Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: leevc5 on January 31, 2017, 12:53:40 pm
Title: Single ended 6L6 amp - unable to find the kit - help, please
Post by: leevc5 on January 31, 2017, 12:53:40 pm
Would like to build a SE amp like a 5F1 but with a 6L6 for higher output and more headroom.  Have been looking but can't seem to find one.  Is there one somewhere in the Hoffman list that I am just missing?
Title: Re: Single ended 6L6 amp - unable to find the kit - help, please
Post by: sluckey on January 31, 2017, 01:22:29 pm
Follow the 'Tube Amp library of information' link at the bottom of this page. Hoffman's 5F1 is at the top of the list. You may need a bigger PT and OT but everything else is the same as the 6V6 version.
Post by: PRR on January 31, 2017, 06:05:05 pm
5F1 or AA Champ, with "Champ/DeLuxe" PT, plus a 5K "6L6" OT from one of the hot-rod transformer shops, is all you need.
Post by: leevc5 on January 31, 2017, 06:12:42 pm
No special wiring? just a 022772 PT, 5F1 loaded PCB and WSE15 type OPT and I get a 10- 12W Champ? Seems too simple.
Post by: PRR on January 31, 2017, 06:27:20 pm
> No special wiring?
If you just want a little more power, you just use a bigger "engine and gears".
My mom bought a Mustang. Choice of 100HP Six or 200HP V-8. It was essentially the same car either way. (Actually if you got the Eight then Ford gave you the less-cheap wheels and brakes. But the Six's brakes were like a cardboard cabinet on an amp-- too-too-cheap.)
Post by: DummyLoad on January 31, 2017, 06:35:41 pm
wimpy 6cyl. drum brakes with four lug axles... bleh!
this OT:   http://www.mojotone.com/amp-parts/Transformers_1/15W-SE-Output-Transformer-3-5K-4K-5K-primary (http://www.mojotone.com/amp-parts/Transformers_1/15W-SE-Output-Transformer-3-5K-4K-5K-primary)
doug sells PT - can get OT from Mojo for you.
Post by: leevc5 on January 31, 2017, 08:19:49 pm
why doesn't some make a SE 6L6/kit? Is There something I am missing? Should I be looking at another kit that is already available?
Post by: shooter on January 31, 2017, 08:35:22 pm
How big is your purse? :icon_biggrin:
PM me if it's BIG :icon_biggrin:
Post by: leevc5 on February 01, 2017, 03:46:12 pm
Thanks y'all, shooter solved the problem with some guidance and 3 resistors.
