Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: Oddvar on October 16, 2016, 06:34:15 am
Title: KT66 for EL34 in 5f6a?
Post by: Oddvar on October 16, 2016, 06:34:15 am
Hi.  Is it any way one can swap KT66 into an EL34 figured 5f6a amp?
Best.
Title: Re: KT66 for EL34 in 5f6a?
Post by: tubenit on October 16, 2016, 07:19:55 am
IF your PT can handle the increased current draw on the 6.3V heater wiring and the increased draw on power tube current, then I think you could use KT66.
I think (?) that there is  KT66 with less heater current draw but that it has a metal base that will not work with bear claws.
You may have to rebias or change the bias reisistor or pot values.
Post by: Oddvar on October 16, 2016, 10:14:35 am
The 6.3 v has 5 ampere?
Post by: shooter on October 16, 2016, 11:15:01 am
you're probably good on filaments, but like Tubnit said, you'll probably need to adjust bias, and possibly drive signal to the tube.  I played around on a SE amp and could swap in/out an 88, 34, or 6550 without tweaking until I settled on one, then I re-biased, but you have fixed bias, so that is more critical.
Post by: Oddvar on October 16, 2016, 01:21:10 pm
I have installe biaspot, so that would be ok?
Post by: shooter on October 16, 2016, 06:50:03 pm
double check it's range before you plug in the new tubes.
you have 1ohm bias R's installed?  makes it pretty easy to adjust bias, couple meters and you're there.
