Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: Gone_Fishing on June 30, 2016, 03:34:41 pm
Completed my ToreVibe but it has 2 problems (1) the higher you turn the Intensity, there is less gain/volume and it distorts (2) there is no fine adjustment on the Mix, that is, when it is turned up to about 2, the mix is already too much. I put in a 100K pot, but no cigar. I built the ReVibe which was a lot more complicated but it is perfect. I have checked the wiring with Tore's schematic countless times and I can't see a problem. Tried different pans, tubes, etc. Any help will be greatly appreciated. Thanks in advance.
Always a good idea to link to the schematic (http://www.tedweber.com/media/kits/5h15t_schem.jpg) & layout (http://www.tedweber.com/media/kits/5h15t_layout.jpg) so folks know what you're working on.
Was this built from a Weber kit, and are the above linked docs correct?
