Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: Planobilly on December 08, 2016, 01:47:09 pm
Title: Unexpected high voltage at output transformer Fender Deluxe clone SOLVED Thanks
Post by: Planobilly on December 08, 2016, 01:47:09 pm
Hi guys.
This is a Mission Amp Deluxe clone. With no tubes in the amp except the 5y3s rectifier I measure these voltages.
407 VDC at standby switch.
520 VDC at pin 3 of the output tube when I turn on the standby switch.
523 VDC at the first 16uf filter cap.
(http://i.imgur.com/twVzvcB.png)
(http://i.imgur.com/PNnlNb9.jpg)
(http://i.imgur.com/zaemuwV.jpg)
Have any idea what could cause these voltages. The AC voltages on the power transformer measures close to the datasheet.
The amp came to me with a burned eyelet board (5K1-2W had burned the board). I made a turret board replacement with the same layout. I installed all new components except the filter caps and one .022 cap (pin 1 V2) The only other difference in the schematic is the power transformer has a center tap for the 6.3 heater so no 100 ohm to ground resistors.
Thanks,
Billy
Title: Re: Unexpected high voltage at output transformer Fender Deluxe clone question
Post by: sluckey on December 08, 2016, 02:34:26 pm
Hi guys.
That's what you should have with no tubes to put a load on the power supply.
Post by: Planobilly on December 08, 2016, 03:16:59 pm
Thanks,
I will continue on and install tubes and continue the testing.
Thanks,
Billy
