		Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: Oddvar on June 19, 2018, 12:04:36 pm
				Hi.  I have enclosed a pic of this build.  I was wondering if anyone could tip me on the best way to wire the OT an PT cables.  They are coming into the chassis approx in the middle under the board, where should I put them for less noise?
				distance and angle are the key points.  coupling between wires is usually minimum when they cross at 90 degrees, distance is a squared kinda math, so 1 more inch away cancels more than 1.  You are also working in 3d, so anything "off plane" helps.
 Ease n access helps when tweaking for minimum
				I would move the OT closer to the PT. Center it on the chassis (front to back) and positioned such that it is half way between the two EL84s.
				Good tis there, I think I'll do that.
				Here is a PDF of a Paul Ruby 18 watt chassis showing transformer postions
