Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: rlh5599 on May 10, 2016, 06:58:35 pm
Title: Tranny trouble...
Post by: rlh5599 on May 10, 2016, 06:58:35 pm
To all you fine wizards: does anybody rebuild dead power transformers, "reasonably"?  I picked up an old webcor push-pull 6V6 amp from a record player, figgerin' I could build a 'Deluxe' style amp out of the chassis, but, alas, the PT seems fubar.  SEEMS pretty straightforward, 120v>325-0-325, 3.15-0-3.15, 5v.  Ran a 5y3, 2 @ 6v6, 2 @ 12ax7.  Just curious I guess..  LMK,
And Thanks!
Ralph
Title: Re: Tranny trouble...
Post by: Paul1453 on May 10, 2016, 07:41:43 pm
What exactly seems to be wrong with the PT?
These things are heavy, so unless you are taking it to someplace local shipping will cost you as much as a new one.
Then American labor rates for skilled workers is high, so unless you are rewinding the PT yourself you are probably better off buying a new one.  :sad2:
Is the PT shorted, blowing fuses?
Not putting out the expected voltages?
Getting hot and or smoking?
What seems to be the problem?   :w2:
Post by: eleventeen on May 10, 2016, 08:14:55 pm
Buy a new one and be done with it. What you're talking about can't in general be done for less than the cost of a new one.
Post by: rlh5599 on May 11, 2016, 01:11:22 am
Thanks guys.  I figgered it was more trouble and money than it was worth...
2 problems:  1: no center tap for the HV out, and 2: it seems the heaters are shorted.
No worries, I'll just buy a new one...
Post by: HotBluePlates on May 12, 2016, 05:53:49 pm
If it's dead anyway, you might consider opening the transformer up yourself to see if there's anything obvious on the outside of the winding you might correct.
I did this with a transformer in a different category than yours (it had an open high voltage winding). In my case, I was lucky and there was a break in the hair-thin wire just a few turns in from where the thicker lead-out attached. The hardest part was scraping the enamel wire and soldering on the old lead-out. Resulted in a perfect repair.
In my case, I figured I was already destined to buy a new PT, so tearing into the old PT could only have upside. A short may have a good chance of being deep inside the existing coil.
Post by: PRR on May 19, 2016, 08:06:23 pm
A Zippo is the classic "tool".
Old-old "enamel" would come off with strong (kidney-killer) solvent. But newer stuff is tougher, and you may not want to stock 11 different nasty solvents just to find what works on a particular wire.
The very old "enamel" would bubble-off with a soldering iron.
