Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: mak009 on January 21, 2019, 06:22:12 pm
Title: GA15 RV turret board
Post by: mak009 on January 21, 2019, 06:22:12 pm
Hi,
First post :icon_biggrin:
Any thoughts on how to build up a turret board for a Gibson (Trace Elliot designed and built) GA15RV? I have the schematic and component list (from the manual)
The amp sounds great but is constructed "to a price" with fairly skimpy PCB traces and machine stuffed with 1/4 watt resistors and low grade components.
I am planning on building a more robust version on a turret board.
Any help much appreciated
mak009
Australia
Title: Re: GA15 RV turret board
Post by: sluckey on January 21, 2019, 06:58:26 pm
Read the first two topics in the "Hoffman Turret and Eyelet Boards" forum.
Post by: mak009 on January 21, 2019, 07:33:38 pm
Thanks for the reply.
I had already read those posts, but there is no info on how to transfer a schematic to a .dxf file.
That seems to be the tricky part-do you have to do this manually or is there a prog which accepts scanned schematics and generates a layout for turret or eyelet boards? Obviously there are lots of decisions in there regarding grounding scheme, power supply topology etc.
Post by: sluckey on January 21, 2019, 07:55:31 pm
Open the very first topic and look at the second line in the first post. Click on the link to go to Doug's program to create a custom board. Now click the button that says "Click here to create a new Board file". Follow the instructions to start putting turrets on a blank board.
Post by: John on January 22, 2019, 09:52:53 am
I think you're looking to submit a schematic, and have it automatically turned into a layout? if so, not on this site. You create the layout yourself on graph paper or whatever, and then manually input the info where Sluckey said.
Post by: mak009 on January 22, 2019, 07:45:35 pm
OK Thanks. Back to the drawing board.
