Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: Oddvar on October 18, 2016, 04:33:37 am
Hi. I have just buildt a 5e1 amp. But it blows the fuse as soon as I turn it on, even without the tubes in. I have the Hammond 291AEX transformer. It says 240 v is the two black leads. Trouble is that one of the black leads has a white stripe, so I wonder if there might be some other leads, it has also has two white leads with red stripes and two brown onews, with a yellow stripe on one. I have askes Hammond, but they don't answer. Any suggestions?
Does the box have a sticker on it that id's each wire???
Do each of the same (main colour)colour wires have continuity????
No, they haven't. I don't know what you mean by continuity?
This page has different datasheet for the transformer:
https://www.hammfg.com/electronics/transformers/classic/290 (https://www.hammfg.com/electronics/transformers/classic/290)
https://www.hammfg.com/files/parts/pdf/291AEX.pdf (https://www.hammfg.com/files/parts/pdf/291AEX.pdf)
Thanks, that must be it. Why operate with two different schematics?
Black-Black/White is 120 v
Brown- Brown/white is 120 v. To get 240 v should I connect Black/White and Brown/White then?
If you scroll down this page you see how to connect for 240V:
http://www.hammondmfg.com/300series.htm (http://www.hammondmfg.com/300series.htm)
In your case I believe you connect BLK/WHT and BRN together and BRN/YEL and BLK are your previous black wires.
Thanks again. It worked...
