Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: leevc5 on September 23, 2017, 06:14:37 pm
Plug it in, hear a humming sound then POP...smoke...capacitor debris all over the place.
What could it be?
A bad cap.
installed backwards.
With polarised electrolytic caps, you need to observe the correct polarity. (+ve pole should point to the higher voltage end of the cathode resistor)
Voltage rating is the last thing not mentioned, I've blown up 1 cap when I got in a hurry and put a 350vdc where a 450vdc shoulda been :think1:
Voltage rating is the last thing not mentioned, . . .
If the 5W cement resistor isn't performing its intended function, the 22/50V cap can charge up well past its voltage rating.
