Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: Voxbox on June 30, 2017, 01:09:37 pm
Help!
I've been working on a 1966 Pro Reverb and tried to remove some masking tape residue from the top of the front panel faceplate and managed (with some isopropanol cleaner) to take what appears a thin layer of slightly shiny clear lacquer off part of it. It now looks a bit tatty :(
Any suggestions for restoring an even sheen to the faceplate?
Cheers, VB
Might try a waxing like spit shining boots. I use WD40 on rubber to get a smooth finish, but I would be concerned with removing the silkscreen. The ink used has cobalt as the drying agent and it is really tough, but anything with a solvent I would not use.
Some soap and water may even it back out, you may just have residue lingering.
Thanks Ed, I did think about a wax finish. The Isopropanol went through the black of the faceplate a little so I'm really annoyed about that.
Any ideas for touching up?
I'll try the wax on the back first.
Cheers, VB
