT. Since you guys are using different OTs, his connections for those wires may not be the same as yours. It's a 50/50 chance the wires will be connected properly.
I also noticed you have already trimmed your blue and brown wires. If you need to reverse them they may not reach. That's OK. There is another very easy way to accomplish the same thing in the Hoffman PR. See the white wires connected to pins 6 of the 6V6 sockets? Just reverse them at the board connection.
You may want to keep this thought in the back of your mind when you power up the amp.
Post by: p2pAmps on September 22, 2015, 11:00:17 am
Good call Steve
Post by: EL34 on September 22, 2015, 12:19:59 pm
On the Output transformer, if you are not sure which plate wire goes to which plate, leave the wires full length for now so you can reverse them later if they are not correct
I have the note shown above in the build instructions
The link above is below every one of my turret board documents on the library page
Post by: rhodco on September 22, 2015, 10:39:50 pm
Thanks for the tips. Since it was a drop in replacement for my other amp and the colors matched up with that transformer fine, I would assume the windings are the same. I guess we will soon see. I'm planning to leave the speaker negative feedback wire off until I confirm it is correct (see Doug, sometimes I do follow instructions!).
I'm taking my time wiring all the tube sockets and pots, trying to route the wires around carefully so it follows your photos. One thing I learned with the stranded wire is that if I use a clamp and small magnets as weights to hold the wire in the position I want while soldering the end, it will harden and stay in that shape after it cools. Makes it easier to lay some wires down low, and router others up high. I'm waiting till last to run the green filament wires because I want them to fly over all the others.
I've ordered the speaker, decided to go with the 12" Warehouse WGS G12C/S 8 ohm 75 watts American Vintage and see how that feels.
What do you guys like for tubes? I have some fairly new Tung Sol 6V6GT's, and a pair of EH (rebranded as Groove Tubes) 6V6's that I pulled from another amp. I was going to try JJ's but read comments about them sounding a bit harsh when pushed to breakup. I also have a JAN-Philips 12AT7WC for the reverb, and some other 12ATX7 NOS tubes to try out. I'm using a Sylvania 5751 for V1 in my other Princeton because I wanted something with a lower noise floor, more quiet, but I really can't tell much difference in that amp.
I usually play with a Strymon blueSky for a layer of digital reverb added to the amp reverb dialed in at about 2.5, and a MXR Carbon Copy analog delay with tap temp mod from Molten Voltage. I think it's call a Delaytion. I had to break that open and "mod the mod" because the chorus pot value was way too high to be usable. Changed the 5K for a 500ohm and it's much better now. Me loves to tinker.
Post by: rhodco on September 24, 2015, 10:12:05 pm
Long day today, but I enjoyed every minute. Finished wiring all tube sockets and pots. Left the tremolo and negative feedback wires loose for now. Vacuumed out all the little fragments and spray washed the interior with flux remover.
Post by: rhodco on September 24, 2015, 10:23:18 pm
For the filament wires, I find that twisting a pair of wires using two different colors makes it easier to keep them all the same polarity across each tube.
Post by: rhodco on September 24, 2015, 10:28:10 pm
The most time consuming part has been keeping all the wires routed so that they don't lay against each other. When they have to cross, I try to get them crossed perpendicular to each other so that the contact is as small as possible. The pot wires and filament wires fly high, as well as the A/C power input.
Post by: rhodco on September 24, 2015, 10:33:43 pm
Tomorrow is set aside for double checking all the previous wiring before going on to the next phase.
Post by: Willabe on September 24, 2015, 10:40:25 pm
Looking good.  :icon_biggrin:
What's covering the 2nd speaker jack?
Post by: rhodco on September 24, 2015, 10:46:12 pm
It's a Switchcraft 515X dust cover. I put those on jacks that never get used to try and keep dust out of the pots inside.
Post by: Willabe on September 24, 2015, 10:48:15 pm
Hmm, thanks.  :icon_biggrin:
Post by: EL34 on September 25, 2015, 07:29:51 am
Looking good
I put the parts on the board and do the pot wires last
Hopefully your wires do not get in the way too much when you add the parts to the board
Post by: rhodco on September 25, 2015, 06:30:34 pm
I put the pot wires on before components because I thought it would work better for me to get the wires wrapped around the turrets first. Now that it's done, I think it would be better to do it your way and just push the wires down into the turrets from the top. Most places there is enough room for that. Only at the bias trim pot would I have to wrap around the turret low. BTW - I really like your choice of solid core hookup wire. It is easy to work with, but stiff enough to stay put where I've routed it when I'm done.
When I finished mounting all the components, I found that I still have a 33K resistor and a .022 cap left over. It took me a while to figure it out, but I think the 33k resistor was for R2 in case I only had one input jack. I used 2 of the 68k resistors in that position instead (R2 and R3). The cap mystery took a bit longer to solve, but I think now it is because C15 and C22 are actually the same component. On the PREAMP and REVERB schematic, C15 is the last component going out to the PHASE INVERTER, but on the PHASE INVERTER schematic, that same cap is labeled C22 coming in from the preamp. According to the board layout, they are both one and the same. However, since they are both listed on the BOM and parts list, I got them both.
Please correct me if I'm wrong, but I think that explains it.
Post by: rhodco on September 25, 2015, 08:19:29 pm
Assembly finished. Looking for mistakes now...
Post by: Willabe on September 25, 2015, 09:13:34 pm
You might already know about these but in case you don't;
Doug put this together and shows a great way to double check a build;
http://el34world.com/Forum/index.php?topic=17701.0 (http://el34world.com/Forum/index.php?topic=17701.0)
This is from Sluckey's web site, lamp limiter, a must have tool for 1st fire up on new builds, rebuilt amps and 1st test on an old or non-working amp;
http://home.comcast.net/~seluckey/amps/misc/Amp_Scrapbook.pdf (http://home.comcast.net/~seluckey/amps/misc/Amp_Scrapbook.pdf)
 It's looking real good!        :icon_biggrin:
Post by: rhodco on September 25, 2015, 09:47:59 pm
Thank you. Yes, I built a limiter box like that a few years back. Just put a 150 watt clear bulb in it. I can see the filament glow more clearly than with a frosted bulb.
Post by: Willabe on September 25, 2015, 11:06:49 pm
Great! Good looking build!   :icon_biggrin:
But, 150w is too big for most amps, it will let too much current through before you can shut it down. Go with a 60w or 100w.
The wattage of the bulbs filament matters when used in series with the amps ACV power supply(PSU) input draw, it acts as a resistor(R) in series with the PSU.
So the more current pulled through that 'R' the more it will limit the current draw. We see it as it lights up the bulb, so if there's a short we can shut down the amp before it fry's.
You can use frosted or clear but if the bulbs wattage is too big it won't light up enough with either unless it's a direct short.
A good way to get see this is to fire up a 'working' amp and see how the bulb lights up at 1st start up but then dimes to almost nothing.
Post by: Willabe on September 25, 2015, 11:59:52 pm
Don't forget to look at the other link I posted from Doug, to double check your wiring, it works great!  :icon_biggrin:
Post by: EL34 on September 26, 2015, 08:11:58 am
As you are double checking using my link above, make sure you check this area  :icon_biggrin:
Post by: rhodco on September 26, 2015, 10:24:46 am
Wow! I totally missed that ground wire. Thank you Doug!
Willabe, thanks for that tip. I will change out that bulb before fire up time.
You guys are a great help!
Cliff
Post by: rhodco on September 26, 2015, 01:37:22 pm
OK, first power up had no smoke, no bang, but voltages are puzzling. The light bulb limiter didn't even glow, but the front panel lamp comes on. I get less than a volt DC on pins 1 and 6 of the preamp tubes. I unplug from the limiter and plug straight into normal AC outlet. All AC voltages check normal, but very little DC volts. Then it occurs to me... the "Instructions" page reads:
"Powering up the amp and setting the bias
After all connections have been made and double checked Power up the amp with no tubes in the sockets. Using a multi-meter set on DC volts, check to see if pins 1 and 6 on the pre-amp tubes have high voltage. Check pins 3 and 4 on the power tubes to see if they have high voltage. Pins 7 and 9 on EL84 power tubes"
How can I have high DC voltage when there is no rectifier tube? Looking at the power supply schematic, I don't see how I could unless D1 is acting as a half-wave rectifier. Before I chase this any further, could someone please confirm that "no tubes" means no tubes at all, or is that with the exception of the V7 power supply 5U4G?
Thanks,
Cliff
Post by: EL34 on September 26, 2015, 02:12:39 pm
You need to have a rectifier hooked up to get DC on the tubes and do your DC voltage checks
The bias circuit has it's own rectifier, which is a single diode and so you will be able to read the negative bias voltage on the power tubes
Post by: rhodco on September 26, 2015, 02:34:08 pm
Thank you. That's what I thought, just wanted to be sure before I put the rectifier tube in. So far, so good.
Post by: sluckey on September 26, 2015, 02:53:23 pm
Expect your B+ voltages to all be high. At this point you're just interested to see that you have B+ on all the filter caps and on all tube socket plate pins. And of course, no smoke or sizzling sounds or funky smells.  :icon_biggrin:
Post by: rhodco on September 26, 2015, 03:58:40 pm
Cleared the bench of all my construction clutter, got my schematics and charts handy. Plugged in a reverb tank and 8 ohm speaker under the bench.
I took care of that missing ground wire, and rerouted my yellow can cap A wire to run over the star ground lead instead of under it.
Also soldered an alligator clip to the end of my negative feedback wire until testing is finished. Then, I'll cut that off and solder it down.
Post by: rhodco on September 26, 2015, 04:05:27 pm
Checked my tube stock and realized I have plenty of 5AR4's, but no 5U4G rectifiers. even though it might work, I decided not to chance it.
I've ordered the correct tube for this design and will wait for it before I go any further. Everything else looks GO for launch.
Post by: EL34 on September 26, 2015, 04:39:03 pm
Hard to say from here, that's what this post is for
You have to do it on your end
The missing ground wire would not be highlighted yellow after you did the check
It would have been easy to spot on your diagram
There could be others you missed also
Here is the link again for the double check routinehttp://el34world.com/Forum/index.php?topic=17701.0 (http://el34world.com/Forum/index.php?topic=17701.0)
Post by: sluckey on September 26, 2015, 04:53:30 pm
A lot of PRs use a 5AR4 rather than a 5U4. Socket wiring is the same. I would rather have the 5AR4 because it draws less filament current and has a separate indirectly heated cathode which means it has a longer warm up time.
http://el34world.com/charts/Schematics/files/fender/Fender_princeton_rev_gz34_aa1164.pdf (http://el34world.com/charts/Schematics/files/fender/Fender_princeton_rev_gz34_aa1164.pdf)
Post by: rhodco on September 26, 2015, 05:18:36 pm
Thanks Sluckey. This is the schematic I have for my other PR. Power supply uses a 5AR4 but that circuit uses two diodes between the transformer and pins 4 and 6 where the Hoffman design doesn't. I thought the difference in design was the reason why a 5U4G is called for?
Post by: rhodco on September 30, 2015, 11:02:25 pm
Got home from band practice and found my rectifier tube waiting (thanks for the prompt shipment Doug). I plugged it in, said a prayer, and turned on the power... 437VDC on the tubes... 6.3 VAC on the filaments... but only -41VDC bias voltage. The notes said I should have at least -50 but, ok maybe that's close enough. Power off.
All tubes in, power on, and the bias voltage across the 1 ohm resistor sits on zero. After a few seconds I start wondering, then here it comes! Creeping up... 7mv...15mv... 19mv... It's fluctuating but when I turn the reverb and vibrato all the way down the fluctuations settle to within a range of about .8mv. Once it seems to be settled I tweek it up to about 23mv and leave it there a while. I plugged in my tele and played a while to warm it up... all while keeping an eye on the meter. Finally set it to 26mv and watched a while to make sure it stayed there.
I have to say that the noise floor on this little amp is remarkably quiet, but it gets plenty loud when pushed. The sound is classic Princeton Reverb, with maybe a little too much reverb. I'll pull the 12AT7 from V2 tomorrow and try a 12AU7 in its place. That should bring it down a little I think. I don't hear much of a difference when I pull the negative feedback wire off and put it back on, but I'll do more testing with that later.
I want to thank all the guys that offered suggestions, and thanks Doug for spotting that missing wire for me! It all turned out great and the sound is glorious! My cab comes in later this week so I should be able to put it all together then and post a video here.
Post by: Willabe on October 01, 2015, 12:23:49 am
 :bravo1:
Post by: purpletele on October 01, 2015, 01:28:06 am
Nice work!
Post by: EL34 on October 01, 2015, 06:25:03 am
nice!
Post by: Willabe on October 01, 2015, 08:49:35 am
You have bias vari trem, it vari's the -bias.
Post by: rhodco on October 01, 2015, 12:09:07 pm
I'm starting to think now that it's not such a good idea to replace the 12AT7 reverb driver in V2 with a 12AU7. That's just too much of a drop down in gain and I don't know how the difference would affect the rest of the circuit.
Instead, I'll use a JAN-Phillips 12AT7WC for V2 and try a 5751 in the V1 position. I also have another reverb tank to experiment with.
ETA on the Mather cab is Friday  :happy1:
Post by: Willabe on October 01, 2015, 12:28:00 pm
No it will be fine.  :icon_biggrin:   Guy's do it all the time, very common way to reduce/tame the verb's depth.
Try that too.  :icon_biggrin:
 :mail1:           :blob8:
Post by: rhodco on October 02, 2015, 04:42:23 pm
FedEx Home Delivery paid me a visit today...
Post by: rhodco on October 02, 2015, 04:44:51 pm
Looks like Mather did another great job. Quality is outstanding. Inside top looks well shielded. All I had to do was install my speaker and bottom velcro straps for the reverb tank. (Thumbtacks are there just until the glue dries.)
Post by: rhodco on October 02, 2015, 04:57:21 pm
Now that I've been burning it in, I've noted that:
A). The 12AU7 really is fine as a reverb driver in V2, but I still only turn Reverb up to about 2 or 3 at the most.
B). The MOD reverb tank I'm testing with seems more bouncy, the springs feel more firm. My friend Jim likes the sound but I'm not a big fan. I think I prefer the longer softer decay in the Accutronics reverb tank in my other PRRI. Will probably swap them.
C). The 470K resistor I substituted for the 1 meg in the tremolo circuit is just fine. Tremolo sounds really good. I only need intensity dialed up to about 3 or 4 at the most.
D). Most important of all, no popping, no hissing, no strange noises of any kind. Remarkably quiet when the volume is turned up with no input signal.
Will do some side-by-side testing next week and make video. Hoffman Hand-Wired Princeton Reverb vs. Fender '65 Princeton Reverb Re-Issue.
 :guitar1
Post by: uki on October 03, 2015, 08:15:34 pm
Looks really good this amp, very good work !
Post by: eleventeen on October 03, 2015, 08:43:31 pm
Excellent news! A nice BF Princeton Reverb is pure fun, plain and simple.
" Power supply uses a 5AR4 but that circuit uses two diodes between the transformer and pins 4 and 6 where the Hoffman design doesn't. I thought the difference in design was the reason why a 5U4G is called for?"
Those diodes protect the amp against a very, very rare failure mode of the rectifier. For practical purposes, they have no particular function, nor does the amp know they are there. Leave them as is. (They have nothing to do with choosing a 5U4 over a 5AR4. Forget about them)
A 5U4 is a directly heated rectifier tube that uses 3 amps filament (properly called a filament) current and drop about 60 volts in use.
A 5AR4 is an indirectly heated rectifier (takes a bit longer to warm up and start conducting) that uses 2 amps heater current (properly called a heater-----but nobody except the very picky really cares about the distinction) and drops more like 25 volts in use.
Some people like the idea having the slow warmup time of a 5AR4, to allow the preamp tubes to warm up before full-on B+ is applied. There's some validity to that argument, nothing to go crazy about.
Their functionality is very close. A 5AR4 will raise your B+ by some 35 volts, you do not seem to need that if you are at +473. A 5U4 is probably quite a bit more rugged a tube and usually cheaper. I'd stay with the 5U4, you don't need 500+ volts on your 6V6 tubes.
Congratulations!
Post by: eleventeen on October 04, 2015, 10:38:39 am
"A). The 12AU7 really is fine as a reverb driver in V2, but I still only turn Reverb up to about 2 or 3 at the most.B). The MOD reverb tank I'm testing with seems more bouncy, the springs feel more firm. My friend Jim likes the sound but I'm not a big fan. I think I prefer the longer softer decay in the Accutronics reverb tank in my other PRRI. Will probably swap them."
At your leisure, I would be interested in your report of 12AU7 driving the Accutronics (hopefully in this amp) and where you set the reverb knob  (differently) with that combo.
Continued congrats that you are working!
Post by: rhodco on October 04, 2015, 09:42:07 pm
Finished burn in and bias adjustments. I've noticed that the Hoffman Princeton Reverb design has a more lively tremolo and reverb circuit. I even swapped tubes between these two amps over the past few days to compare and it's not the tubes, it's the amp. The Fender PRRI seems a little weak and anemic in comparison. Fortunately, there is plenty of room to dial it up or down in either amp according to taste. Using the  12AU7 in place of the 12AT7 only tamed reverb slightly in the Hoffman PR, where the same tube exchange in the Fender PRRI made much more of a difference.
Overall, the Fender PRRI sounds good... more jangle, more chimey. But, the Hoffman PR design seems to have more of a strong and tight low end. Classic Princeton Reverb tone, but with more clean power in reserve... at least it seems that way. Frankly, they both sound great. It's just that they have different voices, like two great singers. Each has characteristics in its tone that are appealing.
Most importantly, I paid about $900 for the Fender two years ago and I've had to fix it twice. The Hoffman cost me almost as much to build myself but I used good quality parts and had fun doing it. Hopefully, this hand-wired amp will prove more reliable than the Fender in the years to come. I plan to use both in a stereo rig for a while and see how they hold up.
Post by: rhodco on October 04, 2015, 09:52:35 pm
" At your leisure, I would be interested in your report of 12AU7 driving the Accutronics (hopefully in this amp) and where you set the reverb knob  (differently) with that combo. "
In this amp, the Accutronics reverb tank is my favorite. The decay is a little softer and slower to fade away than the MOD tank. The 12AT7WC that I used at first seemed a bit strong since I found myself setting the reverb level between 2 and 2.5. After switching to the 12AU7 for a while I was surprised to find that I'm still in that range of between 2 and 3, only I can tolerate 3 better now.
Post by: EL34 on October 05, 2015, 07:17:11 am
The amp looks good
Post by: mresistor on October 05, 2015, 09:48:25 am
You could use a 5R4 rectifier in the princeton, it drops a few more volts than a 5U4 and filament current is lower at 2 amps.
http://www.fourwater.com/files/fullrect.txt (http://www.fourwater.com/files/fullrect.txt)
Post by: rhodco on October 05, 2015, 11:17:06 am
Interesting idea. So, it's more energy efficient? What's the downside?
Post by: Willabe on October 05, 2015, 11:41:48 am
No, it's less efficient, it drops/losses more volts.
It's less efficient, it drops/losses more volts.
But that's for max dcv, in your case if you want to drop a few more dcv's it's good.
Post by: eleventeen on October 05, 2015, 12:36:22 pm
"You could use a 5R4 rectifier in the princeton, it drops a few more volts than a 5U4 and filament current is lower at 2 amps."
Excellent idea. More for the lower fil current than the measly 13 volts. It will supposedly drop 13 more volts than a 5U4. Worth the trouble?
(http://i172.photobucket.com/albums/w32/ttm4/5_volt_rectifiers_zpsaez9m1ej.png) (http://s172.photobucket.com/user/ttm4/media/5_volt_rectifiers_zpsaez9m1ej.png.html)
Post by: mresistor on October 05, 2015, 03:07:39 pm
5R4GA drops 17-23 volts more than a 5U4,   and to me that is considerable when running 20-30 volts over what 6V6's like to see. I'm concerned with the power tube longevity. Some people aren't.
Post by: SILVERGUN on October 05, 2015, 04:15:47 pm
One change that I've made and have now stuck with through the last 2 builds that had reverb was to eliminate the cathode bypass cap on the 12AT7 reverb driver tube.
I've found it to achieve a "softer" reverb sound with a much more usable range throughout the pot.
Thanks again PRR.
Keep up the great work rhodco.
Post by: rhodco on October 05, 2015, 07:06:01 pm
Thanks, but I'm still confused about the choice for rectifier tube.  :w2:
So I've done some research....
The Hoffman PR design calls for a 5U4G,
The Fender 1964 design for the AA1164 called for a 5U4GB,
but then they replaced it with a GZ34/5AR4 using the same power transformer.  :dontknow:
Would you guys agree with this quote? - " Any amp that uses a 5U4GB as OEM, can easily go to the 5AR4/GZ34. It's a drop-in replacement. Now, which rectifier is "better," depends on amp, speaker(s), and what tone you are after. The GZ34/5AR4 has a higher B+ potential and less forward voltage drop (10-15VDC) = stiffer tone. Better bass, better transients.
The 5U4GB usually has 10-20VDC less final B+ in the same amp. Much more forward voltage drop (30-40VDC). Makes for more sag in the tone. A bit more "slow quality" to the transients. Some ppl like this in certain amps. Esp those with very efficient speakers, who are looking of a more Bluesy tone.
Then, there is this guy who says the GZ34 is better and should not be swapped with a 5U4 ...
https://www.youtube.com/watch?v=0f8OiTrnnUA (https://www.youtube.com/watch?v=0f8OiTrnnUA)
Post by: mresistor on October 05, 2015, 07:37:31 pm
As Uncle Doug says, the AA764 (july 1964) had a GZ34 in it. That predates the AA1164 circuit. And according to Doug and many others I've read the PR used either tube until '69' or '70.  My 1979 Fender PR uses a 5U4GB in it from the factory.
I think it's important to pay attention to plate voltages on the 6V6's. If you pop a GZ34 in there and the result is 500V of plate voltage it is not a good thing.
A lot of people will tell you that modern tubes can take that abuse, but is it really a good idea? That's why I was talking about tube longevity. Even though a modern 6V6 , or a vintage one for that matter, can take the high plate voltage, it comes at a cost. And that cost is how long it lasts.
Of course cork sniffers might say that the tube will sound better and have much more headroom for certain types of music genres. Well that's OK. Run it like that and replace your tubes more often, if you got the bux it ain't a biggie.
On the other hand, I feel that the 6V6 tube is more suited for plate voltages of 390-430. I like the sound and feel of them at this level. Especially in my PRs.
Will any of these rectifiers work, and work well. Yes.   So it really is personal preference.
Post by: p2pAmps on October 05, 2015, 07:39:28 pm
On the other hand, I feel that the 6V6 tune is more suited for plate voltages of 390-420. I like the sound and feel of them at this level. Especially in my PRs.
I am running an old Amprex 5AR4 in my PR (Hoffman).... 410v on the plates, no issues what so ever.
Post by: mresistor on October 05, 2015, 07:44:45 pm
I'd like to try one of those Amperex rectifiers. However, my wallet isn't that deep. But it's nice to learn that it's not causing a huge increase in HV.
Post by: p2pAmps on October 05, 2015, 07:46:36 pm
My 5AR4 was a freebie and been sitting in the stash for 12 years.  I finally decided to pull it out.
Post by: sluckey on October 05, 2015, 07:51:57 pm
Some PR AA1164s call for a 5U4...
http://el34world.com/charts/Schematics/files/fender/Fender_PRINCETON_REVERB_AA1164.pdf (http://el34world.com/charts/Schematics/files/fender/Fender_PRINCETON_REVERB_AA1164.pdf)
Some PR AA1164s called for 5AR4/GZ34...
If your PT 5VAC winding is rated for 3A (or more) you can use either a 5U4 or a 5AR4 (or any other 5V rectifier tube).
If your PT 5VAC winding is only rated for 2A you cannot safely use a 5U4.
The difference in B+ voltage between the two types is not harmful to your PR. Use whichever you prefer as long as you honor the current rating of your PT's 5V winding. My preference is the 5AR4 for all the reasons Uncle Doug stated on that video.
Post by: rhodco on October 05, 2015, 10:56:35 pm
OK... then someone please correct me if I'm reading this wrong. It looks like the 125P1B power transformer is only rated at 2 amps, and therefore should NOT be used with the 5U4G ...?
Post by: DummyLoad on October 06, 2015, 12:09:31 am
correct. you should not use a 5U4Gx with that transformer. it will work, but will reduce transformer life, it will run hotter than it already does, it will sag, and IMO sounds like crap. use a GZ34.
if you must use a 5U4Gx, then use one of these. (http://www.classictone.net/40-18027.pdf) it's beefed up a bit and has a recto winding rated at 3A.
personally, i prefer SSR and better filtering, IMO sounds more like a twin reverb in smaller, manageable package. < flame on :p >
Post by: mresistor on October 06, 2015, 08:46:15 am
All the schematics I see show 410V on the plates of the PR.  If a person wants his PR playing and sounding like an original, shouldn't one strive to get as close to that as possible? Pointing out a slight difference in the circuits, the AA764  PT secondary shows 330V whereas the AA1164 and AB1270 shows 340V.
The 6V6, especially EH and JJ new production are touted as being able to handle higher plate voltages and supposedly won't harm them, true, they'll take it,  but also true is they may suffer a reduction in service life.  Another thing to consider is some of the caps in older gear, and even some newer ones,  aren't rated over 450V.
Has anyone used any of the new production 5AR4/GZ34 for a significant length of time and have experienced problems with them? Which ones are good and which ones are not so good IYO? I've read some mixed reviews on them. If you're using one, what brand is it?
DL that transformer is great; and the 40-18019 also has a 3A rated rectifier winding. But it's not as beefy, probably more like an early original? I wish they would make one with a higher rated 6.3vac filament winding. 3 to 4 amps would be nice for using 6L6, EL34, etc.
Post by: sluckey on October 06, 2015, 09:03:55 am
Read Note 1 at the top of the schematics.
Post by: rhodco on October 06, 2015, 09:32:12 am
 :help:
The more pressing and pertinent question for me right now is...
Why does this Hoffman Princeton Reverb kit, design, and parts list, specify a 5AUG rectifier with a 125P1B power transformer when the PT is only rated at 2 amps on the 5V winding?
Post by: EL34 on October 06, 2015, 09:53:16 am
See the PR layout link below
That is what I use to design all the boards
It shows a 5U4GB rectifier tube
Post by: p2pAmps on October 06, 2015, 09:57:50 am
I say read this again and again...
Post by: EL34 on October 06, 2015, 10:02:25 am
I have sold 100's of those 125P1B trannies over the last 15+ years I have been stocking them
No issues so far
I would get so wrapped up in all this
Is the amp working?
Post by: sluckey on October 06, 2015, 10:20:17 am
A 5U4 wants 5V@3A. The 125P1B transformer you have listed in the PR BOM is only rated for 5V@2A (according to your transformer data table). Maybe the 125P1B that Fender used in the '60s was really rated for 3A. Probably was. Classic Tones and AES both list their 125P1B rated for 5V@3A. Maybe yours is rated for 3A also. Could you check?
With the PR becoming so popular lately this issue/non-issue? is bound to pop up again.
Maybe you could just reference this schematic instead...
Post by: EL34 on October 06, 2015, 10:26:44 am
I can change my parts list to a GZ34 no problem
Maybe someone can actually measure the current draw from the rectifier and see what it is in real life?
Post by: Willabe on October 06, 2015, 10:33:11 am
No issues so far
I would say the evidence (real world, in use) shows that the PT you sell is underrated and really has a 3A/5v rectifier heater wind.
Post by: sluckey on October 06, 2015, 10:39:21 am
Perfect solution. Maybe change your Visio/PDF schematic too? Everybody be happy! Until someone comes along and says "but I want to use a 5U4".      :icon_biggrin:
Post by: EL34 on October 06, 2015, 10:43:34 am
I would think that if a winding is rated right at 2 amps exactly and you run it at 3amps, there would be a voltage drop?
Is there a voltage drop running a 5U4GB?
Post by: Willabe on October 06, 2015, 10:48:54 am
But I want to use a 5U4 because it has more sag, BUT I want to use 2/5U4's for even more sag!  :l2:
Post by: sluckey on October 06, 2015, 10:49:09 am
I wonder. That same PT is used in the blackface Champ with a 5Y3.
Just out of curiosity I'd like to know for sure what the manufacturer's rating of Doug's transformer is. It could be that Doug's spec table is wrong.
But it's a non issue for me. The 5U4 belongs in B&W TVs and cheap Silvertone amps.  :icon_biggrin:  There are just too many better choices IMO.
Post by: Willabe on October 06, 2015, 10:55:12 am
Oh, Leo, where are you when we need you?  :sad:
Post by: EL34 on October 06, 2015, 11:00:50 am
I have a amp here with the 125P1B
I'll see if I can get some real life figures from it
Post by: EL34 on October 06, 2015, 11:32:36 am
Ok, I connected a meter in line with the 5 volt winding on the 125P1B transformer and tried 4 different rectifier tubes
I measured AC amps and AC voltage on the 5 volt winding
5V4 - 1.94 amps - 5.26 vac
5Y3 - 1.99 amps - 5.25 vac
5AR4 - 2 amps - 5.24 vac
5U4GB - 3 amps - 5.07 vac
I would say the 5 volt winding is not rated at 2 amps max
It looks to me like there is some cush built into that winding
Post by: rhodco on October 06, 2015, 02:25:15 pm
Thanks guys for all the helpful input. I decided to go with a Tung Sol 5AR4 and biased the amp at 25mv after warm up.
Just out of curiosity, I measured the temp of the power transformer after running it for a while to see how hot it would get. It rose slowly and leveled off at just under 118 degrees F. This was on the bench, not mounted in the cab.
I didn't want to go back to the 5U4G to see how hot it would run the PT. Maybe someone else would like to try that sometime.
