Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: evancorylevine on September 02, 2017, 04:44:35 pm
Title: AB763 backwards doghouse?
Post by: evancorylevine on September 02, 2017, 04:44:35 pm
Hey loves.
I fear that I may have installed the components in the doghouse upside down. I can't just turn it around because the mounting screws and the through-holes to the inside are asymetrical. Do I need to turn this all around, or is it okay if some of my wires to the doghouse run a little longer?
Click here for a picture of the mounted board. (https://www.dropbox.com/s/tgihr6casheyez6/2017-09-02%2011.46.37.jpg?dl=0)
Title: Re: AB763 backwards doghouse?
Post by: sluckey on September 02, 2017, 05:49:58 pm
If you're happy, that's what counts. The important issue is connecting the wires IAW the schematic. Couple inches extra length means nothing.
I would personally redo it but I'm anal about that stuff. I once threw a chassis in the trash because of a backward layout error.
Post by: PRR on September 02, 2017, 07:23:35 pm
If you are going to build a million of them, saving the penny on wire will delay you going broke.
For a one-off, I would not fret.
Post by: bnwitt on September 03, 2017, 08:13:03 am
attached is how the Fender higher wattage amp cap boards are typically wired
