Amp Stuff => Tube Amp Building - Tweaks - Repairs => Topic started by: shark38j on May 29, 2019, 02:48:10 pm
I am working on a project with a Classic Tone #40-18016 power transformer. This is my first amp project and I expected the rectified voltage to be around ~450V DC. It seems to be much higher. As I bring it up on the Variac I reach 400V around 50V AC from mains. Am I missing something? I have the two red leads hooked to the bridge rectifier and the center tap floating. Any information would really be appreciated.
Measured Voltages
Voltage from Variac: 13.4V AC
Voltage out of Transformer: 78V AC
Rectified Voltage: 110V DC
Thanks,
Marc
Are All your tubes in? If not the voltage will be higher.
Yes tubes are in and I have verified plate voltages
Measured Voltages
Thanks,
Marc
That transformer will give you in excess of 900V B+ using a bridge rectifier. It was not meant to be used with a bridge. YOU MUST USE A CONVENTIONAL TWO DIODE RECTIFIER WITH THAT PT!
Ok, my understanding was that 330v - 0 - 330V meant that I would get +330V to -330V from it, 660V P-P. Your saying that I will get a peak of 660V from it, which is about what I'm getting. Is there a way to use the center tap to cut it in half?
Sure. Disconnect the negative terminal of the bridge from ground. LET THE NEGATIVE TERMINAL FLOAT. Then connect the transformer centertap to chassis ground.
Bring it up on a variac and the voltages will be more what you expect.
Everything working now???
