Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: Trapperbob on November 07, 2018, 12:24:24 pm
I have a kalamazoo two that needs a new opt, which one from Hoffman should I get? The champ replacement? I would like to match the original as close as possible. Thanks
I believe the K2 uses an 8 ohm speaker so you would need the part number Mojo771. However, Hoffman is out of stock and I don't think he will be restocking that transformer. But you can get it direct from Mojo...
https://www.mojotone.com/amp-parts/Output-Transformers/Blackface-Champ-Output-Transformer
