Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: okguitarman on June 10, 2017, 02:53:54 pm
Title: larger output trans.
Post by: okguitarman on June 10, 2017, 02:53:54 pm
Should a larger output trans. same input and output specs. lower volume and have no clean head room?
I changed PT31  5k/8ohm 8watt  to 125ese 5k/8ohm15 watt and this was the results.
Title: Re: larger output trans.
Post by: PRR on June 10, 2017, 06:28:24 pm
The 125ESE has way too many wires on it. Are you sure you got it wired right? Are you sure you are sure?
It really should play the same or a hair better.
The 125ESE at 5K may be marginal for the bottom of a bass.
Post by: okguitarman on June 10, 2017, 06:42:10 pm
I'll double check! Tonight and let you know
