Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: kagliostro on January 22, 2018, 02:46:22 am
Is the difference between 6u8 and 6U8A only in heather warmup time ?
http://frank.yueksel.org/sheets/168/6/6678.pdf (http://frank.yueksel.org/sheets/168/6/6678.pdf)
https://frank.pocnet.net/sheets/049/6/6U8A.pdf (https://frank.pocnet.net/sheets/049/6/6U8A.pdf)
According to this page the answer is yes:
http://www.r-type.org/exhib/aaa1389.htm (http://www.r-type.org/exhib/aaa1389.htm)
http://www.r-type.org/pdfs/6u8.pdf (http://www.r-type.org/pdfs/6u8.pdf)
http://www.r-type.org/pdfs/6u8a.pdf (http://www.r-type.org/pdfs/6u8a.pdf)
Thanks VMS
They may be the same.
In series-string heaters it is best if all the heaters warm-up at the same rate. A standard rate was picked, and some (not all) the "A" tubes meet that spec. However the spec was picked to be similar to how most existing tubes warmed-up. I suspect only a few extreme types, or odd makers, actually had to change their heater designs.
Huh. The magazine Popular Science ran a very fictional story/article about the change. Because it is a boring subject, the author jazzed it up with a horse-betting story and Runyon-esque slang. This may not read well if you are not an older American, but you will get the idea. "11 seconds" is a simplification; I inserted the actual spec.
Thanks PRR
I like very much your explanation (and saved the article in my archive)
