Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: bnwitt on September 05, 2016, 05:19:45 pm
Title: LED in Hoffman AB763 bias vary tremolo?
Post by: bnwitt on September 05, 2016, 05:19:45 pm
Has anyone replaced the R/C components on the Hoffman AB763 V5-A Tremolo Oscillator with an LED?  If so does it work/do anything to the strength of the oscillator?
Title: Re: LED in Hoffman AB763 bias vary tremolo?
Post by: shooter on September 05, 2016, 05:23:56 pm
I did it with a Gibson trem, took it from mild mannered to ballsy and brash, the musician types liked it
Post by: HotBluePlates on September 05, 2016, 07:06:51 pm
Sluckey has and reported it strengthens the oscillator output.You essentially have perfect bypassing down to d.c.
Post by: bnwitt on September 05, 2016, 07:25:36 pm
Thanks for the replies Shooter and HBP.  Looks Like I'll be giving it a try.  The player I'm building a BFDR for wants that strong Ry Cooder Tremolo tone.
Post by: HotBluePlates on September 06, 2016, 10:00:12 am
... The player I'm building a BFDR for wants that strong Ry Cooder Tremolo tone.
I wonder if Cooder used a small amp which injects trem at a preamp cathode, like a VibroChamp.  They certainly get swampy trem...
The tweed Tremolux gets a swampy trem as well.  I don't know your appetite for building experimental amps, but it seems you could graft a blackface preamp to the tweed Tremolux paraphase inverter & output section.  Or the player could use an EQ pedal to scoop mids if a tweed Deluxe/Tremolux isn't the right sound.
Post by: bnwitt on September 08, 2016, 01:29:57 pm
I did a little research on Ry Cooder's equipment and he has lots of amps and guitars.  The vibroverb and tweed deluxe were amps he had on stage at a few performances:
http://www.thegearpage.net/board/index.php?threads/ry-cooders-backline-on-october-3-2008.448912/ (http://www.thegearpage.net/board/index.php?threads/ry-cooders-backline-on-october-3-2008.448912/)
He supposedly uses an outboard compressor somewhere in his signal chain and he has a little tube preamp built into a variac body for feeding the BFVV and Tweed Deluxe as well:
http://www.rycooder.nl/pages/ry_cooder_Instruments_gear_amps_effects.htm (http://www.rycooder.nl/pages/ry_cooder_Instruments_gear_amps_effects.htm)
I'm putting a middle control on this BFDR's tremolo channel as I always do with black faced Fender amps as I just think not having one stinks.
Barry
