Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: Leevi on January 24, 2018, 11:08:42 am
Has anyone succeeded to prevent popping when switching between two PPIMV?
/Leevi
short of power down, switch, power on, you might be on a fools errand, but I've ran a few errands like that :icon_biggrin:
The popping comes from the buildup of current that has no path, I thought with any popping switch you can resolve the popping by putting in a significantly higher resistor to ground than the normal path, say you have 1M audio pots put in a 20M to ground so when the switch is temporarily 'open' it has a path somewhere until the switch re-engages and then you have a better path again for the signal.
IN the case of a PPIMV usually its a 220/250k dual pot or some such, so you may do fine with a 1M or so but still even higher is better, meaning the current doesn't want that at all if he PI is in circuit.
~Phil
The following solution is not optimal but does it pop?
/Leevi
Have you tried it like this:
Ciao Risto
Your schematic has something of odd ..... why the MV to be switched are in series and not in parallel ??
also VMS schematic has something strange ......
EDIT:
I don't think this solve pop problems, but will be the way I'll swap between two different PPIMV
(https://i.imgur.com/f3H804s.jpg)
the switch is draw as a pair of DPDT (as to semplify the schematic) but use one 4PDT
to solve pop problems, as told, a high value resistor used in parallel to switch contacts
You maybe right, how about my second attempt?
A lot better VMS :thumbsup:
But now that I've seen it better, I think that also the other one will be doable (and only a very small part of the signal will go where you don't want)
more i think about this more unsure i am on my suggestions :dontknow:
The way I've draw the swap will exclude for sure the unused pots from the signal path
but may be also your circuit is doable without problems .......... or not :w2: :w2:
Thanks for your proposals guys.
My schematic was not meant to be complete, the idea was just to try prevent pot and keep some kind of usable two-master system.
The basic idea was to disconnect the non-active master by isolating it from ground.
But the setting of the non-active master will still affect to the wholeness since the current partly goes through its pots.
VMS's proposal are not complete either and I see the second one better.
Franco, your proposal seems to be complete since the master are fully separated from each other
but I think it will definitely pop.
/Leevi
Ciao Risto
As I told, my schematic is without any shrewdness about preventing pops, it was only to swap completely the unused PPIMV out of the path
to avoid pops you must add resistors in parallel with switch contacts (I think)
How about pots parallel and switch between wipers with make before break switch
Do you mean something like this?
I added resistors across the switches to prevent pop.
/leevi
Yes something like that.
I'm just throwing ideas and hoping that the smarter forum members will chime in :smiley:
I agree, something like that
Remember that connected and switched that way the pots are in parallel, so if you use 1M pot is like you use 500K pots
EDIT:
Don't know if this will give a different load to the previous stage because here we have AC and no DC
(https://i.imgur.com/kygRk8t.jpg)
Yes, I have noticed that. I think two 500K pots would still work fine since the resistance will be 250K per side.
1M is probably a better choice?
Your proposal is worth to try.
/Leevi
k. nailed it - no interaction between the two dual-gang pots.
use a 22M across all 4 outer poles of the switch.
Ciao Peter
Are you sure ?
I was thinking that if there is a charge on the caps as to avoid pops the resistor must perform a discharge path for the instant on which the switch is acted and the cap is not connected to the wiper of the pot
Something like this
(https://i.imgur.com/G9IYvme.jpg)
:dontknow: :w2: :w2: :dontknow:
Thanks guys, now there are many proposals to be tried.
I have noticed that the resistors do not fully prevent the pop especially if you use bigger resistors.
But next time I have double PPIMV case I will try one of those.
/Leevi
i suggest you start with your schem on reply 13.
Less switches less potential pops and you can always double the first caps values if you're loosing to much bass
