Other Stuff => Effects => Topic started by: alange5 on September 14, 2017, 03:58:27 pm
Title: delay + modulation switching problem
Post by: alange5 on September 14, 2017, 03:58:27 pm
I built a Deep Blue Delay and added a modulation board.  The modulation is wired to a 3-way switch (half of a DPDT on/off/on) and should yield the following:
(1) up: modulation only
(2) middle: delay only
(3) down: modulated delay
Positions 1 and 2 work great, but I'm not getting any modulated delay in position 3 - just normal delay (same as position 2).
Here's a crude drawing showing the two boards and my switch wiring:
(https://thumb.ibb.co/bXY1Yk/delay_wiring.jpg) (https://ibb.co/bXY1Yk)
If I disconnect lug 1 from the main delay board, I get modulated delay in position 3, but nothing (dry clean signal) in positions 1 and 2.
How can I wire the switch so that lug 1 is connected to the main board in positions 1 and 2, but disconnected in position 3?
Any other suggestions are welcome.  Thanks in advance.
