Amp Stuff => EZ Board postings => Topic started by: Geezer on June 17, 2005, 10:11:25 pm
> reverb tube/circuitry Q
<< Prev Topic | Next Topic >>
Author Comment
tubenit
Junior tube assistant
(3/8/04 7:40 pm)
I am looking at switching a 6CG7 tube out that is driving a piezo-tranducer reverb for a 12AX7 driving a spring reverb tank. The amp is the DanElectro Centurian. 2(12AX7)
preamp, 6CG7 reverb, 6AU6 tremolo,2(6V6) ouput, 6x4 rectifier. Voltages on a Gibson Scout 12AX7 doing both driver/recovery are pretty similar to the Dano 6CG7. Both are twin triode 9 pin sockets. I understand that the resistors and caps will have to be changed accordingly.
On this amp, I don't care about preserving the vintage goofy reverb.
I looked at numerous schematics and as near as I can understand it looks like one tube can serve as reverb driver and recovery. (left out caps/resistors below in illustration)
DRIVER:
- grid to plate of 1st preamp
tube
- cathode to ground
- plate to "powerline" (+)
RECOVERY:
-grid to reverb tank & ground
-cathode to ground
-plate to "powerline" (+)
Am I understandng this correctly that one tube can serve for both Driver/Recovery and the driver side ties into te plate of the 1st preamp tube? And that tying it between te 1st & 2nd preamp tubes allows the 2nd preamp tube to amplify the reverb recovery? tubenit
Dmichel1984
(3/9/04 4:55 am)
me too
I want to do this on my Silvertone Twin Twelve,
I believe the only changes would be to ground pin 9, right????? :
tubenit
(3/9/04 7:06 am)
Re: me too
The Gibson Scout GA-17RVT I rebuilt does NOT have pin 9 grounded (no caps, resistors on it either). (see schematic heaven.com for schematic)
Hope that helps. I would be curious to know if your twin-12 has a piezo transducer reverb??
Dmichel1984
(3/9/04 6:00 pm)
re
I'm not sure what piezo transducer reverb is, but I think this is a spring tank, although very small. I need more 'verb, and a 12AX7 is a higher gain, higher heater voltage twin triode than the 6CG7, with the same pinout except the 6CG7 has nothing on pin 9... you can ground pin 9 and be able to use both...
the 6EU7 is similar to a 12AX7 with different pinout, but 6V heater, so thats diff. from a 6CG7...
Dmichel1984
(3/9/04 6:13 pm)
btw
by the way, the silvertone does not have a transformer for the reverb
tubenit
(3/9/04 9:32 pm)
Re: btw
The Scout GA-17RVT actually has a 12AX7 for the reverb. The schematic lists a 6EU7 and the tub layout lists the 12AX7 contradicting the schematic.
The layout with 12AX7 is correct for the reverb. I rebuilt a Scout and the reverb is great on it!
I'm curious about no reverb trans and the small reverb?
The piezotransducer reverb looks like a cigar holder only slightly larger. Is that what you have or is yours actually a reverb tank that is small?
Dmichel1984
(3/10/04 1:47 pm)
verb
This may be what I have (silvertone/danelectro are the same) It does have a spring in there i think, but yeah about that size.......
Dmichel1984
(3/10/04 1:53 pm)
btw
I rewired the heater on the 6CG7 driving the verb to accept a 12AX7(12AT7 or 12AU7, etc) not by grounding pin 9, but by moving pin 4 to pin 9 and bridging 4&5, It sure has alot more spring to it now....
tubenit
(3/10/04 6:51 pm)
Re: btw
Interesting! Thanks for the response. The Gibson scout had the 4&5 pin bridged and the 9 pin open like you have done. Glad to hear it has more spring to it. I'm still leaning towards using a spring reverb and adding a reverb trans if needed.The Dano amp will be sent to me by my son-in-law.
Dmichel1984
(3/11/04 6:51 am)
CALLING: WESTBURIAN
Yeah, I think I'd still rather convert it to tranny driven w/ Accutronics tank...
Westburian should be able to help us.....
Topic Commands
jump to: Tube Amp Building - Tweaks - Repairs (New)New Product Suggestions (New)Praises - Complaints - Suggestions (New)Buy - Sell- Trade (New)Archives (New)
Powered By ezboard® Ver. 7.32
