Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: Kitarist on July 05, 2016, 10:31:29 pm
So the PT on this amp blew and i changed it with a new one. While the amp works and plays there are 2 types of noises coming from the amp.
The first one is coming from amp like a buzz hum noise while second noise is actually coming inside the amp its a weird chirping noise.
I'm not sure what could it be. I'm suspecting some filter caps got damaged but i'll replace that also and keep you updated.
I alredy changed the rectifier dioes,tubes.
I was also suspecting the larmar PPIMV i changed the amp to stock and the problem was still present.
Here is also a video i made if anyone cares to take a look at it :)
Reverse the OT plate leads. Does that help?
Sorry it was the PT made a typo ;)
I already checked heater polarity and so on...
That chirping sounds more like arcing. Does the new PT have a center tap for the the 6.3vac?
