Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: machinist82 on May 02, 2018, 08:34:54 am
Title: sopht amp 12v layout help?
Post by: machinist82 on May 02, 2018, 08:34:54 am
I'm working on the sopht amp 12u7 12k5....and I really don't know what I'm doing.
The part I can't really figure out is the transformer/heaters/12v connections.
What I've got right now definitely isn't right.
Heaters go to 12v
Pins 5 and 6 on the 12k5 are labeled as the grid output connected to 12v, seems like the heaters shouldn't also be connected to this same 12v, but I'm not sure how else to do it.  4 turrets on the right hand side are the transformer, I'm using a slightly out of spec 500/3.5 ohm transformer as I had one laying around.
 Also I substituted the 1m and 2.2m resisters for gain/volume.  Not sure I have these correct either.
Not pictured is a 7812 circuit for filtering on the 12v input.
edited - 12k5 is correct
Title: Re: sopht amp 12v layout help?
Post by: shooter on May 02, 2018, 09:00:47 am
http://tubedata.milbert.com/sheets/093/1/12K8.pdf
should help, pics n everything  :laugh:
Post by: PRR on May 02, 2018, 12:30:37 pm
For lurkers: the 12K8 connections look wrong but ARE correct. It works different.
ALL the electricals in your car are connected to the same 12V battery. Spark-coil, cigar lighter, trunk light, navigation system....
Yes a car is a little more complicated so there are several "groups" and dozens of fuses so you can play the radio even when the headlights are shorting-out. But a little amp does not need such frills.
Post by: machinist82 on May 02, 2018, 02:39:31 pm
I don't know how I got 12k8 in my head it's 12k5.  Sorry.
http://www.sophtamps.ca/mambo/index.php?option=com_content&task=view&id=25&Itemid=37
http://www.r-type.org/pdfs/12k5.pdf
Post by: DummyLoad on May 02, 2018, 06:21:49 pm
just curious, but why? you need at LEAST 14.5V supplied to regulator input for the 7812 to operate and regulate. typically charging systems run @ 14.4V. your regulator may not regulate.  :icon_biggrin:
you could try a low dropout type (LT-1082-6), however, your car's battery is all the filter you need. `a noise suppression circuit may be what you really want.
Post by: DummyLoad on May 02, 2018, 06:23:15 pm
LT1086 datasheet.
Post by: machinist82 on May 02, 2018, 09:08:20 pm
It's not for a car in particular.  My plan is to run off a dedicated battery or power supply and generally the power supplies I have laying around are noisy.
