Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: jay_back_in_chicago on February 18, 2017, 01:53:42 pm
Title: 18w project
Post by: jay_back_in_chicago on February 18, 2017, 01:53:42 pm
Hey everyone, here I come with my latest build plan.
I have made few amp tweaks so far, mostly to my valve jr. and my ceriatone twreck clone and now I'm moving on to first build.
Got myself a set of classic tone 18w marshall transformers, and I'm going to build Lite 2B version with 6v6 in it, and from mhuss website I will experiment with supro tonestack, I wonder how it sounds.
What would be best layout out there for Lite 2B? What changes will I have to make for 6v6?
And after all, I found few BOM's online, is there anything in particular that I should follow? For caps and resistors that is, I have all the other parts ready.
Title: Re: 18w project
Post by: sluckey on February 18, 2017, 02:35:50 pm
Here's my Dual Lite. It's a Lite IIB plus a Vox AC-15 Lite in one small chassis. The schematic and layout are at the bottom of the page...
     http://sluckeyamps.com/dual_lite/dual_lite.htm (http://sluckeyamps.com/dual_lite/dual_lite.htm)
You may find a dedicated Lite IIB layout on the 18watt.com forum or else where on the net. Use google. I don't recall seeing a layout on this forum.
As for BOM, do your own from the schematic you choose. That's an excellent way to become familiar with the amp circuit.
Here's a schematic that includes notes for using 6V6s as well as EL84s...
Post by: jay_back_in_chicago on February 18, 2017, 03:44:33 pm
what a nice build!
yes, saw that one, found layout that was so far my reference point.
One question, since I have GZ34 and 5v4 both at home, will there be much difference since the amp is cathode biased?
Post by: sluckey on February 18, 2017, 04:09:50 pm
no
Post by: jay_back_in_chicago on February 19, 2017, 04:22:36 am
so I will go with that...
few more... i have already 32uF + 32uF 500V at home, F&T, could I use that instead of 33uF 450V x2 in schematics you posted?
Post by: sluckey on February 19, 2017, 05:22:48 am
yes
Post by: jay_back_in_chicago on February 19, 2017, 11:22:54 am
So I made my own BOM for the build, caps and resistors, and I will leave it here so if I made a mistake somebody can point it out, and if it's correct it might be of use to somebody
CAPACITORS (total number=13)
2x  50uF  50V
1x 0.0047 uF
4x 10nF
1x 100nF
1x 470pF Silver Mica
1x 16uF 450V
1x 32uF + 32uF 500V Radial
RESISTORS (total number= 21 )
1M    x2
820  x2
120K
22K
470K x4
100K  x2
8.2K x2
1K 3W
250 5W
100 3W  x2
2K2 2W
8K2 2W
220K 1W
POTS
500K LOG (audio)  x2
Post by: sluckey on February 19, 2017, 11:45:42 am
Which schematic?
Post by: jay_back_in_chicago on February 19, 2017, 01:14:42 pm
Following the one made by mhuss (link bellow) and the one you posted I used for 6v6 mods.
http://mhuss.com/18watt/schematics/18wattLite2b.gif (http://mhuss.com/18watt/schematics/18wattLite2b.gif)
Post by: jay_back_in_chicago on February 21, 2017, 07:57:05 am
Pretty much everything is ordered, I just had hard time finding 5W 250 resistor here in EU, any advice?
Post by: kagliostro on February 21, 2017, 08:01:28 am
If you want to share a BOM seems mandatory to post a schematic that corresponds exactly
Post by: jay_back_in_chicago on February 21, 2017, 08:04:53 am
Working on it as we speak, it's just a few changes but I will scan and post when done
Post by: sluckey on February 21, 2017, 08:07:05 am
I would use this...
http://www.tubeampdoctor.com/en/shop_Resistors_Wirewound_Resistors/Resistor_270_Ohm_5W_5_for_Fender_Tweed_Deluxe_1507 (http://www.tubeampdoctor.com/en/shop_Resistors_Wirewound_Resistors/Resistor_270_Ohm_5W_5_for_Fender_Tweed_Deluxe_1507)
Post by: jay_back_in_chicago on February 21, 2017, 08:22:31 am
thank you, I will wait for it to become available
for all the resistors I went with carbon comp 1/2 W, unless more is specified, is that ok?
Post by: sluckey on February 21, 2017, 08:37:42 am
I'm sure if you use google you can find plenty of EU suppliers. Here's another supplier...
http://www.ampmaker.com/store/5W-metal-oxide-power-resistors.html (http://www.ampmaker.com/store/5W-metal-oxide-power-resistors.html)
Post by: jay_back_in_chicago on February 21, 2017, 08:44:47 am
There are, TAD is just practical since I buy there often, have some discount and local free shipping....thank you for the tip anyway
Post by: kagliostro on February 21, 2017, 08:54:43 am
If you buy also from RS
http://it.rs-online.com/web/p/resistori-montaggio-a-foro-passante/8916287/ (http://it.rs-online.com/web/p/resistori-montaggio-a-foro-passante/8916287/)
http://it.rs-online.com/web/p/resistori-montaggio-a-foro-passante/8915830/ (http://it.rs-online.com/web/p/resistori-montaggio-a-foro-passante/8915830/)
http://it.rs-online.com/web/p/resistori-montaggio-a-foro-passante/8506604/ (http://it.rs-online.com/web/p/resistori-montaggio-a-foro-passante/8506604/)
Post by: jay_back_in_chicago on March 04, 2017, 07:07:07 am
All the parts are here, and I started...
Here is assembled board with extra lugs so I can mod it to use cap can 32 + 32 and still connect it according to dockery layout.
One question...If I decide to use one switch, so off-standby-on, what should I buy?
Post by: sluckey on March 04, 2017, 07:21:51 am
Click the "switches" link at the bottom of this page. Scroll down until you come to this switch...
Carling DPST Switch
3 Position toggle switch
You can use this switch for Off-Standby-Play
Very nice if you only have one switch hole
4 Solder terminals
Click here for wiring information.
 Price each = $7.35
Post by: jay_back_in_chicago on March 08, 2017, 05:22:11 am
Will order that one soon!
One dumb question, but I want to make sure. Can I use terminal strip for 2x 3,15 and ground? And then wire from there according to schematic?
Post by: sluckey on March 08, 2017, 06:11:14 am
Sure. Lot's of people do that, including me sometimes.
Post by: jay_back_in_chicago on March 08, 2017, 06:30:39 am
Ok,I can finish planning my layout then, attached is my plan now...
My 5v 2A and 0 wires are really tough, I will just run them parallel to rectifier, there is no way I could twist them. Same with heaters, I will run them parallel to terminal and twist from there. Is that ok?
What about 6.3V unused wire for rectifier? I just shorter it and tuck in somewhere ?
Post by: John on March 08, 2017, 08:19:50 am
Twisting from term strip will be fine. IMO though, the routing of the heater wires is way more important than whether they're twisted or not. I have started positioning my tube sockets so that the heater wires are always away from everything else (usually along the back side of the chassis). And I don't bother twisting anymore. But, Best Practice is indeed, nice neatly twisted heater wires.  :icon_biggrin:
The 6.3 unused wire you're talking about; I wouldn't shorten it any, but just coil it up nice and neat and tuck it out of the way. You never know what you might use this transformer in at some point down the road. I've used the same set in 3 different builds.
Post by: sluckey on March 08, 2017, 09:37:03 am
Be sure to put tape or heat shrink tubing on the end. That wire will have B+ voltage on it.
Post by: jay_back_in_chicago on March 08, 2017, 12:47:40 pm
Will do so, heat shrink it at the end and tuck away.
I was planing to run heaters in end corner, as far away from everything else.
Is my preamp tube placement ok? I wanted to give more space to myself back there so I moved them up front, plus I will need shorter wires for V1 and V2 to connect them to jacks.
Post by: jay_back_in_chicago on March 10, 2017, 05:03:04 am
I have some shielded wire leftover from old hiwatt clone that I got so many years ago, pic attached under
Is that enough AWG for this amp or am I better buying new wire?
Since there is no ground connection on other side for that wire, is there alternative wiring that I could use? like from jack ground to chassis?
Post by: shooter on March 10, 2017, 08:35:00 am
It's fine for your input, you only ground 1 end, just like your layout pic shows.  The "tube" end only connect the signal wire, NOT shield.
Post by: jay_back_in_chicago on March 10, 2017, 08:48:15 am
I get it, will just re use those wires in this build
Post by: Ritchie200 on March 10, 2017, 07:18:21 pm
"jay back in Chicago" is in the EU?  Is there a story behind this? :icon_biggrin:
Jim :hijack1:
Post by: sluckey on March 10, 2017, 07:31:12 pm
Yes. I want to hear it too!  :icon_biggrin:
Post by: jay_back_in_chicago on March 11, 2017, 03:04:52 am
Jim :hijack1:
sure thing!!! not so interesting haha  :icon_biggrin:
I have been traveling a lot for work last few years, and so many good things used to happen right in Chicago, that after a while I began to say to all my USA( and other) friends, "When I come back to Chicago(instead of USA), it will..." :D
Now I use any opportunity I have to visit ;), and  If I expand my business enough I will open an USA branch right there, or Oregon
Post by: moonbird on March 17, 2017, 06:28:10 pm
Sorry for the intrusion  :w2:  Jay.
Sluckey - What would be required to add a little "plexi" dust to this already very cool design? Could some mix resistors be added before the PI to allow both channels to be active?? If so, could you suggest some mods to try - I would have no idea what components would allow this idea to work. Thanks kindly. :icon_biggrin:
Post by: sluckey on March 17, 2017, 07:14:01 pm
Build this instead...
http://www.ax84.com/index.php/oldprojects.html?project_id=november (http://www.ax84.com/index.php/oldprojects.html?project_id=november)
Post by: moonbird on March 18, 2017, 01:37:54 pm
Yayyah - Way cool Sluckey. Thanks.
Post by: kagliostro on March 18, 2017, 03:51:09 pm
http://sluckeyamps.com/november/november.pdf (http://sluckeyamps.com/november/november.pdf)
http://sluckeyamps.com/november/november.htm (http://sluckeyamps.com/november/november.htm)
Post by: sluckey on March 18, 2017, 03:54:47 pm
I was not trying to be a smartass with my answer. There's just no way to get from the amp Jay is building to what you're asking. Jay's amp is an 18 watt Lite IIB. It is based on the Marshall 1974 circuit, but the normal channel has been removed and the tremolo circuit has also been removed. This leaves a single preamp feeding into a cathode biased EL84 power amp. There are no two channels. This amp is so different from a Plexi that I suggested you just build an amp that is based on the Plexi design.
Now here's the smartass answer. Please take it in jest...
If you want 'to add a little "plexi" dust to this already very cool design' then put a plastic faceplate on it.   :icon_biggrin:
Post by: shooter on March 18, 2017, 04:23:19 pm
I used art glass, doesn't sound plexi, but then I don't sound like a guitar player :laugh:
Post by: moonbird on March 19, 2017, 10:54:37 am
Sluckey - No worries. As a hijacker I get what I get I figger. And yes I appreciate the jesting!!
Just for the record however, I was talking about your dual British amp. I though having a plexi-style, mixed input; might be fun and make it a sort of "triple" British amp. Thats what I thought of when I saw your schematic. Needs another thread I reckon.
Cool blue shooter!!
Post by: sluckey on March 19, 2017, 11:16:19 am
Ahh! That makes a big difference. But you never mentioned that until now.
If you want to do that then drop the input selector switch and tie the two inputs together. Then tie the two preamp outputs together using 220K mixing resistors and feed that to the top PI input cap. Ground the bottom PI input cap. Use the two volume controls to blend the two channels together as desired. Expect a bit of interaction.
I actually considered this when I built the amp but ultimately decided to go with the existing circuit just because I was not interested in blending the two channels together. I wanted one or the other, not both.
Post by: moonbird on March 19, 2017, 12:00:40 pm
Sluckey - Sorry to all for my inept communications earlier. Perfect!! Just what I was looking for!! Many thanks!!
Jay - Best of luck on *your* project!
Post by: jay_back_in_chicago on March 19, 2017, 12:45:01 pm
no problem on asking for informations here! It's all in good spirit if you ask me
My chassis will be done tomorrow, and I will  continue with my project. I used this weekend to finish head box finally
Post by: jay_back_in_chicago on March 24, 2017, 12:25:21 pm
Guys, I used silver unprotected wire for ground connections under board, is this ok?
Post by: jay_back_in_chicago on March 29, 2017, 11:12:12 am
I need rectifier advice/help
I'm using gz34
pins 4 & 6 are for 290V connections
pin 1 goes to my standby switch
but with heaters, pin 2 and 8, next to 8 stands f,k,....my question is, out of 0V and 5V, wich ones goes to pin 2 and which to pin 8?
thanks
Post by: sluckey on March 29, 2017, 11:28:23 am
Pins 4 and 6 are for 290VAC connections.
Pin 1 is not used.
Pin 2 goes to 0V on the filament winding.
Pin 8 goes to 5V on the filament winding. Also connect a wire to pin 8 that goes to the standby switch.
Post by: sluckey on March 29, 2017, 11:39:10 am
I would use insulated jumpers. I would also redo those jumpers to look like this...
Post by: jay_back_in_chicago on March 29, 2017, 02:33:05 pm
thank you for grounding tips, will do that
about gz34,glad I asked, all the pin outs suggested I need to use pin 1 :(
Post by: sluckey on March 29, 2017, 02:51:41 pm
Really! I've never seen a datasheet that said to connect pin 1 to anything. Can you post a link to a datasheet that says to use it? Especially a datasheet that suggests to connect pin 1 to a standby switch.
Post by: jay_back_in_chicago on March 29, 2017, 02:55:13 pm
maybe that was my misunderstanding of data, or trying to combine ez81 logic with gz34 logic :/
Post by: sluckey on March 29, 2017, 03:26:42 pm
Post by: jay_back_in_chicago on March 30, 2017, 03:32:54 am
Now I understand it, tahnks
This is how I wired my 32+32 uf cap
(I know that resistor looks really close to the screw but there is good amount of distance there)
Is this ok??
Post by: jay_back_in_chicago on April 01, 2017, 02:25:15 am
here is the amp in headcab I made, just missing faceplate/logo, but I'm still rethinking those
Post by: Willabe on April 14, 2017, 11:43:51 pm
Looks good!  :icon_biggrin:
