Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: Planobilly on September 26, 2016, 10:36:15 am
Title: Recommendations for a EL84 based amp build
Post by: Planobilly on September 26, 2016, 10:36:15 am
Hi guys,
The Hoffman AB763 amp I have finished went well. I now would like to build a EL84 based amp.
What I really wanted was to build a turret board style amp like a Zinky Blue Velvet. I have never been able to find a schematic of that amp. I guess I could call Bruce Zinky to see if one exist. I am not sure what he would have to say. I use to have one but I never took it apart.
Has anyone here ever played a Blue Velvet and if so can you recommend something similar?
Thanks,
Billy
Title: Re: Recommendations for a EL84 based amp build
Post by: shooter on September 26, 2016, 01:59:41 pm
fwiw, not a Zinky;
find your favorite '84 pa, and well, adjust as needed :dontknow:
Post by: NEjoe on September 27, 2016, 12:41:18 pm
Never played a blue velvet amp.
Are they single ended or push-pull?
Post by: PRR on September 27, 2016, 02:16:39 pm
> not a Zinky
I really suspect that is a Hi-Fi line amp, not a geetar amp fragment.
"Blue Velvet" can mean different things to different people.
Post by: labb on September 27, 2016, 02:48:28 pm
https://www.youtube.com/watch?v=JSQKGUb_mKc (https://www.youtube.com/watch?v=JSQKGUb_mKc)
Post by: shooter on September 27, 2016, 02:51:07 pm
You might/are correct, like K I hoard novel schematics, knew I had velvet, and looking a second time I did file it under hifi, my out
adjust as needed
:icon_biggrin:
2amps back, I did use similar architecture 6SN7, it made it to the public domain 4guitar
Post by: Planobilly on October 01, 2016, 12:37:30 am
Hi,
Bruce Zinky was a designer working for Fender who designed the Prosonic as a custom shop project. He is now the owner or part owner of the Supro line of amps.
I have read that the  new Supro Dual Tone is the same as a Blue Velvet but I am sure that is not true. A Blue Velvet has tube reverb and the new Supro does not. The Blue Velvet uses two EL84 tubes and the Supro uses 6973 tubes.
I have ask a lot of people about a schematic and done a good bit of searching with no results. I also have not seen any of the new Supro schematics.
I may not find a schematic but I can buy the amp used for around $800....pretty pricey way to get a schematic....lol
Cheers,
Billy
Post by: VMS on October 01, 2016, 02:17:59 am
It's not the new 1624T dual-tone which I think is a reissue of an old supro. But I believe those Blue velvets were made under supro name for a while:
https://reverb.com/item/405990-zinky-blue-velvet-supro-dualtone-2011-black (https://reverb.com/item/405990-zinky-blue-velvet-supro-dualtone-2011-black)
https://reverb.com/fi/item/2859424-supro-1624t-dual-tone-1x12-combo (https://reverb.com/fi/item/2859424-supro-1624t-dual-tone-1x12-combo)
