Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: Oddvar on May 11, 2019, 02:37:08 am
Hi. Is 2A slo blow fuse sufficient in a 230V Bandmaster build?
Schematics specify 2A slo for 120V operation. If you double the supply voltage you would typically half the fuse rating.
So 1A would be good?
I don't know. Is that half the fuse rating??? :dontknow: :think1: :wink:
The point being that you should check what mains fuse is used in the domestic USA amp, and halve that value for use at 230V with a 230V primary PT.
It will need to be a 'T' type time delay / slow blow.
