Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: kagliostro on February 04, 2017, 10:31:02 am
Title: Line OT Transformers - Question
Post by: kagliostro on February 04, 2017, 10:31:02 am
I would like to know if there is a standard on the orientation of the laminations on the Line OT Transformers
Are the laminations arranged as in a PP PT or are arranged as in an SE OT ?
or there isn't a standard at all and each manufacturer do as he like more ??
Title: Re: Line OT Transformers - Question
Post by: vibrolax on February 04, 2017, 03:28:50 pm
Since these line transformers are not expected to have DCvoltage on them, they would not be gapped like a SE OT.
A gapped transformer would also have to be much larger for a given power level.
Post by: kagliostro on February 04, 2017, 04:44:37 pm
Many Thanks
Post by: darryl on February 04, 2017, 05:42:59 pm
I checked the four line transformer models I regularly use as push-pull output transformers. None of them are gapped.
http://www.altronics.com.au/p/m1115-8-ohm-to-1.25w-15w-pa-speaker-transformer/ (http://www.altronics.com.au/p/m1115-8-ohm-to-1.25w-15w-pa-speaker-transformer/)
http://www.altronics.com.au/p/m1120-20w-100v-line-pa-ei-core-transformer/ (http://www.altronics.com.au/p/m1120-20w-100v-line-pa-ei-core-transformer/)
http://www.altronics.com.au/p/m1130-40w-100v-line-pa-ei-core-transformer/ (http://www.altronics.com.au/p/m1130-40w-100v-line-pa-ei-core-transformer/)
https://www.jaycar.com.au/5w-line-speaker-transformer/p/MM1900 (https://www.jaycar.com.au/5w-line-speaker-transformer/p/MM1900)
Post by: kagliostro on February 05, 2017, 07:34:01 am
Thanks Darryl
