Other Stuff => Other Topics => Topic started by: kagliostro on May 28, 2016, 07:33:38 am
Title: Question about CNC Router limit switc (and/or zero point switch)
Post by: kagliostro on May 28, 2016, 07:33:38 am
My CNC Router has no limit switch and I would like to install it
there are many different ways to connect (electrically) the switch
Which is your preferred arrangement ?
Someone has councils and/or a schematic for me ?
Title: Re: Question about CNC Router limit switc (and/or zero point switch)
Post by: kagliostro on May 30, 2016, 08:28:23 am
OK, may be a pair of pictures will help to understand what I'm asking for
as told there are many ways to connect (electrically) the Home & the Limit Switch
in this example each Home swithc is connected separated from the other and the Limit switch are connected in series with the Stop button
(http://i.imgur.com/LWwZ4oR.jpg)
while in this example the Home switch of each axis is connected in series with the Limit switch of the same axis, the Stop button is separated
(http://i.imgur.com/3EFcHoX.jpg)
Those of you that have a CNC which arrangement adopt ?
Post by: Heinz on May 30, 2016, 01:43:53 pm
Hello Franco,
I may be wrong but I think the serial arrangement of the limit switches and the panic button in the first picture does not make sense. You should connect them in parallel so that each switch triggers a stop. With the serial connection the stop will only be triggered if ALL limit switches are pressed AND you hit the panic stop. I assume that is not what you want.
The second circuit seems a bit more logical. The panic stop can be triggered individually which is good. However, I don't think that the home and limit switches are in serial. If I understand the basics correctly home and limit switch should be at opposite ends of each axis. This would make it impossible to press both switches at the same time so with the series connection you'll never get a signal. Having home and limit switch of each axis in parallel, doesn't make sense, either, since you'll never know whether you're homing (desired) or limiting (undesired, stop). Even having multiple limit switches per axis in serial is very unlikely as all must be pressed at the same time in order produce a signal. Having multiple parallel limit switches per axis makes more sense from an electrical point of view although I can't think of a mechanical setup that would require them.
The first example with parallel switches looks like an efficient and economical solution to me (only one input pin required) unless you want to be able to distinguish the reason for the stop, e.g. for an error display.
Post by: kagliostro on May 30, 2016, 02:22:39 pm
Ciao Heinz
Thanks for the answer, the switch I've under hand has both
but I think that the connection on the switch that is used is the NC (Normally Closed) not the NO (Normally Open)
This changes things or not ?
It will be interesting to know how Doug has the switch arranged on his CNC
Post by: Heinz on May 30, 2016, 02:25:25 pm
You're right. If the switches are NC then it will work. I had not thought of that.
Post by: shooter on May 31, 2016, 08:33:49 am
Fwiw, all the medical systems I worked on, primarily used || design with redundant circuits, typically opto switch, backed up by mechanical switch.  The E-stop always over-ruled everything.  G.E. did have a series string for all *door* interlocks, around 30 in series, over 3 rooms, with NO indication, so about 90% of the *non-critical* switches were by-passed.
Post by: kagliostro on May 31, 2016, 10:54:38 am
Thanks for the info Shooter
Post by: Heinz on May 31, 2016, 11:06:09 am
I think the main plus of the series connection is the fact that any failure - including a break in the wire - will trigger the stop.
Post by: kagliostro on May 31, 2016, 01:33:05 pm
I agree
Post by: PRR on May 31, 2016, 02:08:40 pm
Normally closed (kill on open) is widely used in alarm systems.
Window-tape (metal foil around the glass) is naturally normally closed (opens when glass cracks through the foil), no real choice.
Normally closed also reduces the building wiring. You have ONE wire going around the building and back instead of two.
And normally closed is "fail safe" in the sense that if a wire breaks, the alarm goes-off as soon as you set it, or the machine won't run.
Some other sensors are naturally normally open, and an alarm system will have additional terminals to sense that.
None of this is important to a small machine. Mechanical switches are often both NC and NO. Wire cost is small.
I would have thought they would run individual wire-pairs to each switch. Then the main display could say "X limit hit", "Red button hit" instead of just "fault". But I guess on a small machine you can quickly see which motion has gone too far. And individual pairs greatly increases the number of screw terminals. If they give you a single "kill" circuit, you can series-up all your panic and limit switches so if any one goes OPEN the machine stops.
Post by: kagliostro on May 31, 2016, 02:34:44 pm
Thanks PRR
Post by: G._Hoffman on June 01, 2016, 05:13:32 am
Mine are all normally closed, normally high, and all in one loop, so it only takes one input.  It works great!
Gabriel
Post by: kagliostro on June 02, 2016, 01:08:03 pm
Thanks Gabriel
Post by: G._Hoffman on June 02, 2016, 05:02:19 pm
Thanks Gabriel
The idea is to make sure there is current flowing through the whole loop, so the chip is sure to notice a change.
Gabriel
Post by: EL34 on June 03, 2016, 03:25:08 pm
I use probotix boards
All the NC switches have their own connections on the board
They are not in series
In Mach 3, whatever switch gets opened shows on the display
If switches were in series, you could not tell which switch was triggered
Post by: kagliostro on June 04, 2016, 02:10:54 am
Thanks also to you Doug
Post by: EL34 on June 04, 2016, 07:36:00 am
I have two NC switches for each of the X, Y  and Z axis
The two X Limit switches are in series
The two Y Limit switches are in series
The two Z Limit switches are in series
All the switches go to their own pin on the breakout board
The other side of the switches goes to the common ground pin on the breakout board
That way, if either one of the two limit switches for each axis gets opened,
Mach 3 shows it on the display for the axis that has reached it's limit
I use lever switches that can be NC or NC
You can set up an adjustable screw that touches the lever
That way you can set the switch open point very precisely with the screw
Post by: G._Hoffman on June 04, 2016, 05:24:25 pm
I've never had a problem figuring out which one was just moving, and having them all in series means I can use the other inputs for other stuff.
Gabriel
Post by: EL34 on June 04, 2016, 08:00:53 pm
I have had problems before with an axis triggering a limit switch
It's nice to actually know which one is causing the problem
Post by: shooter on June 05, 2016, 09:11:36 am
+1
the more complex you get, the faster you can find n fix it.  Dougs *redundant* switching per axis is good practice, switches are pennies, motors and gears and possibly limbs are expensive
Post by: kagliostro on June 05, 2016, 10:25:02 am
Thanks to all
Post by: PRR on June 05, 2016, 11:25:12 am
Yes (many pennies for good ones); but controller INput screws are another cost and size issue.
It's not a big deal. A DIY CNC operator can spot a problem without clues from the controller. In a mass production operation with low-pay workers, more feedback and more log data might improve production, but still would not run itself and clear all jams.
Post by: EL34 on June 05, 2016, 12:09:22 pm
Make sure you use precision switches
The ones with the lever action in my pic above work great
The contacts make and break very cleanly with no bouncing
I used some plunger type switches when I first built my machine
They triggered themselves from vibration once in a while
They also had less than accurate make and break contact points
It really sucks to have a limit switch get triggered in the middle of a job and nothing was even close to the switch to make it trigger
Here's a shot of Mach3 as I pressed on one of the X axis limit switches
Notice the yellow leds that are lit up
Post by: kagliostro on June 07, 2016, 02:11:25 am
Thanks for the info and the photo
I got some switch at a Ham Fest, they are brand new and acting them with fingers seem of good qualitythey
are not too small, has lever with a small wheel on the top (now I haven't it under hand but I'll make a photo and post it)
On the CNC, for now, I arranged only the ass Z switch attachment and I've installed two screws as to be able to have a fine regulation of the switch intervention
EDIT:
Here the photo of the Matsushita switch and how I've arranged the screw for fine regulation
(http://i.imgur.com/sNFjjqv.jpg)
(http://i.imgur.com/tJ2pMtXg.jpg)
(http://i.imgur.com/m6v1PMR.jpg)
(http://i.imgur.com/ONeyIvf.jpg)
(http://i.imgur.com/8rOG5gM.jpg)
Post by: EL34 on June 07, 2016, 10:47:28 am
Looks good franco
Do you have extra nuts to lock the screws in place?
Post by: PRR on June 07, 2016, 10:51:38 am
A fine old design, still the go-to switch for many jobs.
Invented around 1932, MicroSwitch company formed in 1937. VERY common in 1950s-1960s, now owned by Honeywell, and never went out of style. Yours is the Japanese equivalent. I would trust a Matsushita to be good-as the originals. (eBay has 10/$1 look-alikes which might not be as good.)
https://en.wikipedia.org/wiki/Miniature_snap-action_switch
Post by: kagliostro on June 07, 2016, 02:47:46 pm
The hole in the aluminium is threaded and the nut is to lock rthe screw at the right point
I got the switch at an electronic fair, there were also other that were cheaper but I preferred this and paied ..... ??? .... 1 or 1.5 € each
Post by: G._Hoffman on June 07, 2016, 05:25:00 pm
It tends to be best not to run the switch directly into a stop - it can easily put too much force on the switch and break the actuator, and also makes the issue of switch bounce a bigger problem.  It is much better to actuate the switch with a ramped plane, which is gentler on the switch, and will induce less switch bounce (making it more repeatable).  Like so:
(http://opensourceecology.org/w/images/2/2f/HomeLimit.PNG)
I wrecked too many switches before I finally listened to the folks telling me that one!!!
Gabriel
Post by: shooter on June 07, 2016, 08:42:21 pm
+1
all the "roller" type switches I serviced, and there were LOTS!, used Gabriel's ramp type stop, usually 2 switches and 2 slightly off ramps, beyond that was a mechanical stop, you didn't want Gramma shooting out the end off an MRI :icon_biggrin:
Post by: kagliostro on June 08, 2016, 06:37:46 am
I can agree about the use of ramp
my CNC controller is provided of the inputs necessary to the switch
but the CNC isn't mechanically prepared to install the switch
so I must use the best compromise I can
Post by: EL34 on June 09, 2016, 06:31:57 am
I have 6 limit switches and all of them are set up with screw stops
Never had a problem with this system
The lever switches I use are very dependable with snap action levers
They have been in use for many years on my machine and my machine gets used a bunch
Running the screw heads into the tips of the levers, there's no way it can damage the switch by pushing too far
The levers on my switches can bend if needed
The switch either works or it does not
Most likely, it's how you set up your switches if you are going to have problems or not
And the type of switch would matter also
Post by: EL34 on June 09, 2016, 06:54:30 am
I also use the same snap action lever switches on my 3D printer, but without screws
The moving Axis just contact the switches like in the pic below
Post by: kagliostro on June 09, 2016, 04:46:13 pm
Thanks for sharing this info Doug
