Amp Stuff => AmpTools/Tech Tips => Topic started by: Willabe on September 25, 2015, 08:17:34 pm
A friend just gave me a Tektronix 2445A 150MHz 4 channel scope with a high voltage probe. Looks to be in good shape. :icon_biggrin:
Is this a good scope for tube amps? Anybody familiar with this scope?
From what I understand any scope in the 50MHz range is fine. I just bought a Rigol DS1054Z because it gets rave reviews for having 4 channels and 50MHz. The audio range of most guitar amps is like 10Hz to maybe 20kHz. So 50MHz is well within range.
~Phil
I'm not familiar with that particular scope, but it is more than perfect (as long as you have a 10x probe) for working on any kind of audio gear. You received a great gift. My everyday scope is a 15 MHz Leader LBO-514, though I do have a Tektronix 556 (100 lbs, 44 tubes, 800W). Oh, here's a picture of one stack of my test equipment when I was moving it earlier this year.
Nice looking stack of test gear. :icon_biggrin:
Yes it came with a 10x probe.
A friend from church is coming over this week to show me how to use it.
I was under the impression that a 10x scope probes can't take over 300v and guitar amps regularly go up to 500 or 600 in some cases. I bought a few 100x scope probes so that I can go higher. Anyone want to confirm that for me?
I don't know for a fact. My lbo-514a label on the bnc input says 600V max. My tek p6103 says it's good to 500v. The voltage ratings for your probes should be on the data sheet.
The 2445 Max input voltage is 400V (dc + peak ac) or 800 V pp ac @ 10KHz or less.
Here's the operators instruction manual. You can probably find a service manual also.
http://www.mit.edu/~jhawk/tek2445.pdf (http://www.mit.edu/~jhawk/tek2445.pdf)
Voltage rating on probes depends more on the caps they use than the X-factor.
Since 'scopes don't need more than a Volt to get a full picture, 100X probes may be useful for a 'scope which has little turn-down for large inputs.
Note that the OT plate leads of a 400V DC amp will kick to 700V-800V.
In many practical cases, you do not need a precision probe. 10Meg and 100K gives 100X reduction, stands high voltage, and uncompensated bandwidth is beyond the audio band.
IMHO 1MHz is more than ample for 99.44% of guitar-amp work. 100KHz is often fine. I have used a 19KHz 'scope and learned stuff. With the transistorization of 'scopes, you can't hardly find anything under 5MHz. Bandwidth is a non-feature. Easy controls may be far more useful.
