Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: kagliostro on August 27, 2018, 10:23:03 am
Title: 5F6 with reverb (Tubenit schem) someone developed a layout ?
Post by: kagliostro on August 27, 2018, 10:23:03 am
Hi guys
a member of DIYItalia want to convert a Carvin Valve Master into a 5F6 with reverb
at music-electronics-forum.com I've find a schematic that is attribuited to our friend Tubenit
(this is the thread http://music-electronics-forum.com/showthread.php?t=23241 (http://music-electronics-forum.com/showthread.php?t=23241) - post #17)
and would like to know if someone developed a layout
Many Thanks
Title: Re: 5F6 with reverb (Tubenit schem) someone developed a layout ?
Post by: tubenit on August 27, 2018, 05:36:49 pm
Hey Franco,
Always good to see you on the forum!   :thumbsup:
There is BOTH an editable SCH schematic and matching layout here  (see Reply #1) :
https://el34world.com/Forum/index.php?topic=571.0
CHECK it for errors as this is one I drew up quite a few years ago.
Post by: tubenit on August 27, 2018, 05:50:21 pm
Looking at the schematic idea of the Bass 5F6-A with reverb,  ……….. you could use a mosfet CF and free up one 12AX7 triode for a stronger reverb driver using a 12AT7?
Post by: tubenit on August 27, 2018, 05:53:28 pm
PLEASE check carefully the layout to see if it matches the schematic correctly.  IF there is a discrepancy, go with the schematic.
Also …………….
Here is the editable layout for the 5F6-A .
Franco,  do you have ExpressSCH or j-schem where you can edit the editable schematic and layout?
Post by: tubenit on August 28, 2018, 06:47:55 am
I got to thinking some more about the Bassman 5F6-A idea using a mosfet CF and having reverb added.  So I redrew the schematic and tried to draw a layout to match it.  CHECK for ERRORS!   IF there is a discrepancy, go with the schematic information.
Things to note:
2 inputs instead of 4,  split cathodes on V1,  mosfet CF,  & an additional stage of filtering.
Just an idea to consider.
Post by: kagliostro on August 28, 2018, 09:56:46 am
Ciao Tubenit
I've all is necessary to open and edit the files
Many Many Thanks for the schematics and layouts
Post by: tubenit on August 28, 2018, 10:56:20 am
You are quite welcome!   Just thoughts to consider for you.  They may or may not be useful.   :icon_biggrin:
