Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: Oddvar on September 29, 2016, 10:18:30 am
I am building a champ amp, and I have an OT that has 4/8/16 ohms outputs, but I only need the 8 ohm. Is it ok to connect only one lead and leave the others not connected?
Yes
Tape them up/insulate them
Yes ..... but may be no
it depends on the OT you have
could you please give an example.
Some Hammond OT's have multiple secondary windings, and proper interconnection of all windings provided gives the best performance from these transformers, even when only part of a single winding could match the load.
Granted, the OP almost certainly doesn't have one of these.
(https://www.hammfg.com/files/products/1608-1650/all-except-1645.jpg)
Yes, but No (for different reasons than Kagliostro probably meant):
Whether you're building a 5F1 tweed Champ (http://el34world.com/charts/Schematics/files/fender/Fender_champ_5f1_schem.pdf) or an AA764 blackface Champ (http://el34world.com/charts/Schematics/files/fender/Fender_champ_aa764_schem.pdf), there exists a feedback loop with parts values suited for the original secondary impedance.
Since you'll be using an 8Ω speaker and not 4Ω, connect that 8Ω tap to the speaker jack. But modify the connection of that series feedback resistor to connect to your 4Ω tap (in whatever manner is most convenient in your build). Then insulate the end of the 16Ω tap and tuck it away.
Even though you're only drawing power from the 8Ω secondary tap, the 4Ω tap will have the same voltage present as though it were the only tap on the OT and your speaker was connected there. It will then also deliver the designed-amount of feedback voltage into your feedback loop.
If you were to otherwise wire up the amp per the layout, but using only your 8Ω tap, you'd have √2-times the designed-amount of feedback voltage going into your loop.
What exactly is this transformer? Is it for single-ended use? What is the nominal primary impedance?
Replay #4 confirmed
Hi and thanks. I am using the Hammond 1760c. The reason is that I only have 8 ohm 10 inch speakers to use, and a small old Pro junior cabinet. The chassis, 5f1, is very small and doesn't allow for more jackoutputs, I could maybe get on extra inn, but cramped.
OK, I understand
follow HBP replay #5 and you are fine
