Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: x44d80 on September 30, 2015, 01:55:10 pm
My son dug out all my old vinyl records. We have equipement to play them, it's just not very good. I was going to buy a old Pioneer, Marantz or Kenwood solid state amp but I started thinking why not just build a tube amp. Heres the problem. The only kits I can find are Dynakit, and one from the Tube Store. Too expensive or too small. I cannot find any info or schematics to build your own. I bid on a Fisher 500 tube amp that needed work but didn't win the auction. The question is would you buy and repair a tube amp or build your own?
Possibilities are endless & mind boggling. Google Williamson amplifier. Can't go wrong with a Dynakit. Numerous old schematics to copy like from Heathkit. I personally like to rebuild
There is always a tube McIntosh
Get yourself one of these:
http://www.ebay.com/itm/Magnavox-Stereo-175-67-Tube-Amp-Amplifier-6V6-12AX7-5U4GB-P-P-Push-Pull-Works-/181887696552?hash=item2a5959fea8 (http://www.ebay.com/itm/Magnavox-Stereo-175-67-Tube-Amp-Amplifier-6V6-12AX7-5U4GB-P-P-Push-Pull-Works-/181887696552?hash=item2a5959fea8)
And, find a nice Heathkit or Realistic stereo pre-amp to go with it. I have a Mag 175 and a Realistic pre-amp, both I've tested and am pleased with the results. I have a Technics SL-1800 direct-drive turntable for the front end. All working, but not assembled into a finished stereo. A friend pointed me to a nice set of table-top speakers that really complement these components. I'll have to get the model number for them tomorrow.
All this would make a great project for your home stereo.
Jack
https://tubedepot.com/products/tubecube-7-stereo-vacuum-tube-amplifier (https://tubedepot.com/products/tubecube-7-stereo-vacuum-tube-amplifier)
http://www.triodeelectronics.com/st70buildkit.html (http://www.triodeelectronics.com/st70buildkit.html)
but there are a bunch of old ones on ebay
http://www.tubes4hifi.com/bob.htm (http://www.tubes4hifi.com/bob.htm)
http://www.triodeelectronics.com/diy35kit.html (http://www.triodeelectronics.com/diy35kit.html)
lots on ebay
http://www.ebay.com/itm/Dynaco-Stereo-70-Tube-Amp-Amplifier-/291573176538?hash=item43e31d98da (http://www.ebay.com/itm/Dynaco-Stereo-70-Tube-Amp-Amplifier-/291573176538?hash=item43e31d98da)
Thanks for the replies and advice. How about something like this?
http://www.ebay.com/itm/ROCK-OLA-414-418S-418SA-JUKEBOX-Tested-Working-TUBE-AMPLIFIER-39310-/331668564651?hash=item4d38fcaaab (http://www.ebay.com/itm/ROCK-OLA-414-418S-418SA-JUKEBOX-Tested-Working-TUBE-AMPLIFIER-39310-/331668564651?hash=item4d38fcaaab)
I don't recommend that specific unit because it does not have a power supply. The power supply is located on another unit. However, that same seller has other Rockola amps for the same price that do include a built in power supply.
Something to consider... These old juke box amps 'may' be designed for a ceramic phono cartridge. If so, you will need an external preamp to use a magnetic cartridge.
Good advice. Thanks so much!
