Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: alange5 on July 07, 2018, 01:17:57 pm
I'd like to build something based on some of the Fender brown circuits - a cross between the 6G11 Vibrolux and the 6G5 Pro.
I'd like to incorporate the bias-vary tremolo of the 6G11 with the diode rectification and higher voltages of the 6G5.
The 6G5 calls for about 450V on the 5881 plates. I have two PT options in mind:
Classictone 40-18005
http://www.classictone.net/40-18005.pdf (http://www.classictone.net/40-18005.pdf)
330-0-330 @ 240ma w/ 50V bias
Classictone 40-18041
http://www.classictone.net/40-18041.pdf (http://www.classictone.net/40-18041.pdf)
325-0-325 @ 180ma w/ 50V bias and 5v windings
If I opt for the 325V PT, will I be ok with the 180ma current (2x6L6 or 2x5881), and could I simply tie off the unused 5v windings?
yes, yes
Thanks.
Here's the schematic I'll be working with:
(https://preview.ibb.co/j6DMXT/brown_amp.jpg) (https://ibb.co/kW6x6o)
Any glaring problems? Does the coupling before the PI look ok? (plate > 100k > .05 > grid)
Each preamp triode needs a 1.5K||25µF between the cathode and ground. Also, connect the .05µF coupling cap directly to the plate of the second preamp triode and remove the 6.8K, connecting point A directly to the 100K.
Thanks for the reply.
Here's the updated schematic with the "A" version of the tone stack (used in both the 6G11-A and the 6G5-A):
(https://preview.ibb.co/kfgQcT/brown_amp_copy.jpg) (https://ibb.co/cC9YWo)
I have an extra cutout for a pot on my chassis. I'm considering adding a master volume. If I use the "type 2" master volume where a dual gang pot replaces the power tube grid leak resistors, will the tremolo still work properly?
Here's the Robinette example from a 5F6A:
(https://preview.ibb.co/hr9vcT/type_2_mmv.png) (https://ibb.co/fJYMHT)
Trem should work with that MV. Before you commit to that tonestack you may want to find a source for that odd treble pot. Hoffman used to carry it, but not now.
Thanks for the help sluckey.
Looks like amprepairparts.com carries those tapped pots. They have a whole section dedicated to "brown" parts.
Thanks for the link.
