Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: guitarjesus on January 25, 2018, 01:26:05 am
Found the issue with my BF Bandmaster, the vibrato channel volume pot is cracked inside the case. Which brand is a proper replacement for the BF Fenders? I wanted to use the CTS 1mef out of my Marshall while its apart but the threaded shaft is too short
CTS with metal shaft is fine. I also like Alpha.
bourns have a longer shaft bushing.
https://www.tubesandmore.com/products/potentiometer-bourns-audio-solid-shaft-24mm
