Amp Stuff => AmpTools/Tech Tips => Topic started by: kagliostro on January 23, 2017, 03:40:42 pm
Title: One other Visio Question (about guide lines)
Post by: kagliostro on January 23, 2017, 03:40:42 pm
There is a way to cancel all the guide lines at one time without to have to select it one by one ??
I don't mean hide, I mean cancel as they were never inserted on the work
Title: Re: One other Visio Question (about guide lines)
Post by: sluckey on January 23, 2017, 04:59:09 pm
If you ever find it, please let me know.  :icon_biggrin:
Post by: kagliostro on January 26, 2017, 03:23:16 pm
OK Steve
I'll say you, if I find how do it
Seems that we have to wait a bit before  :icon_biggrin:
Ciao
Post by: sluckey on January 26, 2017, 03:59:47 pm
Here's your answer...
Select --> Select by Type --> Shape type --> Check only guides --> click OK --> Press Delete key
Post by: kagliostro on January 27, 2017, 03:30:00 pm
I tried it and .....  :bravo1:
Many Thanks Steve :notworthy: :notworthy: :notworthy:
Very useful tip
p.s.: In italian is
(Menù) Modifica > Seleziona per tipo ... > Selezionare Guide > OK > (Premere) Cancella
Post by: sluckey on January 27, 2017, 06:12:32 pm
Thank you for posing the question. It made me search through the menus until I found the answer. I have often wanted to do exactly that but rather than spend the time to learn how, I would just delete them one at a time. Now it's just a couple clicks away! I use guides extensively when designing a board layout or schematic. In fact, I use guides in most every drawing I do. Even my sprinkler system, flower bed, or garden layouts!   :laugh:
Post by: kagliostro on January 28, 2017, 02:22:28 pm
I used Autocad and the use of Construction Lines (the Guide Lines of Visio) is very common and indispensable if I can say
So very often happens I've a massive quantity of Guide Lines on and it was a pain to select it one by one to cancel
Thanks again
Post by: DummyLoad on January 29, 2017, 08:16:25 pm
you can add the guides to a layer. that way you can then make the layer visible, not visible or, delete the layer. i usually add two layers for guides - h-guide and v-guide. start by attaching one horz. guide and one vert. guide to a layer(s) and then just copy it from then on with ctl+left mouse. sometimes i'll add board guide layers and layers for the machining guides.
Post by: kagliostro on February 03, 2017, 05:54:59 am
Ciao Pete
Excuse me, I've seen your answer only now
Thanks for the info, I'll give it a try, seems that is a good method
Ciao
