Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: gtrplayr1976 on January 31, 2017, 01:12:14 pm
Is biasing with the Hoffman board the same as with the original ? On the original I measured voltage drop between the OT CT to the plates.
Thanks !
You can do that. But Hoffman included two 1Ω resistors on the board to make monitoring bias current much easier and safer.
Thank you ! What's the procedure for that ?
I don't know that there is a procedure specifically for that amp. Use this...
http://www.duncanamps.com/technical/lvbias.html (http://www.duncanamps.com/technical/lvbias.html)
Thank you !
Thank you !
GTplayer1976,
I just went through the procedure and referenced Doug's article on biasing amps
http://el34world.com/charts/fenderservice5.htm (http://el34world.com/charts/fenderservice5.htm)
