Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: labb on July 24, 2016, 09:30:14 am
Simple question. What is the correct way to connect a panel mount fuse holder...There is usually a terminal on the side and one on the bottom...Which terminal do you connect the lead from the switch to.
Line (hot) is wired to the end terminal. Switch (load) is wired to the side terminal.
